Old 01-28-2008, 11:48 PM   #466
nocif13's Avatar
Send a message via MSN to nocif13
Team Magic E4 Thread-pc280001.jpg   Team Magic E4 Thread-pc280003.jpg   Team Magic E4 Thread-pc280005.jpg
teamspec/petitrc.com/TEAM WAVE/T.O.P racing/CBRacing.fr/rcmanufactory/Alien POWER/Team Terribles
nocif13 is offline   Reply With Quote
Old 01-29-2008, 03:41 AM   #467
bender's Avatar
In case anyone wants one - I have uploaded an interactive blank PDF set-up sheet to my website:
http://web.aanet.com.au/fir/bender/D...s/E4_blank.pdf
It's based on the foam spec car but can be used just as well on the rubber car.
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 01-30-2008, 02:17 PM   #468
Tomradio's Avatar
Trader Rating: 25 (100%+)
E4RS
http://www.teammagic.com.tw/en/profr...3003&pageNum=1
Tomradio is offline   Reply With Quote
Old 01-30-2008, 03:19 PM   #469
Jochim_18's Avatar
Is all the parts for this new version of E4 interchangable with the previous version? Seems like they realeasing an improve car every couple of months? LOL!!!
I don't even have a chance to race my car yet.
Jochim_18 is online now   Reply With Quote
Old 01-30-2008, 03:21 PM   #470
nocif13's Avatar
WHAT ARE THE DIFFERENCES BETWEEN THE E4 sedan anD E4 rs?
Old 01-30-2008, 03:28 PM   #471
Jochim_18's Avatar
They used a better grade 7075 aluminum. And it accomodate LIPO batteries. I have to modify my E4 to fit lipo. I'm just wodering if they race up the bulkheads to make the lipo fit ot if they modify the battery tray. Because on my E4 I have to shim (0.5mm) the the upper deck for my lipo to fit.
Old 01-30-2008, 03:41 PM   #472
nocif13's Avatar
ok pas interessant pour moi car le lipo n'est pas homologué en france
Old 01-30-2008, 03:42 PM   #473
nocif13's Avatar
ok
Ok not interesting to me because lipo is not approved in france
thanks
Old 01-30-2008, 03:42 PM   #474
nocif13's Avatar
ok
thanks
Old 01-31-2008, 04:28 PM   #475
Tomradio's Avatar
Has anyone run the E4FS on the rug yet? Likes, dislikes?
Old 02-02-2008, 03:26 AM   #476
Great start to the New Year
3 wins from 3 starts fastest race time and Fastest lap
PLUS NO BROKEN DRIVE SHAFTS.
I put Xray axles and Xray diff cups in the front of my car. Not sure what others used but the Xray ball is smaller than the TM ball so that is why I used Xay cups in my front one-way.
I also tried a 6 cell pack vs 5 cell and got my fastest lap time with 5 cell due to the higher corner speed that the lighter car had. Power was down a little but man did it go around corners fast!!!
Motor was a LRP 4.5
NZHobbies is offline   Reply With Quote
Old 02-03-2008, 03:40 PM   #477
Default Team Magic E4 Thread
We have received a lot of email and phone calls asking: “What is the difference between E4 models”? “Which E4 should I get”? “I race on Carpet and asphalt. Do I have to buy two different cars”? Do you have all of these in stock?
What is the difference?
The E4 is the original version. It has more machined aluminum parts than any other version, including; Aluminum pulleys, caster blocks and bottom battery door. It has a convertible (1 way independent, 1 way coupled and locked spool) quick change front 1 way and rear ball diff. This version is out of production and will never be produced again which is why we call it the Special Edition.
The E4FS (stands for Foam Spec.) has a 3mm Carbon fiber bottom deck (chassis) and a 2.5mm solid top deck. The shocks have been improved to reduce friction on the shock shaft. The steering is a single rotating arm style to increase Ackerman effect for more aggressive turn in. The battery mount area has been changed to accept most LiPo batteries without any modification. The pulleys have a deeper tooth depth and the belts are wider. It uses front and rear ball diffs.
The E4RS (stand for Rubber spec.) is like the E4FS with these exceptions; 2.5mm bottom deck and a 2 mm top deck with cut-outs. The steering is also twin parallel arm style to reduce Ackerman for a less aggressive turn in. It has a front 1 way and rear ball diff.
Which E4 should I get? Do I need separate cars for Foam and rubber tires?
First of all the E4 cars are unlike anything on the market. As an engineer and full size racecar builder I saw the advantages of centralized polar mass (putting the heavy items in the center of the car) but I had no idea it would make this big of a difference. The car is just amazing. If you like bling and are the type that is going to hop up the car with billet parts then the best kit is the E4. The bright aluminum parts and gold turnbuckles and carbon fiber chassis and steering parts make this car almost too nice to put on the track. Once you do put it on the track you will find that it is very neutral and easy to drive fast. It is also a very durable car. We let a lot of people drive it at several tracks and it took a real beating. To date we have not broken a single part on the car. It is still exactly as it was when we first put it together. After hundreds of laps it still has exactly the same readings on the setup station as it did when it was new.
