Like Tree352Likes
NOVAROSSI Engine thread....
Old 05-23-2020 | 07:16 PM
  #10591
Winner's Circle's Avatar
Originally Posted by HaulinBass
got the mephisto gt5 fully broken in, shes ALOT of motor.IMO nova should throw a rubber bearing in it and sell it as the high end "truck" motor choice alongside the 4 port mephisto(buggy). even with a hipex 2108/50mm header it was pulling some serious rpms while still feeling snappy
I ran my Murnan GT5 today and it is indeed a LOT of motor. It is a great buggy engine.
Winner's Circle is offline
Old 05-24-2020 | 02:02 AM
  #10592
You can say it is a great buggy engine but you are talking about a Murnan modified which may not be compared with the normal engine although even then I would expect it is a good engine.
Roelof is offline
Old 05-24-2020 | 10:15 PM
  #10593
HaulinBass's Avatar
ran another 1/2 gallon through the mephisto gt5 in my truggy around the track today. loving it so far didnt get any timed tests as i was learning the track but im rather happy for something I bought for no reason other than i was interested in how it would do.
liked the 2095 low noise on my "full monty" mantra in buggy, but broke my fuel tank driving stupid
HaulinBass is offline
Old 05-25-2020 | 11:08 AM
  #10594
egobrkr's Avatar
Any video of you running with this engine?
egobrkr is offline
Old 05-25-2020 | 04:42 PM
  #10595
HaulinBass's Avatar
hopefully i can make it back out this weekend and get some footage
Old 05-26-2020 | 04:17 PM
  #10596
allaboutwho02's Avatar
Whats the best plug to run in a Bonito? Can a person run a OS p4? Or is it better to stick with the NOV cto 6?
allaboutwho02 is offline
Old 05-27-2020 | 04:02 AM
  #10597
If you can easily buy Novarossi CTO6 I would recommend it for the Nova engines.. I never runned os plugs in my novas, i only run the cto6 and they tune great, last forever and I know they fit perfect..
If you watch closely the os plugs are a little bit different in shape. In my opinion use what was designed to.
Chad Millikan likes this.
GeorgeCk is offline
Old 05-27-2020 | 04:09 AM
  #10598
IIRC the issue was going back and forth. I.e. if you start with OS maybe it's OK, but then you have to stay with OS plugs. You can't go back and forth or you'll screw up the button... I'd go with a Nova #6 as advised above..
Herrsavage is offline
Old 05-27-2020 | 04:10 AM
  #10599
I want to update about pipes..
I was running my virtus.21 with the 9901ss/41032, good power, good mileage, good bottom and top and temps at 284F.
The past weekend I runned the 9886ss which I cerakoted with the 41031 manifold. I tunned with the 9901ss/41032 runned it and swapped it on site with the 9886ss/41031.. The difference was massive.. I also richened tha hsn about 4 hours and had more power with temps at 260F.
I runned those compos and both of the seem close in performance but never back to back with each other.
Performance wise 9886ss/41031 is a bomb, temps are better but mileage is worse than 9901ss/41032 but I don't really care about mileage so I am keeping the 9886ss/41031 for now on on every nova I run..
GeorgeCk is offline
Old 05-31-2020 | 04:09 AM
  #10600
Default Rolling fuel milage
Recently bought a mito 4 and a rolling . Love the mito 4 but not fast enough. The rolling has the speed but the fuel milage is aweful. Cant even get 6 minutes. Using a 9901 pipe on both. Any suggestions? Is there another motor that has the speed if the rolling but better fuel economy ? Mephisto?
rythby is offline
Old 05-31-2020 | 04:52 AM
  #10601
egobrkr's Avatar
I have 2 rollings. 1 for truggy and one for buggy. 7mm Venturi in truggy and 6.5mm Venturi in buggy with 021 header and 9853 pipe on both. I can go 10min pit stops in a race almost every time. I noticed on the rolling that I was able the lean out the LSN more then some of the other engines I have tuned.
Winner's Circle likes this.
egobrkr is offline
Old 05-31-2020 | 05:09 AM
  #10602
wow! That's amazing. Do you have a measurement on your carb settings? I must be way off
rythby is offline
Old 05-31-2020 | 10:54 AM
  #10603
egobrkr's Avatar
HSN is .20 in from flush. LSN .92 in from flush .06 in from flush on mid needle
egobrkr is offline
Old 05-31-2020 | 02:35 PM
  #10604
HaulinBass's Avatar
smoked the clutch when i got hung up earlier in the day but mine is the orange truck with white on the front, Black one with orange is jeremy litke probably the fastest guy in western canada hes running a spec 3 nitro shop modded motor
houston full monty mantra
was pretty tired, drove 4 hours one way to club race after spending the previous two days moving and made tons of dumb mistakes turning too early and such
Galatians2 20 likes this.
Old 05-31-2020 | 06:40 PM
  #10605
Galatians2 20's Avatar
You are definitely really rich on that rolling. I’m running a 7mm Venturi with the 41031 header and an old ofna 053 and still got over 10mins in truggy and believe I can lean out about another hour or two.
Galatians2 20 is offline
