Team Magic E4 Thread
#303
We have received numerous requests to have the E4 Sedan from Team Magic reviewed on www.rctvlive.com. We are pleased to announce we will have the E4 on a future episode. Thanks for your interest. Jeff
#306
What is the weak point of this car ( i will only runt 27T Stock untill i get more Licens points,to do Mod). What is the most comon parts that breaks? what spare should or MUST i have,how is the Belts,the diffs. Did see a pic of the D-bones..that didnt look to good, will this be a issiue on a 27T car?
I will run schumacher rubbers,and a 27T motor, tracks are preaty medium, and grip is medium...what Pinion and Spurs is recomended to have in the butler?
For motor i wi use a Tuned Advance 27T and Advance 5.0 ESC. think 5 cells TSR will be enough.
tips and hints would be good...2 of my club m8s running the E4, one 27T and the other Mod..the ar seems REAL smoth...
#309
ok, but in stock 27 i dont think the belts will go, but i ordred some anyway...we only using Schumacher rubbers, no track sauce... What range of springs, and Where can i getém? my local hobbyshop is a TM dealer, but dont have al parts yet, but all the NT arts, will thoose springs fit? and what oil is usble? what W?
#310
i used TM G4S Spring 1.4,1.5 and shock oil was 350 ~ 450W.
and i also used serpent yellow,white front spring(GP spring)
#311
..thank god thats no issiue in buggy for me, free motors/escbut very much thank you for thoose tips, il get thos asap...maybe some softer...
#314
#315
Any tip for how i will mount the batterybars at the end of each pack? 5 cell config.Check Ganesi´s lauyout no problem with batt tubes on + and -,BUT with 5 cells it will not be so much space between topdeck and servo..
