Team Magic E4 Thread >
Old 04-15-2008 | 12:37 PM
  #1006
mk2's Avatar
mk2
Default e4
has any one experinced that when you lock up the oneway to a sold axel that it makes the front wheels chatter and hop when you make hard turns and if so what did you do to fix the problrm ??
mk2 is offline
Old 04-15-2008 | 12:43 PM
  #1007
Marcos.J's Avatar
Super Moderator
you can cut back the steering throw a little bit and it will eliminate some of it , usually does it on full lock.
Marcos.J is offline
Old 04-16-2008 | 04:45 AM
  #1008
dev's Avatar
dev
Default setup for E4 on carpet
i would like to know whats the best setup for E4 on the carpet? im having trouble setting up my car. the rear of the car has no traction or grip into and out of corner, there's no traction or grip from the rear of my car. i hope some 1 can assist me, thanx
dev is offline
Old 04-16-2008 | 06:19 AM
  #1009
Marcos.J's Avatar
Super Moderator
rubber or foam?
Marcos.J is offline
Old 04-16-2008 | 08:08 PM
  #1010
Sal Amato's Avatar
As a hobby shop owner where do I get team magic products from?
Sal Amato is offline
Old 04-16-2008 | 10:51 PM
  #1011
Originally Posted by sns820
As a hobby shop owner were to I get team magic products from?
try wolf hobbies
mwoods is offline
Old 04-17-2008 | 03:45 PM
  #1012
Canuck's Avatar
Default Rear lower outer hinge pins
Any ideas on how to properly secure these rear lower outer hinge pins ?
What I don't like about ready assembled kit is the fact that most set screws are too tightened and loose there effectiveness. My kit is brand new (E4 FS-C1) and I have this problem.
A captured type hinge pin would be nice if it exist !
Canuck is offline
Old 04-17-2008 | 04:11 PM
  #1013
Marcos.J's Avatar
Super Moderator
what i did on mine i took a small drill bit and drilled a little bit on the hinge pin for the set screw to fit in to prevent it from moving.
Marcos.J is offline
Old 04-17-2008 | 05:28 PM
  #1014
Canuck's Avatar
Good trick. I will do that thanks.
Canuck is offline
Old 04-18-2008 | 02:50 AM
  #1015
dev's Avatar
dev
Originally Posted by Marcos.J
rubber or foam?
rubber tyre. take off 22
dev is offline
Old 04-18-2008 | 03:06 AM
  #1016
Canuck's Avatar
Default Binding up front on steering.
Got on my electronics installed and BL motor. With car on bench and power only at 25% whne I turn the front wheels over 40% of maximum throw I start getting a binding (hard vibration) up front. This happens only with the wheels installed . If I take one wheel off (either side) the sound and hard binding goes away.
Up front I have a locked oneway or spool (pin and insert in oneway).
I have the new E4 FSC1 version from Wolf Hobbies.
Anyone had this problem ?
Canuck is offline
Old 04-18-2008 | 10:08 AM
  #1017
Originally Posted by nocif13
for carpet or outdoor?
For outdoor, the last weekend a run the 1rd Nationals, and the car work well, but i have very bad luck, i broke 2 belts, 1 battery and a spurl, i finish in 8th in Final A, but i think in this track the car is more fast, i think is possible go to podium, i have some modifications in the setup and the car is more fast, in the last session i run in 19.3 and now i go to 18.9, and constants laps 19.0 - 19.1, but i feel the car need a litle evolution, for now, is not in the level of new 416, 08, MI3, the only change i think the car need, a litle change in the angle of ackerman, some of steering braces with differents longs ¿...?, or simply the steering from FS, i don´t know, for now.
Thanks, doug lemmons, i´m interesting in the changes, i like to testing, and i have some ideas and changes from the setup.
Greetings, Luis C.
luic is offline
Old 04-18-2008 | 10:23 AM
  #1018
Would that be the rib of the rubber tire rim rubbing the lower A-arm or anything of the suspension..? Looks like it must be something between the inside of the rim and the suspension IF there are no problem with THAT side of the tire is off.
Solara is offline
Old 04-18-2008 | 11:06 AM
  #1019
nocif13's Avatar
motor 9.5 speed pasion
esc feigao
nocif13 is offline
Old 04-18-2008 | 11:48 AM
  #1020
Canuck's Avatar
Maybe, need more coffee tonite and time to continue checking. It's pretty noisy and jerky. I am thinking something about the CVD's maybe.
Canuck is offline
