STS engines
Old 11-15-2007, 02:37 AM
  #2566
speedy2's Avatar
where can I buy 3.5 buggy engines ?? on-line intern.
speedy2 is offline
Old 11-16-2007, 05:52 PM
  #2567
20 SMOKE's Avatar
Trader Rating: 102 (100%+)
look here to find some close to you http://www.stsrc.com.tw/dealers.php
20 SMOKE is offline
Old 12-05-2007, 01:09 PM
  #2568
Kemorc's Avatar
Ok, here is a pair of new engines from STS:
S21T BUGGY ENGINE (#2121)
Type : rear exhaust without pull-start
Cylinder Contents : 3.5cc
Bore : 16.68mm / Stroke:16.00mm
Crankshaft : 14mm SG type
Carburetor : 2 Needles Slide 7~9 mm
Piston / Sleeve : ABC 5P
Glow-plug : Turbo
Here is the new .12 3 port onroad engine:
IFMAR Legal .12 3port version (#1205)
Cylinder Contents : 2.1cc
Bore : 13.80mm / Stroke:14.00mm
Crankshaft : 12mm SG type
Carburetor : 3 Needles Slide 5.4mm
Piston / Sleeve : ABC 3P
Glow-plug : Turbo
Kemorc is offline
Old 12-08-2007, 10:50 PM
  #2569
hooked_on's Avatar
Are STS trying to copy GRP/Ninja now:S
hooked_on is offline
Old 12-11-2007, 09:10 PM
  #2570
Default D12EX
I need some answers from my fellow RC brothers. I blew the crank out of my D12EX and went to buy a new one. The parts listing at STS site lists a different crank that what's in mine. (at least the picture) Here is a pic of my crank, is this the same as other guys cranks in the D12EX? What is the correct part # for this crank?
lurchsum69 is offline
Old 12-22-2007, 01:53 AM
  #2571
Kemorc's Avatar
STS isn't copying anyone. Just because STS is using a different cooling head you automatically assume something? You must be fooled by a lot of product on the market then.
D12EX Crank: 120200
Kemorc is offline
Old 12-26-2007, 03:12 AM
  #2572
SH
Trader Rating: 18 (100%+)
what efra legal pipes work well with the new sts S21t engine
SH is offline
Old 12-27-2007, 04:19 AM
  #2573
KemoRC, please don't treat us as though we were born yesterday - that's a load of crap. The engines are pretty well made for the money, but there's NO denying that STS is the latest in a long line of Taiwanese engine manufacturers that try to copy other engines. STS started out with a direct rip-off of a Novarossi engine, and many subsequent models were exact copies of other engines. They may now be at a stage where their copied engines have generated enough R&D money to start and try things of their own, but it's a insult to our intelligence to claim the STS doesn't copy anything. They simply wouldn't be where they are now without the money they got by copying other engines. For the record, I think they're decent engines.
rcg33k is offline
Old 12-27-2007, 01:25 PM
  #2574
SH
umm, how is the STS a copy? i see nothing, the cooling head for one is nothing like i have seen before.
I have heard the JP4 pipe works really well with the NEW S21t...so who has tried this?
What are the improvements on the new engine exactly? sure i know the bore & stroke has changed but what else?
SH is offline
Old 12-29-2007, 03:32 AM
  #2575
jameslow's Avatar
hi guys up there, i have a few questions:
- I just got myself a new STS D12EX engine and had break in the engine. How can i know if the engine is fully break in?
- I try to lean the high end in order to get more speed... however, i only manage to get the top speed when it hit 140 degree c. (so is it normal, or the hand temp gun got problem?)
- Im using sidewinder 20% fuel right now!
- Although i have lean it, there is still quite amount of smoke come out.
- Which plug should i use? im using nova & os plug now!
Thanks a lot!
jameslow is offline
Old 12-29-2007, 11:04 PM
  #2576
CurveTracer's Avatar
1.A temp of 120 deg C should be your maximum temperature. I would recommend staying closer to 112 deg C.
I ran six tanks of fuel through the engine while slowly leaning out the HSN on my STSD3R.
2. The STS engine head button is set up for a Nova Rossi style glow plug taper.
This means RB, Nova Rossi type plugs should be used. However some users report that the OS plugs will work ok,
but once the taper is set for a certain glow plug type you may not have good sealing if you alternate between different types.
3. What type of exhaust pipe are you using?? My Ofna/Mega pipe was too restrictive and the engine did smoke a fair amount.
It had good power though. I switched to an RD logics Turbo II pipe which flowed better, less smoke and unleashed lots of power.
4. How is the engine geared??? I've been running a final drive ratio of 6.3 for first and 4.46 for second.
Hope this helps
CurveTracer is offline
Old 12-31-2007, 10:07 PM
  #2577
darkanbil's Avatar
hi all,
i'm now using 12ex engine with RD Logic pipe and Nova plug (averenge).its a good engine with a good acceleration even i put it on Kyosho RR (got 2nd B-Main on SJRC last 2 week).for now, no problem with this engine accept one:
-this engine will easy to start with only one push, but it will die if i pull the trigger quickly.if this hapend, this engine will hard to start again.i have to lean the HSN and start the engine (it will start easily).after that, i have to rich back the HSN.i think this engine cannot be start in rich mode.
what is the main problem..? (according to this symptom).
darkanbil is offline
Old 01-02-2008, 07:59 AM
  #2578
jameslow's Avatar
Originally Posted by darkanbil View Post
hi all,
Hi...Thanks for reply! im using 12ex with JPL pipe and Nova plug (hot)... agree with u that its have good acceleration. I have no problem staring my engine... very easily stared! just that i need to lean out the engine in order to get the top speed. i try lean out < 3 turn for high end needle to get the top speed.... but this also cause my engine to run at 140 degree C.
Can i check with u, what is ur high and low end needles setting? Thanks!
jameslow is offline
Old 01-03-2008, 02:16 AM
  #2579
Kemorc's Avatar
Small update:
I'm no longer selling STS engines. My distributor refuses to take in any more orders and refuses to import more engines for us to stock up and sell. The reasoning for why is unknown, but with this being said, the ONLY engine products I will now carry are to be Go Tech engines. If anyone wants a good deal on an engine, check out my site under my profile, you can snag a 3 port D28M for cheap along with the first gen D21T.
Kemorc is offline
Old 01-05-2008, 11:35 PM
  #2580
dameetz's Avatar
Glow-plug : Turbo
Glow-plug : Turbo
Is it available yet? i m particularly interested in the 12 size for touring cars. I used to race using STS D5R a few years ago and very happy with it, and I dont mind trying this new STS.
dameetz is offline
