Old 04-04-2009, 04:39 AM   #1966
xlamontx's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Stangas View Post
Hey guys...
a mate just bought one and it the one where the batteries are loaded in via the bottom.
Our question is.... how and/or what type of lipo can be fitted in. We dont want to get the dremel out just yet.
I have an intellect hard case and it is just physically too big
Any suggestions appreciated
Stangas
I have the 3Racing 3700 hard case in mine. Its a tight fit, but no dremmel or shims required.
xlx
"Have Car ~ Will Travel"
XLX Racing (Est. 1995)
TRACK MASTERS R/C ~ TEAM DRIVER
MSRA-Racing.com
xlamontx is offline   Reply With Quote
Old 04-06-2009, 01:50 PM   #1967
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Here is another set up that I got over the weekend. I will be trying out other things on thursday and if the car gets better I will post them.
File Type: pdf Marcos.J E4 Rubber set up with Xenon tires..pdf (394.4 KB, 122 views)
Old 04-06-2009, 02:24 PM   #1968
How can I get 3 for the rear toe angle?
I can get max 2,5.
SebO is offline   Reply With Quote
Old 04-06-2009, 02:25 PM   #1969
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Thumbs up
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 04-06-2009, 02:44 PM   #1970
Super Moderator
Marcos.J's Avatar
I can get max 2,5.
you need the onboard toe set at 1.5 then use the K factory 1.5 degree rear hub, or the Wolf Hobbies Rear hubs that will be available soon.
Old 04-06-2009, 10:34 PM   #1971
Hey Marcos, set up looks close to mine only a couple changes. What kind of track are you running on?we run on a track that is prepped with soda. i am running the team magic 13lbs spring all the way around with no swaybars. When you shim up the fron roll center in the rear, what does that accomplish. Something i was going to try 1mm all the way around, but never got to it.
Are you going to be attending reedy this year?
WEEZY is offline   Reply With Quote
Old 04-07-2009, 03:10 AM   #1972
I have the e4-fs and recently i bought a speed passion ver 2 motor ( 4t ) to put to the car.
The spur gear is 112 and it seems that i cant put a pinion gear lower than 25 because the motor is touching the rear belt .
Is that normal or the motor is bigger than the other motors.
Team Magic G4JS - Orion wasp .12 - Traxxas 4tec - O.S 18 tz
Team Magic E4FS - speed passion GT 2 pro - 4T ver 2 - 4.5T Ver 3
Kyosho spada 09 - Kyosho mini-z monster - Kyosho mini-z mr-02
memix is offline   Reply With Quote
Old 04-07-2009, 03:57 AM   #1973
nocif13's Avatar
Send a message via MSN to nocif13
hi memix
change the spur gear,i used 69 OR 75 in 45DP(110 IN 64DP AGAINST HOMETOWN)
best regards
olivier
teamspec/petitrc.com/TEAM WAVE/T.O.P racing/CBRacing.fr/rcmanufactory/Alien POWER/Team Terribles
nocif13 is offline   Reply With Quote
Old 04-07-2009, 08:27 AM   #1974
Super Moderator
Marcos.J's Avatar
It gives the car more foward traction. I'm going to try 1mm all around the front and rear this week and see what it does, I can't make it to the reedy race this year (running low on funds)
Old 04-07-2009, 08:32 AM   #1975
Super Moderator
Marcos.J's Avatar
Go to a 114 spur and see, with the E4's you will need an assorment of spur gears due to the limited room that you have for motor movement.
Old 04-07-2009, 08:55 AM   #1976
Rick Vessell's Avatar
If I remember correctly with the E4 we are limited to a range of teeth between 140 and 150. So if you add 112 spur and 25 pinion together you get 137 teeth total which is outside the range. You need to find your ratio within in the range of total teeth for proper motor adjustment.
Go to a 116-118 spur and then you'll be able to get the ratio you want for you 4T. I ran a 4.5 on carpet this winter geared at 116/24-25 with no fit issues.
Socko
Rick Vessell is offline   Reply With Quote
Old 04-07-2009, 10:15 AM   #1977
Super Moderator
Marcos.J's Avatar
Im sorry I forgot ,we run on asphalt and we also treat our track with soda.
Old 04-09-2009, 07:59 PM   #1978
Thanks to Jonny Socko for the reminder. This has been mentioned a few times but the thread is getting so large it is really hard to backtrack through the whole thing.
There have been a lot of questions about pulleys. Not all of it has been accurate. There are two internal ratios used on the E4s. The E4FS uses the 1.8 internal ratio and all of the others use the 2.0. The E4FS uses 34 tooth pulleys on the diffs and 18 tooth center pulleys. All the rest use 35 tooth pulleys on the diffs and 17 tooth center pulleys. All the cars use 17tooth side pulleys. Side pulleys and center pulleys are not interchangeable.
The manual has an error on the part number for the 17 tooth center pulley. The correct part numbers are as follows:
503155 35 tooth diff pulley
503201 34 tooth diff pulley
503197 17 tooth side pulley
503222 18 tooth center pulley
503236 17 tooth center pulley
There has also been a lot of talk about mixing and matching pulleys to compensate for belt stretch. We have tried this and have not had any good results.
Wolf Hobbies Your Source for Everything Team Magic Kfactory and H.A.R.D. in the USA www.wolfhobbies.com [email protected]
Wolf Hobbies is offline   Reply With Quote
Old 04-09-2009, 08:19 PM   #1979
There have been a lot of questions about pulleys. Not all of it has been accurate. There are two internal ratios used on the E4s. The E4FS uses the 1.8 internal ratio and all of the others use the 2.0. The E4FS uses 34 tooth pulleys on the diffs and 18 tooth center pulleys. All the rest use 35 tooth pulleys on the diffs and 17 tooth center pulleys. All the cars use 17 tooth side pulleys. Side pulleys and center pulleys are not interchangeable.
Umm... I think my E4 has a 35 and a 17 for a 2.0588 internal. But I didnt count the teeth on them. So please tell me Wolf, since we are running it 4.2 final its important that I know if all my small pullies are 17 teeth or not.
geez man I sure hope it is 35/17. I have the E4 C1 optimized for rubber.
Thanks in advance Wolf.
Old 04-10-2009, 01:33 AM   #1980
cvccsi is offline   Reply With Quote
team magic m1b pitdog Nitro Off-Road 447 04-30-2013 09:17 AM
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
Team Magic G4 J_Longbrake R/C Items: For Sale/Trade 0 10-07-2004 07:56 PM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
