Old 04-11-2006, 10:29 PM   #4276
Originally Posted by going4#1
Tag, I'd be very interested in the results. I am thinking of giving them a try myself. I have a feeling there won't be much change in lap times but durability is important too.
Thanks in advance.
I got some of these blue spur gears in and they are off. The diamater is wrong. It has the same amount of teeth but some are bigger around and some are smaller around.
I bought 3 54tooth and they are larger then the stock ones.
The 59tooth are smaller then the stock ones.
Can't set the gear mesh!!!!!! This product sucks!!!!!!!!!!!!!!!!!!!!
Joe Maxey is online now   Reply With Quote
Old 04-11-2006, 10:48 PM   #4277
Joe Os's Avatar
Originally Posted by asw7576
Should be 21/58 (1st) 27/52 (2nd) as in mtx3 manual.
The problem of your stripping spur gear is gear selection you choose is wrong. You need to go up / down by the same rate and increment for first and second gear. Ditto with pinion gear.
Pinion gear 21 - 27 = 6 teeth differences
Spur gear 53 - 59 = 6 teeth difference. Ditto with 52 - 58 = 6.
What about my pinion gear is 21 - 29 = 8 teeth difference
spur gear is 52 - 60 = 8 teeth differences? or
spur gear 53 - 60 = 7 teeth differences?
Joe Os is offline   Reply With Quote
Old 04-11-2006, 10:52 PM   #4278
Joe Os's Avatar
Originally Posted by redsand
As Joe Os runs 21/29 (1st) & 52/60 (2nd), I have a something to mention.
His gear combinations are 21/52 (2.47) first and 29/60 (2.06) second gear.
2.47 - 2.06 = .41 , this figure is incredibly small so when the tranny shifts into 2nd gear the engine's rpm will only drop very little. (I know Surikarn used to run .45 on his mrx3).
The stock mtx3 suggests to run 21/58 (1st) (2.76) and 27/52 (2nd) (1.92). So if we do a little math for those figures, they'll be 2.76 - 1.92 = .84 ; and there'll be more engine's rpm drop during the tranny shifting.
So its that ok if i run like that?
Old 04-11-2006, 11:46 PM   #4279
asw7576's Avatar
I suggest to use longer screws like 3x10 or 3x12mm at the bottom ( use tooth pick to measure the depth ).
I never had stripping gear problem since mtx3 era. Perhaps longer screws hold the engine mounting better than 3x8mm due to heat factor.
Secondly check your gear mesh especially on the 2nd gear ( remove 1st gear first and mesh it correctly ) and try to spin it.
Third check the bearings on the main shaft. Sometimes it could damage due to high rpm and stress.
Goodluck.
Old 04-12-2006, 12:21 AM   #4280
Chris West's Avatar
Send a message via MSN to Chris West
Originally Posted by banky71
hey... I am starting to build my MTX4 and i was wondering how far do you screw in the grub screws on the front and rear arms for the lower shock mount?
about 3mm no less though
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 04-12-2006, 03:48 AM   #4281
asw7576's Avatar
Let me check my MTX3 with 22/58 and 29/52 and hear the engine's rpm drop. This Friday is public holiday and I will test it alone.
Last weekend I have race with that gear setup. It was fine but I can't hardly hear the rpm and gear shifting due to race condition.
Old 04-12-2006, 08:17 AM   #4282
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Who makes a set-up system for this car?
And where can I get one local ( People's Republic of Northern Virginia area)?
Or on-line if the Price is right!!
THX in advance!
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 04-12-2006, 09:44 AM   #4283
asw7576's Avatar
Try Hudy Professional Set Up System.
buy it from http://www.rcamerica.com/
Old 04-12-2006, 10:25 AM   #4284
THX, I'll check this out (I was hoping to get one locally if possible)...
RC Tech member #11
Old 04-12-2006, 11:35 AM   #4285
Derby Bros Racing's Avatar
i was checking the Skyline website and i saw this....
Derby Bros Racing is offline   Reply With Quote
Old 04-12-2006, 11:42 AM   #4286
YBSLOW's Avatar
Pipe looks good...............
I use several skyline hopus on my 4 as well.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 04-12-2006, 03:49 PM   #4287
Corse-R's Avatar
Originally Posted by FF25510
I'm very interested in .12. hope will arrived here next week.
I was quite interested too about those little ninjas. Got pissed of waiting and had a great price for a pair of Sirios T3-E STI (Blueprinted ones). This weekend I'll break-in one of those little puppies and will see how perform.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 04-12-2006, 03:52 PM   #4288
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
I dont doubt the sirio's performance... What I do doubt is their durability....
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 04-12-2006, 03:57 PM   #4289
Corse-R's Avatar
ignore this.
Cheers,
Corse-R
Old 04-12-2006, 04:08 PM   #4290
Corse-R's Avatar
Got some previous experience with the 'stock' T3-E and their perf was simply stellar. They needed very little work to stand-up with 'teorically higher breeded' engines like JP's and others. The Sti's looks much better (honest, just opened one of those and are really incredible).
Forget about the nightmare of the Evo2 cranks. Is a matter of the past and at least the Spanish distributor stands up with the product and exchanged them without questions.
Cheers,
Corse-R
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
