Team Magic E4 Thread
#1070
I was prepping my E4 last night in an attempt to run it for the 1st time this weekend and noticed that the bar where the sway bars slot into seems to move at one side, which in turn makes one side of the sway bar more responsive than the other and therefore stiffer which must effect the handling. Is this normal? or if not how have you guy's fixed the problem.
It does this at both ends, it's the bar mounted to the bulkheads. From looking at it it will make cornering one way different to the other.
Cheers
Aaron
Cheers
Aaron
#1071
Cheers
Aaron
Cheers
Aaron
#1073
#1074
#1076
Hi I was looking into getting an e4, but I dont know what to buy. I run rubber asphalt in the summer and carpet foam in the winter. I also run trakpower 4900 lipos. Which model will be the best for me. Also I do not like running a spool or oneway.
How do the a arms hold up? I looked at the chasis over the weekend and that was the only thing that I saw on the car that looked weak at first glance.
#1077
#1080
FYI
The new Intellect 3800 hard case Lipos fit my E4.
Just needed to drill a hole in the back end of the top deck so that I could plug the negative wire into the battery. It doesn't appear to weaken the top deck but means I can't mount my cooling fan there anymore.
