Team Magic E4 Thread >
Old 08-21-2008 | 06:14 AM
  #1216
Marcos.J's Avatar
Super Moderator
Originally Posted by slakr
Marcos, I would be interested in one belt to keep as my spare.
But do you think I will have much of a problem considering I probably won't run anything faster than 13.5BL?
If you are only running 13.5 the stock belt should be just fine.
Marcos.J is offline
Old 08-21-2008 | 08:54 AM
  #1217
kufman's Avatar
Originally Posted by Marcos.J
does that mean it is a secret?
kufman is offline
Old 08-21-2008 | 09:38 AM
  #1218
Marcos.J's Avatar
Super Moderator
Well a little bit , but if you need one let me know.
Marcos.J is offline
Old 08-21-2008 | 12:34 PM
  #1219
Marcos,
Have you tried the K-Factory belt(k2116)?
Barry Baker is offline
Old 08-21-2008 | 01:14 PM
  #1220
Marcos.J's Avatar
Super Moderator
Originally Posted by Barry Baker
Marcos,
not yet but I have one on the way. Im testing the new ones out tonight , Im sure they will hold up with the mod motors( SP3.5)
If you want to try one let me know.
Good luck in Vegas!
Marcos.J is offline
Old 08-21-2008 | 07:02 PM
  #1221
Marcos.J's Avatar
Super Moderator
Well I tested the new rear belt tonight with the 3.5 SP motor and it was great! I think I have my belt skipping issues solved!!
Marcos.J is offline
Old 08-21-2008 | 08:47 PM
  #1222
Marcos
I run your latest setup with one minor change I ran a a front diff. Find this easier to drive on a tight indoor carpet track.
I like the setup only problem I found was I am generating a lot of grip and steering now, to much infact to the point that the car was grip rolling on some of the faster corners.
I turned down the steering travel, this helped in the fast following corners, but the car then doesnt have enough lock to get me round the slower corners and it wont change direction. So I am basically back to where I was with my original setup.
Any ideas on how to remove the grip roll but keep everything else.
Thanks Anthony.
A Coldman is offline
Old 08-21-2008 | 09:17 PM
  #1223
Marcos.J's Avatar
Super Moderator
Originally Posted by A Coldman
Marcos
Thanks Anthony.
you got me there I dont race carpet much, but I would start by running stiffer springs in the front or maybe 6 degree caster blocks, Im going to be racing carpet next weekend I will start with that set up and see what happens. Like I said I dont race alot of carpet so Im not sure.
Marcos.J is offline
Old 08-21-2008 | 09:33 PM
  #1224
STLNLST's Avatar
Randy Caster would have had an answer......
STLNLST is offline
Old 08-21-2008 | 10:01 PM
  #1225
clint do you have yours together so you and your teamate can bond?
AARON YOUNG is offline
Old 08-21-2008 | 10:04 PM
  #1226
STLNLST's Avatar
My TQ car from Marin is still together and ready to race at Ripon on Saturday. I just hope I don't let you down
STLNLST is offline
Old 08-21-2008 | 10:05 PM
  #1227
maybe wolf will sponsor you so you and barry can work together.
Old 08-21-2008 | 10:15 PM
  #1228
STLNLST's Avatar
w do have the same birthday's.....LOL You can be the local Team Magic driver. I'm cool with what I have
STLNLST is offline
Old 08-22-2008 | 06:26 AM
  #1229
Marcos.J's Avatar
Super Moderator
I guess I could copy and paste someones answer but I was just being honest, that i have no clue when it comes to carpet
Marcos.J is offline
Old 08-23-2008 | 05:40 PM
  #1230
Marcos.J's Avatar
Super Moderator
Well I installed a few K-Factory goodies and Im going to test tomorow at our local club race. Made minor changes to the set up that I posted before and if the changes are positive I will post the new set up sheet tomorow night.
Marcos.J is offline
