Team Magic E4 Thread >
Old 03-27-2008 | 08:44 AM
  #886
Canuck's Avatar
Originally Posted by Marcos.J
you will have to change to atleast a 96t spur gear to be in the FDR ratio for the 10.5, you need to be in the low 5's or high 4's
I guess that means a 19T pinion should do the trick. Where do you find the FDR for a 10.5 BL motor ?
Canuck is offline
Old 03-27-2008 | 08:55 AM
  #887
Canuck's Avatar
Shoot, I can't find a 96T spur gear on Wolf Hobbies site.
Canuck is offline
Old 03-27-2008 | 10:36 AM
  #888
Marcos.J's Avatar
Super Moderator
any spur gear will work
Marcos.J is offline
  #889
Marcos.J's Avatar
Super Moderator
Originally Posted by British Menace
Hey Marcus.J
I was thinking of getting the similar car from Wolf Hobbies. The E4 FS/C1. I plan on running the car on rubber both indoor AND outdoor. What do you think? Do you think this is the right car for what I want to do?
Thanks man.
British Menace
i havent ran the FS conversion , but yohan has
Marcos.J is offline
Old 03-27-2008 | 12:37 PM
  #890
I use Hara/HB springs, with the low support HB, too.
Greetings, Luis C.
luic is offline
Old 03-27-2008 | 01:10 PM
  #891
Originally Posted by Tabushi
Guys, where you can get a E4JS (the cheaper version) ?, and which differences are with the ultimate one ? ... this is meant for rubber based racing mainly, as a low budget start,
thanks,
Pat
Not out yet... maybe another week or two before its released.
Lycan is offline
Old 03-27-2008 | 05:09 PM
  #892
Canuck's Avatar
Oops ! More like a 40T pinion.
96/40=2.4 x 2.0588= 4.94112
Right ?
Canuck is offline
Old 03-28-2008 | 05:44 AM
  #893
Canuck's Avatar
Does anyone know if 48 pitch spur and pinion will fit on the E4 FS ?
Marcos, if I go this route, any recommendations for me instead of the 96T spur (64 pitch) ?
Canuck is offline
Old 03-28-2008 | 07:25 AM
  #894
Marcos.J's Avatar
Super Moderator
i ran 48 pitch on my car i ran a 74t spur and a 33 pinion for a 4.76 FDR.
Marcos.J is offline
Old 03-28-2008 | 08:08 AM
  #895
Canuck's Avatar
Thanks Marcos, exactly what I was looking for.
Canuck is offline
Old 03-28-2008 | 08:11 AM
  #896
Marcos.J's Avatar
Super Moderator
no problem , the car has limited room to move the motor around so your best bet is to get a few different spur sizes and pinions,this way you shouldnt have any issues getting the FDR that you need.
Marcos.J is offline
Old 03-28-2008 | 03:41 PM
  #897
yyhayyim's Avatar
Hey Marcus.J
Thanks man.
British Menace
Hi there...yes, I've run the FS converted to RS by Wolf...works great on asphalt. Good flex and crisp sharp handling with a good enough set up. Get it and run it!!!
yyhayyim is offline
Old 03-28-2008 | 03:44 PM
  #898
yyhayyim's Avatar
For 10.5 BL, a 48P 72T Spur works great. Lower than this, will not let you mesh...its 64P equivalent is 96T.
Get Kimbrough Spur gears or PRS....tower Hobbies, Stormer Hobbies, or NexusRacing.net
yyhayyim is offline
Old 03-30-2008 | 09:24 AM
  #899
gansei's Avatar
Default e4 movie
i did practice for Korea national race (will be beld after 2 weeks)
the modified class must use 5 cells.
i tested LRP 3.5T(4 timing).. But.. i want to get a little punch.
i am considering to buy New Speed Passion 2 BL 3.5 motor.
could it give more punch?
http://www.youtube.com/watch?v=3O06Rc9H5RE
gansei is offline
Old 03-30-2008 | 09:48 AM
  #900
Marcos.J's Avatar
Super Moderator
The SP 3.5 is very good!! also you might want to try the SP 2.5 with 5 cells (its a missile!!!)
Marcos.J is offline
