STS engines
#2418
Originally Posted by jfc_tech
ooopsss... sorry, i though u were asking between .21B & .21T.
my friend said, the fuel economy the most visible fact. the rest is just almost the same. but this on buggy.
I was asking about the .21 "B" and the "E", im thinking on the "E" version (pullstart or roto) to put on a monster truck already powered by a OS .18TZ engine ...
#2419
Hi Pato, so long no talk....The difference between "B" and "E" is that the "E" has a one piece cooling head with head button, the "B" has a two piece design... cooling head and button are separate...rest is the same...just a question of economy (E)...and tuning option (you can't change to a turbo button on the "E" model...
Saludos
Alfonso
#2420
Originally Posted by skengines
Thanks Artificial, you have been of great help.
How many shim are there. I assume two, and both are of the same thickness?
#2421
is this glow plug fit D5R?
how to find a turbo glow plug that is rb/NOVAROSSI type??? that's kinda pain
thanks anyway.
Racers Edge Sure Fire #7 Medium Turbo Glow
http://www.racers-edge.com/store/cus...cat=505&page=2
thanks anyway.
#2422
Saludos
Alfonso
Saludos
Alfonso
check here for details. STS Taiwan, Home of the STS engines.
#2423
Originally Posted by Artificial-I
Os will leak , nova wont. I personally dont like os plugs cause Ive heard the wire filament when broken off can cause damage to the motor while a nova/rb plug will disintigrate causing no damage.
#2425
Can I reuse the STS air filter? Like take foam off its base, wash it, then reglue it back to base?
#2426
Has anyone here tried the d12ex with the red head? I see it is a little bit cheaper that the d3r, what is the difference between the two? I know the d3r is ifmar legal but that doesn't matter for the racing I do. The ex has a larger carb according to specs and it appears to have a carb restrictor (is this right?). So, would I be better getting the d12ex? Any suggestions would help.
Keith
Keith
#2427
EX is an economy engine. Apparantly larger carb opening makes it harder to tune down low. If the extra $ is not a deal I'd go the D3R or maybe D5R, but I have no experience with the EX version.
If you have the $$ go the D12X
http://www.stsrc.com.tw/12engines.php
#2428
Thanks, I already have a d5r and I am really happy with it. I was just looking for something that isn't as touchy on carb settings and has a little less bottom end with compairable top end. Will the d12x's carb work on the d5r and will it be any easier to tune? Also, does any one know anything about the d3r A.I. modified and is it worth the extra money?
Keith
Keith
#2429
I read earlier (in this thread I think it was) that the larger carb opening on the D5R does make it harder to tune. The D3R I had not touched the needles for a number of races. (though I have now as new pipe has been installed)
The D12X carb should be fine. Also don't forget high oil % in fuel will make it a nightmare to tune.
