Like Tree3Likes
Tamiya TRF415
Old 03-08-2016 | 01:32 PM
  #21091
JimmyMac's Avatar
I only have a 415MSX Marc Rheinard Edition. Not the 49419. But is has the MSXX top deck on it and it's been run on asphalt a lot. Sorry.
JimmyMac is offline
Old 03-08-2016 | 02:31 PM
  #21092
JoJo1241's Avatar
Originally Posted by eComet
Are you collecting the whole car or just need the parts?
The whole car if possible.
JoJo1241 is offline
Old 03-09-2016 | 10:56 PM
  #21093
JoJo1241's Avatar
Hello, witch parts do you have?
Greetings, Joop.
JoJo1241 is offline
Old 03-09-2016 | 10:59 PM
  #21094
Suspended
Greetings, Joop.
I just finished restoring a brand new TRF415MSXX MRE. List what you need and I'll see if I have the parts.
eComet is offline
Old 03-10-2016 | 11:02 AM
  #21095
JoJo1241's Avatar
I can buy a new MSXX MRE, but that is not what i really want.
I would like to get my hands on a normal TRF415MSXX, the 49419.
greetings, Joop Voorn.
JoJo1241 is offline
Old 08-15-2018 | 12:26 AM
  #21096
nickcza's Avatar
It's been almost 2 years since the last post in here, hope I don't get lashed for reviving it... I'm considering getting back into touring car racing, and I pulled out my old TRF415MS which has been sitting in the cupboard for 12 years. The chassis is still 100%, but it is missing the front drive belt. So my question is, is it worth getting a belt (if possible) and fitting brushless, a lipo, etc. and racing it? Or should it be relegated to a show piece? Does anyone know a good online place to get discontinued Tamiya parts such as the drive belts?
nickcza is offline
Old 08-15-2018 | 12:55 AM
  #21097
I really like the idea of running classic cars. But.. I'd clean that up and make it a shelf queen.
The drive belts are "standard" parts, and can be bought from many, many sources. You can even get "better" belts than came from the factory.
You'll need to do some work, how to find other repair parts for the TRF415.
The TRF415 is also a stiffer and higher CG car, if your local courses are high traction, you're going to be fighting an uphill battle. The stiffness is also going to give you trouble versus the more flexible chassis at low traction tracks.
It's worth noting, there are a bunch of ~very cheap~, and ~very good~ chassis on the market. $200 could get you a quite a car to throw your electronics in. With the benefit of not needing to worry about parts availability.
nickcza likes this.
Nerobro is offline
  #21098
disaster999's Avatar
Regional Moderator
At this point I would shelf the car and keep it as a collectible item. I wouldnt even begin to mention about the competitivity of the chassis since how you set the car and how you drives dictates more than anything, but the availability of parts of this car is a huge concern. One crash is the difference between still having this car to look at and hold and a pile of scrap carbon and metal.
nickcza likes this.
disaster999 is online now
Old 08-15-2018 | 01:19 AM
  #21099
nickcza's Avatar
Thanks, makes sense, I'll still need to find some belts even if I make it a show piece. Haven't had much luck with that yet.
nickcza is offline
Old 08-15-2018 | 01:15 PM
  #21100
sosidge's Avatar
If you can work out the length of the belt (normally printed on the belt), you may well be able to find a replacement from another car, even if the Tamiya belt is no longer available.
I'd back up the "shelf queen" route - biggest issue is going to be that the 415 was never designed around LiPOs and you probably won't get a LiPo in there without major modifications. Not worth doing. I haven't looked on eBay but you might find that a clean 415 is becoming collectable.
sosidge is offline
Old 08-15-2018 | 02:38 PM
  #21101
The ol 415MS had the older higher bulkheads so clearance for a lipo shouldn't be a problem but don't quote me on that. It wasn't until the 415MSX version did the bulkheads become an issue.
The 415 may not be competitive compared to the current gen cars but you can still run it a slower class like VTA.
littleZEN is offline
Old 08-17-2018 | 12:34 AM
  #21102
Yep the 415ms is fine for lipo fitment. You can quite easily run the 415. Most spares are available and the hard chassis is quite useable on high grip carpet. It’s wont be as refined as the newer cars but it’s competent enough for club racing.
Here is one I modified recently to win a TRF championship a few years ago.
https://www.thercracer.com/2016/05/t...-spec.html?m=0
Qatmix is offline
Old 08-17-2018 | 01:21 AM
  #21103
nickcza's Avatar
Thank you, this looks very promising! The only issue I have is I can only go online to get the spares I need, where I live there is nothing available. I haven't been able to find much, other than the odd part here and there on eBay. Those nylon centre pulleys look like a much better idea than the alloy ones that came in the kit, especially for wear.
nickcza is offline
Old 09-07-2019 | 11:35 PM
  #21104
Speed Chaser's Avatar
Quick question what was the difference between the TRF415MSXX(49419) and the Tamiya TRF415MSXX Mark Rheinard Edition(42104)? Been considering added a 415 to my collection for some time now but cant desiced on all the different variants of the chassis.
Speed Chaser is offline
Old 09-08-2019 | 06:28 AM
  #21105
https://www.tamiya.com/english/rc/manuals.htm
the manuals will tell you the difference. But the 415ms was faster around the track
Juan Aveytia is offline
