Team Magic E4 Thread >
Old 01-21-2008 | 01:13 PM
  #451
nocif13's Avatar
http://www.petitrc.com/_forumphp/sho...ewpost&t=34757
have you got a set up sheet for carpet and rubber please
thank
nocif13 is offline
Old 01-22-2008 | 09:04 AM
  #452
Anyone know, if there is any possibility of releasing the extreme version of Foam Spec or the refined version of rubber spec??
Now I'm in this situation
If I buy the first version (Rubber spec) I will have a lot of options aluminium caster block, aluminium pulley, but I will face with the problems that already raised in this thread i.e. drive shaft, delaminated belt, not compatible with Li-Po(need some modification)
If I buy the Foam Spec I won't get those options as rubber spec.
Plastic Caster block, plastic pulley. Plus I have to buy oneway diff.
but I will get new belts(wider), new shock, stronger driveshaft, redesigned chassis, redesigned bellcrank, air duct.
black_spl is offline
Old 01-22-2008 | 10:35 AM
  #453
Rubber version as you call it, is end of line so I'd go with the new FS.
http://www.rcview.com/showthread.php?t=93
Lycan is offline
Old 01-23-2008 | 07:27 AM
  #454
gansei's Avatar
Originally Posted by nocif13
GANSEI
You have a picture to compare the shaft XRAY T1 and TM on the same photo ?
this picture is T1 Shaft on E4
Attached Thumbnails Team Magic E4 Thread-sany0001.jpg   Team Magic E4 Thread-sany0002.jpg   Team Magic E4 Thread-sany0003.jpg
gansei is offline
Old 01-24-2008 | 08:45 AM
  #455
nocif13's Avatar
my E4
Attached Thumbnails Team Magic E4 Thread-1834-pc250007.jpg   Team Magic E4 Thread-1834-pc250003.jpg   Team Magic E4 Thread-1834-pc250012.jpg
nocif13 is offline
Old 01-24-2008 | 09:00 AM
  #456
Hey I just saw the E4 on www.rctvlive.com
VERY COOL congradulations Team MAGIC!
microcrazy24 is offline
Old 01-24-2008 | 06:32 PM
  #457
gijoe64's Avatar
Hey I just got the E4FS Foam Ver. is there a setup for this car yet?
gijoe64 is offline
Old 01-27-2008 | 05:55 AM
  #458
gansei's Avatar
Default E4 Movie
This Movie is E4's Run in Korea Kirina Circuit.
i used Orion 3.0T BR motor and Much-More AT 28 tire.
i recorded Best Lap 17.5 sec in this movie.
But i recorded Best LAP again 17.056 sec with Much-More AT 32 tire.
My Previous E4's Best Lap was 17.7 sec.. what a surprising growth!!
and TOP CLASS GP Touring car average Best Lap was about 17.0 ~ 17.3 secs.
But my G4RS(TM GP car) Best Lap was 16.6 sec.
http://www.youtube.com/watch?v=vkl3jXEPnjA
Attached Thumbnails Team Magic E4 Thread-sany0001.jpg   Team Magic E4 Thread-sany0005.jpg
gansei is offline
Old 01-27-2008 | 08:45 AM
  #459
nocif13's Avatar
the e4 win in a french regional 17T
http://teammagice4.blogspot.com/2008...-ligue-10.html
setup for carpet
http://NOCIF13.FREE.FR/E4_TRETS.pdf
nocif13 is offline
Old 01-27-2008 | 10:10 AM
  #460
It did look good on www.rctvlive.com The E4 is a VERY well made and thought out car. It should start building momentum now....Way to go Team Magic!
Ginsu is offline
Old 01-27-2008 | 12:16 PM
  #461
hi does anyone no the spring rates for the kit springs?
thanks
mwoods is offline
Old 01-27-2008 | 03:32 PM
  #462
Mi2_Tastic's Avatar
Mark you have mail!!
Mi2_Tastic is offline
Old 01-28-2008 | 02:48 PM
  #463
This is my new E4
White_Masta is offline
Old 01-28-2008 | 03:34 PM
  #464
British Menace's Avatar
Originally Posted by White_Masta
This is my new E4
That is a very nice paint job........congratulations on having the E4 and for doing such a fine job on the paint work !!
British Menace
British Menace is offline
Old 01-28-2008 | 09:53 PM
  #465
Thomas P's Avatar
Did anyone ave any info on the "new" rubber E4 ? Will it be similar to the Carpet car, but thinner chassi ?
When will it be available in the shops, or can the old be upgraded, is the fittnes better in that car? the stock one i have is heavely shimed.
And one more thing, arnt the shops worldwide intrested of this car and it parts? i know 2 shops and they are most of the time out of parts...that can only means the car is weak or team magic dont produce parts enough or they arnt intressted having parts in stock?
Thomas P is offline
