Old 03-21-2009, 07:17 PM   #20326
DRAG_ON's Avatar
Originally Posted by asw7576 View Post
Sorry, I edited it your quote .... so it look bigger and clearer now.
So, how is the handling after using one ? ...... I mean compare to ball diff ?
i found this picture long time ago......... i think you have to change the rear CVA into 44 mm instead of using 46mm
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 03-21-2009, 08:59 PM   #20327
dameetz's Avatar
I know this is 415 thread but just want to ask if the gear diff will fit in the 416we? Whats the pulley T on that? 37T?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 03-21-2009, 10:03 PM   #20328
dameetz
I think you will find that the 416 is not quit wide enough (26.8mm) at the rear bulk head. 46mm swing arms are fine.
Steven
Casino Kid is offline   Reply With Quote
Old 03-22-2009, 05:05 PM   #20329
chrisk's Avatar
Trader Rating: 32 (100%+)
Default GEAR RATIO QUESTION
i am running 540 class with my TRF 415 msx
(awsome car)
i currently run a 72 spur 36 pinion and gearing is spot on.
Johnson can motor club races only and the motor i just threw on the dyno and it has about 18000rpm
I just picked up a red dot motor of somebody here in Australia and it turns around 21700rpm and peak amp of around 5.23
what should i adjust my gearing to for me to run the better motor? or should i leave it as is?
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 03-23-2009, 03:00 AM   #20330
asw7576's Avatar
(awsome car)
If I were you, I will leave it like that, and enjoy more top speed.
Old 03-24-2009, 03:20 AM   #20331
penmark67's Avatar
Trader Rating: 14 (100%+)
Default short arms
Hi people I recieved an order from O/S and Ive been sent the short arms (X) pattern instead of the std type MSXX MRE (Y) pattern , my question is does anybody use them and how does it change the cars handling.
Im using 1B/1A Front mounts and 1XC 1D rear mounts and run on low/med asphalt ....long sweeping track.
Thanks Mark
penmark67 is offline   Reply With Quote
Old 03-24-2009, 04:31 AM   #20332
chrisk's Avatar
I heard that the short arms hook the car up and help with traction. But cause they are short arms you may need shorter shafts or different blocks that are wider
smaracing.org
Old 03-24-2009, 06:10 AM   #20333
penmark67's Avatar
Default yep
Yeah that seems to be the case but do I have to shim or use spacers somewhere to keep the same track width or run a slightly narrower car ?
Questions questions.
thanks Mark
Adelaide
Old 03-24-2009, 08:43 AM   #20334
94eg!'s Avatar
Trader Rating: 17 (100%+)
If you have the parts, you should switch to the same blocks found on the 416 Worlds Edition...
94eg! is offline   Reply With Quote
Old 03-24-2009, 02:07 PM   #20335
ok i was out practicing today and i got a funny rear grip problem
when i come out of a corner and start to put the power on again the rear wants to come around !!!
tried moving my 5 cells to the rear but no help
i am running a 10.5 turn LRP brushless with yellow rear springs and white front with 350wt oil in the shocks
Vtec 27 tyres and ride hight of 5mm front and 5.5 rear droop is 6mm front and 5mm rear (measured on droop blocks and measured under arms
racing on medium grip smooth tarmac
cheeRS phil
sidecarphil1 is offline   Reply With Quote
Old 03-24-2009, 03:59 PM   #20336
BLUE 2's Avatar
Trader Rating: 23 (100%+)
Talking
cheeRS phil
Hi
I would try 4mm front droop to let it put more weight to rear on power
See ya
Cars Offroad : TLR 22B - TLR 22B 2.0 - TLR 22T - TLR 22SCT - TLR TEN-SCTE 2.0
Cars Onroad : HB Cyclone TC - TRF 416X - Tamiya TA05 - Serpent s411 eryx 2.0
BLUE 2 is offline   Reply With Quote
Old 03-25-2009, 03:05 AM   #20337
penmark67's Avatar
Default yep
Originally Posted by BLUE 2 View Post
Hi
See ya
He's correct and ..........use 50wt in the front
Try setting your droop with verniers from the top of the axle next to the hex
24.5mm front 25mm rear
Also be carefull that your softish spring rate has'nt cooked your rear tyres.
Cya Mark
Old 03-25-2009, 11:53 AM   #20338
with how many holes in the pistons ??
can you show me a piccy ?? and do you rest the car on droop blocks ??
they were new tyres just scrubbed in the lack of grip was from the start of my practice
Old 03-25-2009, 12:34 PM   #20339
STLNLST's Avatar
Trader Rating: 21 (100%+)
This weekend is the first points race for the Reedy race. Winner gets their entry paid for if they win their class. Can't wait to run the car again and get some more track time with it on asphalt. The weather is looking real good for this weekend. It's suppose to be a high of 79 so I'm assuming the track temp will be triple digits. Should be awesome.
STLNLST is offline   Reply With Quote
Old 03-25-2009, 12:37 PM   #20340
JayL's Avatar
to droop the tamiya we use the David Jun method:
set car with chassis on setup board, no blocks, no tires, nothing.
measure the distance between the setup board and the top of each axle using the depth measuring part of your calipers
I usually end up with about 26mm in the rear
JayL is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
