Tamiya TT02 Thread
#1698
Ran my TT02 S on carpet for the first time this week.....what a pig. While I drove it to second place, it was the hardest I've ever had to drive that car. It pushed hard in corners, the lack of sway bars was very evident in the high speed corners. I think I've come up with a solution that will allow me to mount sway bars (I'll post it if it works)
#1699
This was my set up in usgt for carpet
Ride height 5
Droop - 2,5 over ride height in front and 1,5 in rear
Camber - 1,5º all around
Front toe - 1,0º toe out
Dampers TRF419 big bores
Shocks Muchmore 400 wt
Springs Muchmore X springs Red front (firm) Pink rear (medium)
Diff - Front epoxied / locked, Rear 10k (using my diff mod in this post R/C Tech Forums - View Single Post - Tamiya TT02 Thread
Car was extremely competitive. I stopped running it because of the rear portion of chassis breaking when rear axle stud would catch a pipe and break... I even broke the hardened chassis this way..
Ride height 5
#1700
That's almost a mirror copy of my setup. I'm running a ball diff in the rear, locked in the front.
The only major difference is dampers. I'm running TRF black coated with stiff front springs and med rear springs.
This was on grey CRC carpet with SXT 3.0 sauce on Gravity USGT tires
#1701
thanks you thats great info, realy appreciate it. I rebuilt the shocks last night (mini CVA) with a some orings to reduce my droop, im still not down to 5mm ride hight so when the springs arrive ill try the medium rear and see if that gets me where i need to be. i rebuilt with a 35wt oil with the 1 hole piston. I have around -1.5 up front -2 in the rear with unknown toe, im guessing at around 1deg. also running heavy oil in the front diff, this did help last week. thanks again for the info, ill see how this setup works :-)
thanks again.
thanks again.
#1702
Got a box stock TT02 for my son to run at TCS events in novice. Car ran fine in practice on black carpet. First qualifier got some traction roll, so between quals I super glued sidewalls. Second qualifier car ran great when making left hand turns but would spin out on right hand turns. Could not find anything mechanically wrong with the car, looked at diffs, dogbones, etc...nothing-even tried different tires with same result. In final car did same thing. Got home and still can not find anything wrong with car. HELP! WHAT IS GOING ON? THX
#1703
#1706
#1707
#1708
#1709
No testing this week. Damn weather. Question on motors now.
Im running a sport tuned which is about the pace we all run. Id likento go brushless for increaded run time not more speed. Would a 17.5t be roughly in the same region as the sport tuned but give increased run time?
#1710
I think a 17.5t motor would be much faster than the sport tuned.
1387Likes
