Old 12-14-2005, 02:20 AM   #2626
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by moot
has anyone tried the optional rubber belts?
Yeah, I was wondering about those too.
Does Mugen say anywhere what they are supposed to do better than the other belts or if the last longer?
stefan is offline   Reply With Quote
Old 12-14-2005, 02:22 AM   #2627
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I am running the rubber belts. I've noticed that they stretch more, wear is about the same, and other than that, I've got 10 races on the side belt and it now needs to be replaced.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 12-14-2005, 02:48 AM   #2628
just finished building my MTX4 and the side pulley belt seems pretty loose, to have a reasonable amount of tension it has only 10mm gap between the two belts at the belt tensioner. Does this seem right?? I am using the 24 tooth pulley
josh_c is offline   Reply With Quote
Old 12-14-2005, 05:04 AM   #2629
rcfoolz's Avatar
yes, it does run loose. Take the cam for the belt tensioner and flip it over so the pin is on the top. that will give you a little bit more tension. I run mine like this.
Old 12-14-2005, 05:37 AM   #2630
VenomWorldOrder's Avatar
hey guys i found my rear shock tower is bent anyone else found this? i bought a second rear tower to make a double tower and the second one is not bent. i have the early model mtx4's package date;
"05-sept-26 13:19:12"
also is there anywhere i can get a full range of mtx4 hop ups?? i like the mono stuff and visited a site ChookGB posted here previously but i find their prices a bit steep. also any brands making stuff out of 7075 alloy? not 6061.
thanks
VenomWorldOrder is offline   Reply With Quote
Old 12-14-2005, 06:43 AM   #2631
Trader Rating: 38 (100%+)
What kind of engine does this kit require, in terms of shafts. Is it a threaded shaft or pilot shaft?
Thanks.
Breakin2 is offline   Reply With Quote
Old 12-14-2005, 07:18 AM   #2632
Thanks.
it is the SG shaft. the one that does not require a end attached to it. ie: NOT the shaft with a thread front tip to case
Old 12-14-2005, 07:59 AM   #2633
ogreasurada's Avatar
thanks
For the tower, you can contact gonad on this forum for his 4mm CF tower, it vitally has no flex and it has 1.5mm recess for the mounting so you dont need extra shims to mount the shocks. Double stock shock tower may seem to work, but actually they cant really hold the stress together since they are not in one-piece.
Skyline carries full range of upgrade from mono: http://www.skylinercracing.com/store/c_31.htm and you get free shipping with a $50+ order. Not sure if they use 7075 alloy but from most people experience so far the quality is very good. You can also find bunch of upgrades from different brands for the MTX4 on ebay. Hope this helps and good luck.
ogreasurada is offline   Reply With Quote
Old 12-14-2005, 08:14 AM   #2634
rcfoolz's Avatar
I noticed the same thing after the first race I ran. The carbon is from componet grade fiber. As for other hop-ups. I took the time to do a lot of them to mine (built my own) and bought some. The only thing I would sugest is the light-wieht 2 speed shaft. I had my car so light from hop-ups that I had to put 57cents in the car to get weight after removing the titanium screws and hinge pins. And with a worn set of tires, I was still at 1726grams.
Old 12-14-2005, 08:26 AM   #2635
VenomWorldOrder - thanks, that's what I was looking for. Is the LRP .12 engine a good choice? It's $189 at Tower after their code discount.
Old 12-14-2005, 02:52 PM   #2636
dg8one's Avatar
Default MTX-4
hey guys
just finish building my mtx-4 it last me 2 weeks to build the car and never have the problem you guys having.......just order my skyline one pc pipe
but just find out that changing the front oneway to a diff is a pain they said only 4 screws hell no so anybody knows how to put the diff in their the easyway
thanks
Member of the CHEATERS CLUB
TEAM KAMIKAZE(MARYLAND CHAPTER)
TOKWA'T BABOY LTD
dg8one is offline   Reply With Quote
Old 12-14-2005, 03:08 PM   #2637
dg8one's Avatar
here's mine with my theme body
TOKWA'T BABOY LTD
Old 12-14-2005, 03:11 PM   #2638
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
Nice lookin car Dg8one. Have you ran the TZ yet? I have not seen one run that l know of. l have heard they are fast though. Get that body mounted and get to the track.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 12-14-2005, 03:17 PM   #2639
Your body looks SHARP.
Have fun with the car.
Old 12-14-2005, 03:42 PM   #2640
dg8one's Avatar
cant run the car till winternats in FL so i'll find out when i get there
its too cold i hate snow
TOKWA'T BABOY LTD
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
