Team Magic E4 Thread >
Old 01-27-2009 | 02:49 PM
  #1801
Originally Posted by Axlegrease
Ref E4RS
Hi I am having the exact same problem with pulleys, I was replacing them on the rear only to notice that the original 'side' pulley should have a longer conical nose on it. If you replace it with one of the pulleys 503197 then it does not sit against the bearing and then there is too much end float on the layshaft! I have an aluminium pulley (aluminum if your reading this outside of the UK!) but this pulley is narrower.
Anybody got any coment on how to overcome this, a spacer maybe?
Also:
a/ I have heard that replacing the 17t pulleys with 18t reduces belt slip is this the reason for using 18t?
b/ Do I replace have to replace all 4 off pulleys or can I just replace the centre pulleys (the 18t packet 503222 has 2 off identical pulleys so I have the same problem as menioned above i.e. they are both the same in the packet and the layshaft is sloppy so I just want to replace the centre pulleys and leave the original 17t pulleys for the long belt)
c/ Does using 18t pulleys affect the internal ratio of the car?
Any help here would be most appreciated!
Regards,
Steve
I hear you on that one man. I wish there was a billet 18t pully kit for the whole car . I'd buy it !
John St.Amant is offline
Old 01-27-2009 | 05:53 PM
  #1802
HarryN's Avatar
Doesn't the new 2009 version of the E4 address a lot of these issues? I think I read about it on Redrc.net nd it was linked to Team Magic's site.
HarryN is offline
Old 01-27-2009 | 11:10 PM
  #1803
It would appear that the exploded view listed against the '09 car just shows the same old pulleys and does not differentiate between the side pulley and the centre pulley ref PDF link below which was posted on the TM website last year but has it listed against the '09 car
http://teammagic.com.tw/Download/E4R...ded%20View.pdf
I think I shall use ligthweigh 17t pulleys in the centre and Aluminium on the sides to over come this problem as I need yo sort it out before Sundays racing!
Axlegrease is offline
Old 01-28-2009 | 01:32 AM
  #1804
I think that's what you need for the center pulley, part# 503236
http://www.teammagic.com.tw/en/profr...3236&pageNum=1
K4neX is offline
Old 01-28-2009 | 07:06 AM
  #1805
Tomradio's Avatar
Ref E4RS
Also:
Regards,
Steve
The 18t pulleys change the IR of the car. They are used when running foam tires. The 18t pulley can only be used up front when running a ball diff. If you’re having belt-shipping issues try the new PU belts they are a little tight at first but they break in nice. The 09 comes with the new belts.
Tomradio is offline
Old 01-28-2009 | 08:15 AM
  #1806
SLOPPY!
Old 01-28-2009 | 02:16 PM
  #1807
liljohn1064's Avatar
I have a couple sets of the old belts NIP front, back and center if anyone needs some. My 21.5s haven't even stretched the originals out in the 3 months I've been running them.
liljohn1064 is offline
Old 01-28-2009 | 02:59 PM
  #1808
I think my E4 will make a great T/A.
Old 01-28-2009 | 06:23 PM
  #1809
They sure do.
Old 01-28-2009 | 08:02 PM
  #1810
What are you guys running with on the pin/spur??
milton6599 is offline
Old 01-28-2009 | 09:28 PM
  #1811
Mine like a 94/43. I have a good balance between acceleration and top end and the motor comes off around 120 to 130.
Old 01-28-2009 | 11:59 PM
  #1812
Rommel's Avatar
These will be available soon for anyone who might be interested.
Custom Cut Urethane Chassis Protector for Team Magic E4 #503105 chassis!
Rommel is offline
Old 01-29-2009 | 05:01 AM
  #1813
Aren't you allowed to gear it 4.2 final?
Old 01-29-2009 | 06:11 AM
  #1814
The motor gets way too hot at 4.2. We experimented and the car started losing time the further we got away from a 4.4 in either direction. It might just be my cars, but its the same for both. If my driving and my son's wasn't so awful, they would probably finish in the top 5 every week.
Old 01-29-2009 | 06:58 AM
  #1815
Good 2 Know kinda info !
