Team Magic E4 Thread
#1037
Hi guys,
I'm considering a Team Magic E4 RS, and need to know the following things:
Can it take stick packs?
How does it compare against other electric tourers on the market?
What's the quality like in TM cars?
I've got a Team Brood 11 turn single modified motor, would this be a good match up?
Cheers,
Michael
Cheers,
Michael
#1038
hey guys i have some custom milled steel battery trays and they are sweet they add 80+grams to the bottom of the car witch helps with makeing weight and helps the car handel much better mail me at [email protected] for info and pics
#1039
#1040
#1041
thanks
Pete
#1042
Finaly
...the car is done...have a Ko 2413 here to..
Lightweight spool by JP-Products
Xray Shafts around
TC SPEC
4.5
Teambrood and TSR cells
Special belt´s wider then the "wide".. this one fill up the whloe pulley..no slip here..
Front:
Rear
...the car is done...have a Ko 2413 here to..Lightweight spool by JP-Products
Xray Shafts around
TC SPEC
4.5
Front:
Rear
#1043
This spool, look good,
, Thomas. what belts are this? what brand? .
I´m wait for a FS version of E4, i think make a similar version how Wolfhobbies version, with the chassis of FS, and other parts from the RS version, Top deck, rear whisbones,...
Greetings, Luis C.
, Thomas. what belts are this? what brand? .I´m wait for a FS version of E4, i think make a similar version how Wolfhobbies version, with the chassis of FS, and other parts from the RS version, Top deck, rear whisbones,...
Greetings, Luis C.
#1044
Hi Luic, to be honest i do not know. i Bought them from a friend, that have been to a company that makes rubber gaskets,belts etc... it rolls a little slower, but propp will loosen up in time..
but i can check this out, or maybe fix some..cant promise, but il see what i can do ?
#1045
Hi guys,
Cheers,
Michael
Cheers,
Michael
#1046
hey guys,
i've just finished building my E4 and i want to bolt a brushless 17.5 (Australian Stock) in. Just wondering if any one has recommendation for a spur and pinon in 48pitch to get me started??
thanks
Prime.
thanks
Prime.
#1047
i would like to know to. i bought one of these and it doesnt fit around the dimples in the chassis that stick out towards the center of the car. and at 70 bucks a pop i shouldnt have dremmel slots into the side of it. i dont want to have to grind on my chassis either. do the newer versions of the e4 have these dimples in them? look at the bat tray if you dont understand what im saying. if you look at the top if it has a dimple on each side to fit past the the sides. look at the pic below and you will see.
#1048
hey guy's I'm comtenplating on swicthing rides. just curious what everyone opinion on this car. what are the main parts needed for spares. I read somewhere lipos don't fit(might be one brand). If i did go with this I would go with the asphalt spool version.
cheers.
cheers.
#1049
The original E4 Has to be modified to fit Lipos However the newer versions RS and FS Do not need to be modified you just need to use the shims which come with the kit.
i am selling my TM E4 RS version if you are interested look at my signature there is a link there
#1050
I thought lipos are not allowed in races as it's considered illegal.