The E4RS is the production version of the E4. Many of the billet pieces have been replaced with injection-molded parts which is why it costs less. The E4 Special Edition is about $30.00 more. This is less than the cost of 1 billet part. This makes the E4 Special Edition a real bargain.
The E4FS is the most versatile of the three models. The slightly thicker top and bottom decks have a weight penalty of only a few grams but they give you a stiff stable platform that removes one more tuning variable: Chassis flex. It is stiff enough for foam tires on carpet and by simply changing springs and shock oil it grips the asphalt like crazy with rubber tires too. This kit is my overall favorite electric racecar. I can get into the physics of it if someone asks but it would take a long posting that will bore a lot of people. One sweet aspect of this kit is that if the aggressive turn-in of the single arm steering does not suit your driving style, you can simply change to the twin parallel arm steering system (we have a kit with all the parts). It takes a few minutes and the holes are already in the top plate. If you insist on making the chassis more compliant we do stock the thinner E4RS top deck with the machined cut-outs. If you prefer a front 1 way or spool it just takes four screws to change either diff. This car can easily suit any race surface and any driving style preference. So the answer is no, you do not need to buy two cars.
The answer to the last question is: Yes… We have the E4 and E4FS in stock. www.wolfhobbies.com In fact we are the only source in the world for the E4FS as we purchased the entire production run. We will order E4RS cars as requested.
One other question we see a lot is: “What are the ratings on the springs in the 502134 spring kit”?
1.2mm 10lb
1.3mm 13lb
1.4mm 17lb
1.5mm 20lb
1.6mm 26lb
1.7mm 31lb
1.8mm 41lb
1.9mm 51lb
Wolf Hobbies is offline   Reply With Quote
Old 02-03-2008, 05:48 PM   #478
TeamB&B's Avatar
From an engineering point of view, the E4 design is definetly the future. Unfortunately, Team Magic distribution and support is way lacking for a global manufacturer in today's economy. No matter how great the product is. It takes millions to develop a product, package and distribute it. TM falls short on the distribution and may be loosing the US market.
1. How long will TM play around before they get the global distribution channel in place?
2. Is Wolf Hobbies the official TM importer, US distributer on record? Or just another importer until inventories run out and TM looks for another company with a promising plan and sales agenda to capture the US market.
3. If so, the TM website needs to reflect this. XRAY has RCAmerica. Losi has Horizon Hobbies. These are all long term and reliable relationships.
Now Wolf Hobbies is now on the scene. Therefore, I will patiently wait to see how this pans out.
1. Is there going to be a nationwide sales promotion?
2. Are team driver being signed to promote the brand?
3. What is the long term financial commitment to get the E4 out of the starting gate.
Team Magic needs to take some pages from the XRAY/Hudy and Much More play books.
RCAmerica / Sweep
TeamB&B is offline   Reply With Quote
Old 02-03-2008, 10:46 PM   #479
Suspended
I have worked for r/c manufactures for 12 years now and have set up thousands of new accounts for hobby shops from the distributor stand point. It looks like wolf hobbies must a made a major deal with TM and some cash behind them and some b.s. stories, because it has a P.O. Box as an address of business, that usually a sign of a business that works out of it’s house with no store front. You would never be able to open an account with these criteria in the U.S. industry today. Leave it to TM to turn time back that has hurt this industry in the past by not looking into companies and their experience before they have chosen a company to distribute their products. Does money talk with TM? It looks like that by TM selling to their so called new distributor. It looks like TM is trying to break all the rules that have been established over the last 10 years for real honest established companies or hobby shops with store fronts. If wolf hobbies are the USA sole distributor, why do you have an on-line store selling cheaper than hobby shops, get you rear out there and find shops to carry your products, not promoting your own mail order to forums. Why don’t you have dealers on your web site that customers can go too purchase product? You should be pushing customers to your dealers not your own personal company, especially when shops have been buying product from you.
Why would TM not sign with an established company or has TM burned that many bridges in the USA?
Is there any knowledge that comes with one of many new TM USA Distributors? In the past, TM has had zero dedication to its sole distributors that they have committed to, so that will never change.
The company has buried itself in my book and I have owned four TM cars in the last 4 years and I will never buy one again.
nitroballer9 is offline   Reply With Quote
Old 02-04-2008, 11:54 AM   #480
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
what's the largest lipo that the rubber spec can have?
team magic m1b pitdog Nitro Off-Road 447 04-30-2013 09:17 AM
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
Team Magic G4 J_Longbrake R/C Items: For Sale/Trade 0 10-07-2004 07:56 PM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
