Team Magic E4 Thread >
Old 12-05-2007 | 09:48 PM
  #316
YLLIB's Avatar
Hello Isaac, You can get the g4rs, e4 and g4+ at SpeedWorld in Calif. They have them and getting the g4 rs this week.
www.speedworldraceway.com
Hope this helps
YLLIB is offline
Old 12-05-2007 | 10:37 PM
  #317
I would like to know is this know optional parts fit with orion li-po 3200?
billbill4u is offline
Old 12-06-2007 | 12:06 AM
  #318
gansei's Avatar
my li-po 4800 was fit with this option..
gansei is offline
Old 12-06-2007 | 03:31 AM
  #319
Originally Posted by Thomas P
Any tip for how i will mount the batterybars at the end of each pack? 5 cell config.Check Ganesi´s lauyout no problem with batt tubes on + and -,BUT with 5 cells it will not be so much space between topdeck and servo..
I run with 5 cells, and not have problem with conectors, the - i have in the rear right, near to ESC and the + in the left, near to midle belt.
In the other hand, i testing more the car, and the feel is good, but i need more agile in front, i modified the rear arms, and now can adjust the wheellbase in 2mm, the car is more reactive when is short, and for me, is more fast.
In front, i feel the steering system, more flex, and have bump steer, if add washer to steering block, the bump steer is reduced, but the steering block flex and make the steering slowly, and litle imprecise.
Now, i put the steering carbon brace upside down, how the photo, but i suplement the plastic braces, because touch in the top deck, and for make more consistent this zone, i have not yet tested, but i reduce the washer in steering block to 2 mm, and the bump steer is insignificant.
I dont have any problem with the dogbones, are very good, but the blades in rear break, and in the list of parts is the same ref, to the dogbone, i hope TM that manufactured separately, for now i adapted a Xray blades.
And the next week, i hope to testing the new spool.
For now is .2 -.3s , more slow, to the Cyclone in the same circuit, same tyres, same electronic, and same driver, but i need more work with he.
Sorry if my English is not more readable, ;-)
Greetings, Luis C.
luic is offline
Old 12-06-2007 | 05:37 AM
  #320
cuttingedge's Avatar
Has anyone made o front Diff for there E4 ? looking at it i am wondering if a Tamiya 415 rear diff might fit ill try it later
Front diff maybe a good option for tight tracks as as we all know a hard impact with a spool in means somthings got to give as earlyer mentioned in this tread by somone who,s drive shafts keep breaking .....
Cant wait to run mine for the first time Sunday...........
cuttingedge is offline
Old 12-06-2007 | 07:06 AM
  #321
gansei's Avatar
Default front bearing block
gansei is offline
Old 12-06-2007 | 04:26 PM
  #322
Jochim_18's Avatar
where can you get those K factory option parts fot the E4?
Jochim_18 is offline
Old 12-07-2007 | 01:38 AM
  #323
gansei's Avatar
i buy it from korea TM Dristributor.
gansei is offline
Old 12-08-2007 | 11:59 AM
  #324
I have two E4 cars that I run
One in Stock 27T silver can which has had no problems
One in Mod 4.5 Brushless 5 or 6 cell. This car has snapped 7 UJ's in 3 meetings
Anyone have a quick fix to stop this happening?
After a year off racing electric I have found these cars very easy to drive with top results gained running the cars out of the box. Lots of rear end grip with excellent handling.
NZHobbies is offline
Old 12-08-2007 | 04:28 PM
  #325
Hi Gensei, Just wondering what the red screw on your top deck is screwing in to? Mine just has a plastic insert there with no mention in the book?
many thanks, john
Grindog001 is offline
Old 12-08-2007 | 05:30 PM
  #326
gansei's Avatar
many thanks, john
it is just decoration..
gansei is offline
Old 12-09-2007 | 09:06 AM
  #327
Thomas P's Avatar
any news or ideas on Steel CVDs rear?, the alu wont last longtime..a friend does Mod, and he snapped 2 today on poor gripp carpet... any ideas? no other brands that is direct fit?
Thomas P is offline
Old 12-09-2007 | 09:11 AM
  #328
gansei's Avatar
Rear CVD is not Steel.. it is aluminum...
front CVD is Steel...
is it fit front CVD on rear?
gansei is offline
Old 12-09-2007 | 09:59 AM
  #329
Thomas P's Avatar
ahh, maybe i wrote little wrong, rear CVDs are snapping off like toothsticks, they are Alu.
is there any news if Steel is coming for rear? OR can front be used @rear?
can other brand be fitted until TM reelese any Steel rear cvds?
Thomas P is offline
Old 12-09-2007 | 09:39 PM
  #330
I have the same problem and I use front CVD on rear that fit.
However, my front CVD broken too, now I use 415msx front CVD & hubs fit on E4, I really hope TM can modify they CVD, it too weak!
