Old 02-19-2012, 03:19 PM   #21046
Originally Posted by Blueman Austria View Post
Nice blog!
If you all cant find the 169T Cyclome front belt, there is also a xray version available: 3x507mm front belt #305431.
Instead of the 3 racing parts, you can also use the white tamiya gear diff as well combined wiht the 501x/416 18T center pulleys.
By using the 18T pulleay the belt are exactly runned in the middle of the excenter mark. -> Perfect fit!
Greetings Rainer
Thanks for the extra info on the belt. I will update my blog with that info.
The Sakura pulleys are exactly the same width as the tamiya 18t pulleys so they also allow the belts to be perfectly central.
Btw I did a couple of test heats and the car went pretty good, although I need to sort out the dampers etc to match my current foam set-up.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 02-20-2012, 07:20 AM   #21047
tc3team's Avatar
Originally Posted by TommyAfrica View Post
Hi all
I just bought a MRE and love it
Looks like a million bucks wondering if it can be competitive with front ball diff
Should I change to spool
I have ta06 and ta05 both on spools
foam on high bite tracks will use a diff up front.
Otherwise, use a spool IMO
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 02-24-2012, 11:59 PM   #21048
Hey guys
I just put spool,wide pitch pulleys and also low friction belts i was wondering what gear diff i could use without changeing the ratio of the car because i was going to buy the spec r ta05 gear diff but it has one more tooth on the rear pulley
Please help me find the right gear diff
"No matter if you win by a inch or a mile, winnings winning".
AleD123 is offline   Reply With Quote
Old 02-25-2012, 10:42 AM   #21049
If you have the 36T pulley on the front you are best to replace it with the 37T spool pulley. Then you can use the following Gear diffs
Tamiya V2 for TRF416/7
Spec-R TRF416/7 diff
3Racing Sakura zero Gear diff
The above will fit the TRF415. The 3Racing one is really cheap (And its working really well).
A spare 37t front pulley is cheap as well.
Here is a link to my guide, if you dont change the centre pulleys you can use your original belts
http://thercracer.blogspot.com/2012/...gear-diff.html
Old 02-25-2012, 10:10 PM   #21050
Im still racing brushed silver can, can i still run the gear diff without changing anythin other than the gear
Also if i go to a 37t gear diff what does the ratio become
Sorry guys im still new to touring
Old 02-26-2012, 01:26 AM   #21051
chrisk's Avatar
Trader Rating: 32 (100%+)
internal ratio is pulley teeth / centre pulley teeth
eg 37/18= 2.05:1 is your internal ratio
you can still use your silver can
there is a website called gearchart.com
put in your internal ratio, spur and pinion and it will give your FDR
or spur/pinion = z then x this by your internal ration (2.05:1) and you get your FDR
eg:
internal ratio 2.05:1
spur 60
pinion 40
60/40= 1.5
1.5 x 2.05 = 3.075
3.075 is FDR
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 02-26-2012, 11:37 PM   #21052
Are the new belts needed because i just want tO buy the ger diff assemble it and put it and and change my gearing due to the new ratio
Old 02-27-2012, 08:26 AM   #21053
You can use the original belts if you just use the 37t rear and 37t front pulleys and leave the centre pulleys as 16t
Old 03-03-2012, 08:54 PM   #21054
Hey guys thanks for all the feedback on the gear diff runs perfect
We raced today i ran a trf415msxx mre spool with 3racing trf416 blue sleeves and outdrives. The black plastic outdrives snapped what do i replace it with i have the trf416 blue sleeves but im trying to find some steel trf416 outdrives
What can i do
All feedback is apreciated
Old 03-03-2012, 10:39 PM   #21055
Trader Rating: 69 (100%+)
What can i do
http://www.speedtechrc.com/store/ebp...id=865&id=9868
eComet is offline   Reply With Quote
Old 04-11-2012, 09:02 AM   #21056
Do 417x belts fit the trf 415 MRE equipped with 37T front spool and 37T rear diff? How about after changing the mid pulleys to 18T/19T?
raceblast is offline   Reply With Quote
Old 06-04-2012, 05:15 PM   #21057
jp_666's Avatar
Hello:
It is compatible the "Spec-R gear differential set (For Tamiya TA-05 V2/V2-R/IFS-R 37T)" in the front diff for the 415msxx.
thank you
jp_666 is offline   Reply With Quote
Old 06-12-2012, 01:01 PM   #21058
I sent you a PM, but to be clear the TA05 gear diff will not work in the front (or rear) of the 415
Old 06-20-2012, 11:12 PM   #21059
jp_666's Avatar
thank you
Old 06-28-2012, 04:36 PM   #21060
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
Anybody looking for a new in box factory shrink wrapped TRF 415 MSX MRE, please email me at [email protected].
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
