Team Magic E4 Thread
#1951
John
#1955
Sorry to inform you but all that slop in my car is due to the bearing holes being too big for the bearings. The slop you are refering to is taken up once the wheel is bolted on. There has to be atleast .005" too much gap and the bearings float around in the uprights. Changing the axels will not fix my slop issue. Its the plastic, not the metal.
#1957
#1959
Im still deciding on what to get for 13.5 brushless racing on low budget, can you more or less put me on one side of Hot Bodies Cyclone S tub chassis v/s E4 JS tub chassis kits ?. Downhere in Chile we have a TM importer but he is 100% on nitro and if i go E4 i will go alone same thing on Cyclone S.
thanks,
Pat
thanks,
Pat
#1960
Suspended
Sorry john i didnt put all the info. When i was at snowbirds with wolf he and dave were running the new proto type aluminum 0* rear hubs. They also were running the new axles. soi dont know if the k factory hubs solve it, but the ones wolf is making will take the slop out.
#1961
The axles and hubs have been an issue for some time. We have spoken with TM about the materials factor for a year now. To help everyone out we are stepping up to the plate.
The hole in the plastic hubs is not too big when the hubs are new. The issue is that the material "cold flows" This means that as the bearing is banged around the hole gets larger in at least one direction. We have checked many hubs on Optical comparators and CMMs to verify this. The simple solution is to glue the bearings into the bores. CA works the best but if you are doing this a day ahead of time you can also coat the bore with Loctite 242 or shoe goo. You need to put the adhesive in the bore before putting the bearing in or else you risk gluing the bearing into a solid. We have tested this many times and it works very well. It is also a way to salvage a hub that has become sloppy.
The reason for the new axles was not an issue of slop (the shims take care of that) but more importantly width. The intent was twofold. As it comes the nominal width of the E4 is 185mm. Adding shims under the wheels is one way to make the car wider but causes durability issues. (The reason why Barry lost a wheel in practice at IIC was that he had so many shims spacing the wheel out that there was no plastic covering the pin. Once he got up to speed the O ring couldn't retain the pin so the entire assembly came apart). The new axles come in Titanium for strength and 7075 Aluminum for economy and weight reduction (less than2 grams each). But the best part is that the drive hexes come in varying widths from -.25mm (for wide foam wheels at ROAR events) to +.75 (for Trans Am fronts to bring them out closer to 200mm) This will allow you to tune with front and rear track width and really balance the car. The other reason is that really hate "fussing" (not the word I really mean) with the O ring to take the axles apart.
The hubs and caster blocks are also in response to providing something that is not available anywhere else. The rear hubs are available in 0 and 1 degree toe angles. The front caster blocks are available in 3, 6 and 8 degree angles. We also have plans for 4 and 5 degree blocks if there is a demand. One of the great features is that the caster blocks are hard anodized. This gives them a very tough wear resistant pin bore that will make them last much longer than what is now available.
Please be aware that these are completely new designs. They are similar to TM parts only in the areas that require them to fit the existing car. There are also two other factors that make these special to us. First is that they are made in the USA and second the price is aimed at being less than what is available now.
The big question you are all asking is WHEN????? The answer is now...sort of. There have been many delays in these parts that are just beyond our control. Three hours from now I should be doing the final check on the parts at the machine shop and releasing them to the platers. We will get them by Tuesday and ship as soon as they arrive. They will be on the web site by Monday but the photos will be of unplated parts until Wednesday. The titanium parts are not plated.
To set the record straight Dave did not use the prototype parts at the Nationals. I did bring them along to show him and for him to take home for more testing. I did use the 0 degree rear hubs for my rubber car to cope with the tires they speced for the race.
#1962
Wolf Hobbies is very pleased to announce that Marcos Jennings has joined our "family" of team drivers. Most of you already know him as a regular contributor on this forum. but for those of you that do not know him he is a truly excellent driver, setup person and without a doubt one of the nicest people in R/C. He works very hard at developing his car but always finds the time to assist anyone that needs help. We are pleased that he has decided to join us and to be our "point man" in the Southeast. Welcome aboard Marcos!!
#1963
I'll be posting some new set ups by sunday or monday for outdoor rubber asphalt.
#1964
Hey guys...
a mate just bought one and it the one where the batteries are loaded in via the bottom.
Our question is.... how and/or what type of lipo can be fitted in. We dont want to get the dremel out just yet.
I have an intellect hard case and it is just physically too big
Any suggestions appreciated
Stangas
Stangas
#1965
Cheers,
Simon
The carbon shock towers work nice too.
