Old 04-03-2006, 04:02 PM   #4126
ogreasurada's Avatar
Originally Posted by gonzo416
anyone know if there are aluminum wheel hexes with the 1mm offset in them so you don't have to use spacers?
I have 0 offset wheels on my car without spacer and don't see any problem.
ogreasurada is offline   Reply With Quote
Old 04-03-2006, 04:06 PM   #4127
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
I was running 0 degree offset rims on my car before with dogbones and I was kicking them out like it was cool. If you are going to run them, run CVD's or put spacers on the axles. It isn't too much fun chacing dogbones and outdrives around the track.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 04-03-2006, 05:10 PM   #4128
typer's Avatar
Originally Posted by GrandeGixxer
I have not seen any. I guess that doesn't mean they don't exsist.
use kawahara
typer is offline   Reply With Quote
Old 04-03-2006, 05:33 PM   #4129
racer x 1's Avatar
Trader Rating: 27 (100%+)
the nija 12 is on its way but not next week
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 04-03-2006, 07:38 PM   #4130
Almost ready for the summer!
Joe Cude
Old 04-03-2006, 07:39 PM   #4131
gonzo416's Avatar
Trader Rating: 39 (98%+)
no spacers and the rims are too close to the c-hubs and they will break like the electric t2
gonzo416 is offline   Reply With Quote
Old 04-03-2006, 07:41 PM   #4132
kartermdb's Avatar
where do you guys put your switch, or do you even run one?
thanks in advance
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 04-03-2006, 07:45 PM   #4133
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
thanks in advance
As of yesterday... I will never run a switch. I will run the battery directly into the reciever and this is the why... My car's battery disconnected from the extension cord at full throttle and went against a track barrier at about a 45 degree angle. I broke that side's lower and upper arm, Skyline Aluminum Arm Holder, Front (left side) bulkhead, foam bumper, and many things I cannot even remember. I did not hit anything during the qualify and was running an almost perfect race until this little mishap that had to happen when I went wider for better traction.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 04-03-2006, 07:47 PM   #4134
kartermdb's Avatar
alright, good to know, it saves me $10 when i go to finish the electronics
sorry to hear about your car, i just purchased mine and havent bought a motor yet, still debating
Mark Burt
Thanks to:
Old 04-03-2006, 07:51 PM   #4135
Riketsu's Avatar
Yeah, yesterday wasnt my day. It just ended good when I won the outlaw and got 2nd in main B. Both races were awesome because were under rainy conditions. You had some part of the track that you had to drift then another part of the track that you were able to race normally. Then had to watch out if it rained some more to take it slower.
I'd suggest you get a stock TZ. It can be as fast as any other engine out there (unless you set the 2nd speed wrong like I did during qualifiers). Found myself running the beginning of the straight on 2nd gear with little power.
The TZ is a very good engine, it survived 10 minutes in 1st gear during my outlaw main. I checked the bearings, conrod, sleeve/piston and everything seems alright.
Old 04-03-2006, 09:00 PM   #4136
AMGRacer's Avatar
Originally Posted by Chris West
are you using the mugen clutch in your R40?
Yep sure am. Not because the HPI clutch is particularly bad, but because the Mugen clutch is good, parts are available, and heaps more setup options.
AMGRacer is offline   Reply With Quote
Old 04-03-2006, 09:37 PM   #4137
kidDynomite's Avatar
Originally Posted by Vinyard
Look at what just arrived at my LHS.
Can't wait to try that motor. There's just something about Ninja's wearing nice Italian suits that intrigue me.
kidDynomite is offline   Reply With Quote
Old 04-03-2006, 09:56 PM   #4138
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
thanks in advance
I do use a switch, and mount it in the stock location using the mounting plastic that came with the kit. If you eliminate the switch, all you are doing is saving your self from either the switch getting turned off during a crash and the headache of eventually the switch will go bad. If you eliminate your switch, you will have to either plug some sort of extension into your receiver to go to the battery, or leave the receiver cover off so you can get to the receiver every time. Many of the team drivers do not put the cover over their receiver, but I always use it.
When I need to buy a switch, I go through a lot of them to find one that is hard to move. This helps prevent the switch from moving during a hard impact, and so far it hasn't happened since I started being picky about the swtich tension. One time I did have an extension go bad on a gas truck that caused me to lose power. After that, I would buy a switch, open the thing up and put a longer set of wires on so I did not need an extension.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 04-03-2006, 10:24 PM   #4139
richey's Avatar
Send a message via MSN to richey
This is the latest from K-factory all for about $6
Silver Bowl Raceway Operator
www.TeamTaylorRacing.net
Byron's Fuel, Airtronics
JoshStevensFoundation.org
richey is offline   Reply With Quote
Old 04-03-2006, 11:02 PM   #4140
asw7576's Avatar
What happen to engines when I use very low gear ratio way over the manual ? ( aka to gain more top speed because the track is 80 meter long straight ). The engine is long stroke novarossi LL5
This is from 7.489 to 6.062 ( 1st gear ) and from 4.973 to 4.235 ( 2nd gear )
* I'm concern with 1st gear more, going from 7.4 to 6.0 *
This is for upcoming sunday race, April 9.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
