Motor Testing and Comparisons
#376
I dont see it being a motor of the month. Its the exact rules they have always used in every country except the US and they dont have motor of the month battles.
It will allow more motor manufactuers to get into the 25.5 motors as they will now use same stators as 13.5, 17,5, 21,5, etc.
EA
EA
Did you really mean stator? The stator is the main thing that changes between the turns.
#377
But all manufactuers, to my knowledge, use the same stator across all their spec winds except 25.5 and most just dont participate in that class due to it being different.
Even with all the new motors over the past 4 years I am still running the original R1 super short motors I got when they came out. Thats not motor of the month unless you just buy everything to see if other stuff is faster. I just wait till someone passes me before I buy something new!
EA
#378
Good news!
I teamed up with WMHRacing.com where you can now go to view my motor review and The Jerry spreadsheets. To the site and scroll down to the bottom. Or click on these links.We are still looking to do some more tweaks.
#379
EA
EA
If you run R1 or Hobbywing spec motors, there is no motor of the month. Both my best 21.5's (R1-HD and a HW G4R) are over a year old each. Both are still turning track record lap times if I do my part.
FYI, I time both my motors to whatever it takes to pull 5A on a fresh 2s pack. I gear them to just below 200 deg internal temps and watch my peak RPM's and lap times to confirm the gearing is right. I shoot for the highest numerical gear ratio that gives me consistent, fast lap times. The R1 and HW do require different ratios to go the same speed.
#380
EA
EA
#382
From what I have experienced, the "motor-of-the-month" was mostly based on what motor won the Worlds and/or is winning at the track. Not much data was available except the phrase "this motor is faster because it's what all our top racers use." So, that would make sense why racers would jump around? Heck, I bought a Reedy motor because the shop said it was one of the fastest motors. Yeah... it really wasn't, and I found out the hard way.
#384
#385
"8.4.2.1 All motors used in ROAR competition must be on the list of approved brushless motors posted on the ROAR website. Instructions and requirements for submitting motors for approval can be found on the ROAR website. Motor approvals shall be valid for 4 years from date of approval. Manufacturers can renew an approval for motors still in production for no additional fee or inspection for an additional 4 years."
And again, new motors may be submitted at any time. This means if company A has the lowest IR and resulting "fastest" motor out in the field and company B comes along and gets a lower IR and "faster" motor approved, company A can then immediately submit a newer, lower-IR motor to keep up with or perform better than company B's motor. Company C then comes along and drops a motor that out does both company A and Company B's motors and you can see how the cycle of the next got-to-have fastest spec motor goes.
#386
#387
This is more of what I was hinting at. Which if it happens, I'm afraid it will turn into the motor of the month and who has the deepest pockets. Lets hope not, but the writing seems to be on the wall. IMHO, it should be a once a year approval in October with an approval date for use on January 1st of the following year.
I don't believe motor manufacturers will be updating motors more than once a year. The only company I have see change a motor in less than a year was Hobbywing and Trinity. Fantom changed the Helix after a year, but most will wait at least 2-3 years before dropping a new motor design. It costs a lot of money to change them out too fast, but if people are willing to drop over $150 on a motor, then I guess yearly motor designs will be a thing. However, motors are not like RC cars. There is only so much you can do to a motor to make it better. You can drop internal resistance to ridiculous levels, but then your talking about using rare metals and a $500 motor.
With motors reaching $200, I wouldn't doubt ROAR coming out with a maximum motor price, just like the brushed motor stock class, way back in the day. However, there are $120 motors that will keep up with a $180 motor.
#388
Who do you think lobbied ROAR to get rid of the blanket minimum IR rule and why did they do it?
#389
I think the ROAR did see that while doing tests in the field. On my club there was also a guy who did rewinding motors. By rounding the edges, using a much thinner isolation and a tight hand winding he ended up with a much shorter wire lowering the resistance. And keep in mind the purity of the copper also plays a role.
#390
I was not into RC when the ROAR brushless motor rules came around. I just recently got into testing brushless motors a couple years ago.
533Likes
