Old 04-18-2006, 08:15 PM   #4396
Trader Rating: 44 (100%+)
Originally Posted by MAVICXXX
rear shock tower and chasis i presume..
wow .. this thread has a lot of traffic.
ALL - thanks for the info.
what's the deal with the stock dogbones?
do the pins wear out fast? or they bend easily or ..?
i would very much like to re-use the stock doggies if possible
will take note of the rear shock tower. will probably read this thread from page 1 onwards
the standard chassis has too much flex?
YOKObori MOkei
wyl03 is offline   Reply With Quote
Old 04-18-2006, 08:19 PM   #4397
Joe Os's Avatar
Anyone try the solid front axle? if so any good feedback? lol
Joe Os is offline   Reply With Quote
Old 04-18-2006, 08:27 PM   #4398
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Nothing wrong with using the stock front dogbones. I use the universals, so I will never have to go walking around the track looking for a lost dogbone.
Nothing wrong with the stock chassis either.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 04-18-2006, 08:29 PM   #4399
Chris West's Avatar
Send a message via MSN to Chris West
I prefer it over the diff i felt it had better on power steering and better braking and its lighter as well
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 04-19-2006, 12:15 AM   #4400
Motorman's Avatar
FYI
The full line of K factory MTX4 parts are available in the US now
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 04-19-2006, 12:35 AM   #4401
Originally Posted by Motorman
FYI
K-factory = good stuff.
I currently use the 2sp shaft, vented brake disk, 2nd gear oneway adapter and wheel hexes on my MTX4...... I have named it the MTX4 Scottspec
Old 04-19-2006, 04:54 AM   #4402
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Im also using the K-Factory ventilated brake disk... Only one question, is it supposed to be purple?
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 04-19-2006, 10:28 AM   #4403
itchy b's Avatar
g'day scott, im thinking about getting the kfactory (oneway,locker, spool,) combo, will this be a good thig on the car for a bumpy low grip track?
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 04-19-2006, 10:47 AM   #4404
Vinyard's Avatar
Nuthin wrong with with everything... its just personal preferences.
Universals saves time spent on searching for bones and one-way cups if encounter a knock... stock rear shock tower is fine if you dun flip and crash the wrong way..
in fact its great stock out of the box.
Vinyard is offline   Reply With Quote
Old 04-19-2006, 03:28 PM   #4405
I honestly don't know as I have never run a spool. My guess would be yes, but I will see Swauger in a few hours and ask him.
Old 04-19-2006, 05:50 PM   #4406
You get 4 wheel braking but lose a little steering. To fix the steering loss . . . turn earlier. I say it might be worth at least a good half to full day of practise to see if you like it. The 4 wheel brake is a nice feature.
I have to admit though, some of my best lap times are with the one-way.
going4#1 is offline   Reply With Quote
Old 04-19-2006, 06:03 PM   #4407
dont really get it bro..better stick to abc rather than brb?what is HOT and nuclear reactor means?
The engine runs too hot, way too hot. Typically the engine should not be going over 120C~125C but when testing the BRB, I easily exceeded 125C when I tuned the engine to race conditions. I tried all the suggestions I was given when I bought the sleeve but I still couldn't get it working the way I liked.
I'm back to ABC again with a new JP FX12 T03 I bought this year. After swapping out the standard crankshaft with the one found in the 5-port engine, the engine is fast enough. Teamed with a Kawahara manifold and muffler, the only thing lacking is better driving skill.
Old 04-19-2006, 06:15 PM   #4408
oh ya?then i should try for suwon.. flex or bent is nature of aluminium when it is construct like a chasis..but how bout the tweak?the major problem wit stock is the too flexy and tweak..
I agree. Drivability-wise there is nothing wrong with the Mugen chassis at all. Durability-wise, the standard Mugen chassis definitely lacks something. While it survives most minor accidents without incident, when you get into a major smash it definitely has a tendency to deform at lot easier than some of the other competition chassises out there. At least that's my experience. To be fair to Mugen I didn't smash 50 710s, 50 RRRs, and 50 MTX-4 and compare their stock chassises but in 3 years of on-road racing it's the weakest chassis I've had direct experience with.
Kawahara isn't indestructable but it is a lot more durable. For me it drives pretty much the same way the Mugen does, it's cheaper, and it has lasted longer without tweaking, bending, or cracking. What else would you want in a chassis?
Old 04-19-2006, 08:32 PM   #4409
MAVICXXX's Avatar
yes bro..but when it comes to race,you wil get pissed off when suddenly you cant get your droop well and found the chasis tweak!for no reason without any major collision.. well anyway,rest of it is ok and there are few so so things that i can close 1 eye..but chasis affects alot!i cant stand it..now wit kawahara same thickness but hardened..thing is,you said its cheaper while it is not here.. here is about $68 while the stock only cost me $50+
MAVICXXX is offline   Reply With Quote
Old 04-19-2006, 10:39 PM   #4410
Trader Rating: 14 (100%+)
Clutch Question:
Im running an OS .12 TZ, are you guys running a shim behind the collet on the crank?
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
