Old 03-18-2011, 12:26 AM   #20941
Blueman Austria's Avatar
Originally Posted by gsxr0311 View Post
thanks for the reply. i have the 415msx
So you alreafy have the reversible suspension with the 950 knuckles.
If you want to use the short arms, it is a direct fit.
The only thing you have to mention is that you widen the suspension blocks.
I gone from Front B-A to D-C, and rear XB-D to XA-E.
Greetings Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 03-18-2011, 12:58 AM   #20942
Parts needed for the Spec R Gear diff modd:
HB70738 HB Cyclone 169T Belt
305444 Xray 3x183mm (61T) Belt
53989 Tam. 18T Center Pulley
54023 Tam. 37T One Way Pulley (to fit the spool or oneway)
3454395 Tam. Direct Center Shaft
A Spec R 37T Tamiya 416 Diff of course.
The rest are aprox 10 pics 0,3mm shims.
Thats all.
Greetings Blueman
Old 03-18-2011, 03:48 AM   #20943
Default Questions about 53807
Are the 53807 aluminum uprights fit in the 415MS?
If so, do you recommend upgrading from plastic?
I'm spare part shopping at the moment...
looklikeaflip is offline   Reply With Quote
Old 03-18-2011, 03:53 AM   #20944
nvm, different bulkheads so im guessing no.
Old 03-18-2011, 07:44 AM   #20945
Yes this is a direct replacement, but they have 0 toe in, and the standard plastic ones 1 toe in.
There are also 1 toe in versions available.
Greetings Blueman
Old 03-18-2011, 08:23 AM   #20946
gsxr0311's Avatar
Trader Rating: 19 (100%+)
Thats all.
Greetings Blueman
thanks so much. i already switched to the tamiya front and center spool so this upgrade wont cost me that much.
Special Thanks to: RC Target, Ko Propo USA, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. IGT8. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 03-18-2011, 08:57 AM   #20947
gsxr0311's Avatar
here is a pic.
Old 03-18-2011, 06:21 PM   #20948
Thanks blueman.
Do you recommend aluminum over plastic for rear uprights?
Old 03-19-2011, 12:38 AM   #20949
Thats all.
Greetings Blueman
One thing i forget!
54077 Tamiya LW 44mm Swing Shaft.
The 46 mm are to long.
Old 03-19-2011, 12:48 AM   #20950
Thanks blueman.
The only differnece is that the 0 degree uprights have less friction because the toe in is all generated by the suspension blocks, and the axle/swing shaft runs straight.
But realistc i think it makes no big difference, and if you have big impacts the plastic breaks, and you replace it, but the aluminium one bends and squeeze the bearing so that the rotation of the axle is not good anymore. In this case it looks like it is ok, but you have to change ist also!
Did you use the bearing spacer between the to bearings?
53891 Tam Bearing spacer for short rev. suspension
If not this is highly recomended!
Gerrtings Blueman
Old 03-19-2011, 02:18 AM   #20951
No, I didnt. It fits inside the upright before I put in the bearings?
Old 03-19-2011, 05:24 AM   #20952
Yes the spacer is between the two bearings in the upright/steering arm. In case of an impact, the force will be transfered to the inner bearing as well and they both will last much longer.
Go for it !
Grertings Blueman
Old 03-19-2011, 05:22 PM   #20953
I sure will. Thanks!
Old 03-19-2011, 07:30 PM   #20954
gsxr0311's Avatar
hay blueman, or whoever else can answer this question, what do you use for the front spool differential joints. i currently have the plastic ones. anybody using anything else?
Old 03-20-2011, 12:55 AM   #20955
The plastic/delrin ones with the alu sleeves work best. Very durable, and smoother than steel ones.
Greetings Blueman
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
