Team Magic E4 Thread
#1351
I am thinking about picking up the e4rs car for this season. I've been running the losi and i've been fairly decent with it but I'm thinking of trying something new. I mostly run on an indoor asphalt track with really high traction. I am just wondering how this car compares to the losi, i know they have similar design concepts with the center weight. Also, is this car pretty good right out of the box or are there a lot of extras needed to make it competitive? Thanks
If you get the E4RS I have a few set ups for rubber asphalt to get you started.
#1354
#1355
as long as you can find small spurs you shouldnt have any problems getting the ratio that you need for the 17.5, I have an assorment of spur gears and i can get ratios from the 3.45FDR range all the way to 14.75FDR
#1356
#1358
Ok guys, need some help.
Going to go for a E4 JS to start *(Just been told we're going to be getting a new indoor track so wont have to travel 5 million miles to race!!!)**
A set up for rubber tires, on carpet and what parts will I need to get this set up?
Also,
Looking at going into the 13.5 class. Reasonably priced brushless and speed controller combo'
(Bear in mind guys......I spend all my money on nitro so .... :-) )
This is going to be budget electric racing to keep my eye in for next year...lol
Thanks for any help you can give :-)
british Menace
Also,
british Menace
#1359
Also,
british Menace
Also,
british Menace
#1362
Ok thanks for the tip Marcos. I'll have a look into that.
The JS at $199 is a real bargain at the moment !!
Just need to find someone with the Speedpassion and SP13.5 motor now
Thanks again.
British Menace
Thanks again.
British Menace
#1364
13.5 is probably the new 19T class...running some entry level tub car just won't cut it. You will ended up buying a little bit upgrade here and there just because you just can't get as fast as someone's Mi3.5, Phi T2 2008 at your track....I can garantee you this, you will find plenty of those $400 plus chassis at the 13.5 class. Hardly you will see someone running a $200 car and be winning in this class...
17.5 is sportman, I will leave it to the sportman ppl...
BM, you need to think about the E4RS, or the Schumacher Mi3.5...
FYI...indoor carpet racing is totally different then Leisure hour raceway or 1/8th raceway...every INCHES on the track count and there are no 2-speed and 353 tuned to help you.About the speedo, lipo and motor, no other choice - SPEED PASSION and CORE all the way.
#1365
Thanks Solara,
Good info'.
I wasn't going to bother with electric at all cause there isn't a track in 3 hrs drive of here :-(
But since there's going to be a track just 2 -3 miles opening up this weekend........... and a good one at that. I've thought again.
Be nice to put Team Magic and the E4 , not to mention RCManufactory on the map over here eh Solara?
Talk soon and thanks again
British Menace
Good info'.
British Menace
