Mugen MTX-4
Old 04-20-2006 | 04:11 PM
  #4426
GrandeGixxer's Avatar
I just got my order of 3 racing spur gears and they are all true. The ones I got are not flawed in any way. Maybe there was a bad first batch that was shipped out. The new 2 speed setup is pretty interesting as well. the first gear 1 way bearing actually rides on a steel collar so that they can use a larger bearing as well as a titanium shaft. I will take pics and let everyone know how it works when I get it mounted up. I was pretty amazed how fast I got my order from RC Mushroom. It was sent out form Hong Kong on Tuesday, and it arrived today. That is fast! Yee haw.
GrandeGixxer is offline
Old 04-20-2006 | 06:10 PM
  #4427
itchy b's Avatar
a friend of mine used the blue spur gears at the nsw titles at moorebank after stripping the original and didnt have a problem after unlike his pit buddy who stripped 5 mugen spurs, so no prizes for guessing which ones i'll be using in the future
itchy b is offline
Old 04-20-2006 | 06:14 PM
  #4428
itchy b's Avatar
Originally Posted by Scott Fisher
I asked Mike and he said he would definitely try a spool with bumpy low traction conditions.
thanks for the advice scott, i'll give it a go but a bit worried about breaking the cvd's
itchy b is offline
Old 04-20-2006 | 06:17 PM
  #4429
Joe Os's Avatar
Originally Posted by Slo-MTX4
I had no end of trouble of stripping 2d gears on this car but what i found was that the bearing in the 2nd gear housing was loose in the housing causing the gear to move out towards 1st gear leaving only a small amount of the gear on the pinion. Got a new housing where the bearing doesnt move and no more stripped gears.
What pipe you running your T03?
Joe Os is offline
Old 04-20-2006 | 06:18 PM
  #4430
Joe Os's Avatar
Originally Posted by kidDynomite
Spool is the ticket for low traction tracks. I was able to take tighter lines than the diff or one-way guys. Depending on traction, I would even try a 5k and 7k rear diff. It'll help keep the rear from coming around. Also try 40wt-50wt (400-500) shock oil. It'll help let the car roll better, thus give more traction through the turns. Also try a stiffer rear sway bar and run the front sway flat. Driving style is different, but easier to drive for those conditions. Lot-trac tracks will make a one-way car more squirley when braking at the end of the straights. Spool will help you position the car better through the turns on-power with having to do less lifting. Just remember not to hit anything. Spools do a lot of wear on the front belt, and a locked front diff means there's no give on the universals. They will be stressed on impact and may bend or snap.
If you choose to go diff, 100k up front and 5-10k in the rear works pretty good too with no worries to the universals.
What spool mean bro?
Joe Os is offline
Old 04-20-2006 | 06:26 PM
  #4431
ogreasurada's Avatar
Solid axle.
ogreasurada is offline
Old 04-20-2006 | 06:27 PM
  #4432
itchy b's Avatar
a spool is a solid diff that gives you 100% drive to both wheels 100% of the time, unless you break a cvd
itchy b is offline
Old 04-21-2006 | 04:00 AM
  #4433
asw7576's Avatar
What size of pinions and spur gears do you guys use for racing ?
asw7576 is offline
Old 04-21-2006 | 04:47 AM
  #4434
MAVICXXX's Avatar
i stil like the stock for the biggest track we hv here..but 16/22 58/54,3,2 is stil viable..
your Q bit difficult la to answer..
MAVICXXX is offline
Old 04-21-2006 | 07:18 AM
  #4435
blanks596's Avatar
question for anyone out there- I have a complete set of tuning springs for my G4, which appear to be the same diameter as the mugen's but different length. Is it possible to use these springs on my mtx-4 or will there be a problem?
blanks596 is offline
Old 04-21-2006 | 08:00 AM
  #4436
itchy b's Avatar
you can use them, just not sure what minimum ride height you will get at the front
itchy b is offline
Old 04-21-2006 | 08:01 AM
  #4437
Default Crystal Park
My oldest daughter and I are going to race the Roar OnRoad Nationals in June at Crystal park Ca. USA. Anyone out there have some experience with that track. I am interested in gears, tires, springs, shock oil and overall bite level.
jeff whiting is offline
Old 04-21-2006 | 12:25 PM
  #4438
Smile
Jeff, I will give you my set-up I ran for the toys for tots race. I didn't do very well, but my car was very fast. If I had finished a qualifier I would have been either high in the C or maybe in the B.
JP modified T03 with Mugen p1002 pipe. grey clutch shoe with light shoes and hard JP spring. set .08 preload and .01 endplay.
Stock gearing with 24t front pulley.
front: 600w stock pistons light blue springs, track at 198mm
42 shore tires cut to 61mm ride height 5, droop 1, caster centered, 1* out toe, flat roll bar, camber at 2*.
rear: 400w, stock pistons, light blue springs, 40 shore tires cut to 63mm, 1.5* toe in, roll bar off, camber links no spacers middle hole, camber at 2.5 ride height 5.5mm, droop at 5, 30,000 diff fluid. Track at 200mm
Good luck at the race, I wish I could make it out there for it. This setup should give you a good place to start out with.
Old 04-21-2006 | 02:07 PM
  #4439
Perfect that is exactly what I was looking for. I especially appreciate the clutch info.
JEFF
Old 04-21-2006 | 05:53 PM
  #4440
RAL's Avatar
RAL
If anyone needs a body...
http://www.rctech.net/forum/showthre...94#post2306694
RAL is offline
