Like Tree3Likes
Tamiya TRF415
Old 06-28-2013 | 02:54 AM
  #21076
Burlap's Avatar
Thank you all for the tips, I'll try them out over the weekend!
Burlap is offline
Old 06-28-2013 | 07:19 AM
  #21077
I have some base settings I use on my lads 415 here
http://www.thercracer.com/p/community.html
Qatmix is offline
Old 06-28-2013 | 11:48 PM
  #21078
Burlap's Avatar
All,
Did some adjustments today and followed most of the information here, especially in regards to springs, sway bars and camber/toe adjustments.
The car seems to be a lot less tail happy now, and seems to have more bite in the front end as well. Will see how it goes at my Wednesday night racing. Thanks once again for all the tips.
Originally Posted by addicted2blue
What suspension mounts are you using in front and what kind of suspension arms?
Sorry I missed this. With the front blocks I am running 1E and 1D. I am using the Evo V/416/417 arms on it instead of the 415 LW, as I have found them to be much stronger.
Burlap is offline
Old 06-16-2014 | 03:30 AM
  #21079
This has probly been covered before but can you use 416 centre pulley setup on 415msx?
Thinking specifically one way set 49492. And if you swap to gear diff (417 type 2) and spool why can't you use 416/7 belts?
Adsmotron is offline
  #21080
Also does anyone know a good place to get lipo battery stays to suit 415 chassis. I'm not afraid of a drill or dremel
Old 06-16-2014 | 05:09 AM
  #21081
http://www.thercracer.com/2012/02/tr...gear-diff.html
I changed a 415 to have the same pulley teeth count as the TRF417 here.
Qatmix is offline
Old 06-16-2014 | 05:48 AM
  #21082
Thanks qatmix, great article have read.
Perhaps what I should of said was if you run the spool and diff from the later model what is stopping you using the centre shaft with the central spur from it also? As per kit 49492?
Old 06-16-2014 | 06:01 AM
  #21083
I need to check, but the centre part on the 416 is too narrow. This is only really important if you want to use the centre one ways, if just making a pulley the std 415msx part with the updated pulleys gives the same effect.
Qatmix is offline
Old 07-31-2014 | 05:02 AM
  #21084
Hey fellas i have a brand new TRF415MS and 415MSX for sale as well as a RC TB EVOLUTION 3 SURIKARN LIMITED EDI how do i advertise them on here im new to this site any help would be appreciated cheers
DREWS is offline
Old 07-31-2014 | 05:10 AM
  #21085
You need to go to the R/C Items for sale/trade section.
addicted2blue is offline
Old 05-30-2015 | 02:56 PM
  #21086
I am running a TRF415 MS and just changed my front spool and rear gear diff from 36T to 37T. Will the original drive belt work or do I need to get a bigger drive belt. If so, how many teeth does the drive belt need to be?
Thanks!
looklikeaflip is offline
Old 03-04-2016 | 06:58 AM
  #21087
JoJo1241's Avatar
Hello, i am looking for a Tamiya TRF 415 MSXX model 49419
It has to be in good shape.
I have posted this also on the buy/ sell thread, but i am hoping someone will read it here also.
Greetings, Joop Voorn.
JoJo1241 is offline
Old 03-05-2016 | 02:14 AM
  #21088
JoJo1241's Avatar
anyone?
JoJo1241 is offline
Old 03-08-2016 | 09:13 AM
  #21089
JoJo1241's Avatar
anyone?
anyone?
JoJo1241 is offline
Old 03-08-2016 | 10:13 AM
  #21090
anyone?
Are you collecting the whole car or just need the parts?
eComet is offline
