Mugen MTX-4
#2626
Originally Posted by moot
has anyone tried the optional rubber belts?
Does Mugen say anywhere what they are supposed to do better than the other belts or if the last longer?
#2628
just finished building my MTX4 and the side pulley belt seems pretty loose, to have a reasonable amount of tension it has only 10mm gap between the two belts at the belt tensioner. Does this seem right?? I am using the 24 tooth pulley
#2630
hey guys i found my rear shock tower is bent
anyone else found this? i bought a second rear tower to make a double tower and the second one is not bent. i have the early model mtx4's package date;
"05-sept-26 13:19:12"
also is there anywhere i can get a full range of mtx4 hop ups?? i like the mono stuff and visited a site ChookGB posted here previously but i find their prices a bit steep. also any brands making stuff out of 7075 alloy? not 6061.
thanks
anyone else found this? i bought a second rear tower to make a double tower and the second one is not bent. i have the early model mtx4's package date;"05-sept-26 13:19:12"
thanks
#2632
Originally Posted by Breakin2
What kind of engine does this kit require, in terms of shafts. Is it a threaded shaft or pilot shaft?
Thanks.
Thanks.
it is the SG shaft. the one that does not require a end attached to it. ie: NOT the shaft with a thread front tip to case
#2633
thanks
thanks
Skyline carries full range of upgrade from mono: http://www.skylinercracing.com/store/c_31.htm and you get free shipping with a $50+ order. Not sure if they use 7075 alloy but from most people experience so far the quality is very good. You can also find bunch of upgrades from different brands for the MTX4 on ebay. Hope this helps and good luck.
#2634
I noticed the same thing after the first race I ran. The carbon is from componet grade fiber. As for other hop-ups. I took the time to do a lot of them to mine (built my own) and bought some. The only thing I would sugest is the light-wieht 2 speed shaft. I had my car so light from hop-ups that I had to put 57cents in the car to get weight after removing the titanium screws and hinge pins. And with a worn set of tires, I was still at 1726grams.
#2636
hey guys
just finish building my mtx-4 it last me 2 weeks to build the car and never have the problem you guys having.......just order my skyline one pc pipe
but just find out that changing the front oneway to a diff is a pain
they said only 4 screws hell no so anybody knows how to put the diff in their the easyway
thanks
they said only 4 screws hell no so anybody knows how to put the diff in their the easywaythanks
i hate snow
