Old 08-18-2008, 11:41 AM   #1201
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally Posted by yyhayyim View Post
Hi Anthony,
I've run both the single and dual steering link, and the dual will make the car react off center quicker. Allegedly, when you have shorter steering links, you get quicker reaction off center, and that's what the duo link has over the mono link...the mono link system makes the steering smoother and more consistant, and better on bigger open tracks.
Regards,
Yohan
Hey Yohan , i got the E4 working really good!!! you need to pick one up again!
Old 08-18-2008, 03:39 PM   #1202
yyhayyim's Avatar
Trader Rating: 26 (100%+)
The version I need will have to have aluminum brace up front for the camber links, and rear aluminum hubs, because the stock plastic ones had a lot of play on them after a couple runs.
I'll check with Wolf and see if I can get a C1 with rear aluminum hubs, and that front camber link aluminum brace.
Dash 4 the cash with the TM E4?
Florida State Series?
Very tempting...just gotta move some cars
yyhayyim is offline   Reply With Quote
Old 08-18-2008, 03:55 PM   #1203
Super Moderator
Marcos.J's Avatar
mine has almost no play at all
Old 08-19-2008, 07:46 AM   #1204
Super Moderator
Marcos.J's Avatar
I made a typo on the set up that I posted , on the Bladder note i put "none" but i meant no o-ring under the bladder.
Anthony I answered your email
Old 08-19-2008, 10:28 AM   #1205
STLNLST's Avatar
Trader Rating: 21 (100%+)
way to cost someone a TQ spot with that bogus info..... How's the scene out your way bro? Touring car is drying up a little out here. I will be going to off road for the winter months. We still have the KO race and the regionals to come out this way but after that my sedan will be packed away.
STLNLST is offline   Reply With Quote
Old 08-19-2008, 11:33 AM   #1206
Default TM shock set?
I have the TM shock set 502143,
I need to know the different lbs for each spring, Can anyone help please.
Thanks Anthony
<<<<<<<<<<<<<<Team Magic E4>>>>>>>>>>>>>>>
Web Master for DMS RACING www.dmsresults.co.uk
A Coldman is offline   Reply With Quote
Old 08-19-2008, 11:47 AM   #1207
Super Moderator
Marcos.J's Avatar
Thanks Anthony
TM Springs:
1.2mm= 10lbs
1.3mm= 13lbs
1.4mm= 17lbs
1.5mm= 20lbs
1.6mm= 26lbs
1.7mm= 31lbs
1.8mm= 41lbs
1.9mm= 51lbs
Old 08-19-2008, 11:48 AM   #1208
Super Moderator
Marcos.J's Avatar
Actually the mod class has been picking up alot!
Old 08-20-2008, 02:35 PM   #1209
Super Moderator
Marcos.J's Avatar
I dont know if any of you had problems with the rear belt in mod but i had 2 that stripped , I found a stronger belt its a little wider. I wqill be testing it out tomorow with some mod motors. As you can see in the following pictures the difference between the stock belts and the new belt that i got. I had them made for me and I had to order a few to meet the minimum order so I have a few extras if anyone needs them.
Old 08-20-2008, 03:41 PM   #1210
STLNLST's Avatar
I'm sure Wolf would like all future pics to have the rear shocks attached
Old 08-20-2008, 03:53 PM   #1211
kufman's Avatar
Where did you custom order the belts from? I was thinking about doing the same for my XX-4.
kufman is offline   Reply With Quote
Old 08-20-2008, 10:52 PM   #1212
Super Moderator
Marcos.J's Avatar
Old 08-21-2008, 06:33 AM   #1213
Default Rear Belts?
I would be interested in some of those I run mod and my rear belts keep stretching. Please Pm me details.
Also What shocks are you running, as they dont look anything like the ones on my E4?
Thanks Anthony.
Old 08-21-2008, 06:55 AM   #1214
Super Moderator
Marcos.J's Avatar
Thanks Anthony.
ygpm for belt info
The shocks are from TM they are the newer ones , also Im running the bottom shock spring collar from the TC5 to be able to use the AE springs.
Old 08-21-2008, 07:09 AM   #1215
slakr's Avatar
Trader Rating: 31 (100%+)
Marcos, I would be interested in one belt to keep as my spare.
But do you think I will have much of a problem considering I probably won't run anything faster than 13.5BL?
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is online now   Reply With Quote
team magic m1b pitdog Nitro Off-Road 447 04-30-2013 09:17 AM
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
Team Magic G4 J_Longbrake R/C Items: For Sale/Trade 0 10-07-2004 07:56 PM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
