Like Tree4Likes
Viper RC -
Old 04-30-2014 | 07:39 AM
  #10321
the instructions should be under the cardboard riser panel. I think thats where they also throw in a few stickers as well.
Bob Barry is offline
Old 04-30-2014 | 08:30 AM
  #10322
samuelsonmark71's Avatar
samuelsonmark71 is offline
Old 04-30-2014 | 09:10 AM
  #10323
nikos2002's Avatar
Devin- apologies if you didn't get them. As stated they are normally in the very bottom of the box. Glad you found them online.
drerc- thanks for posting the videos again.
jsrracing- nice to talk with you, of course let me know if you want us to check the motor sensor.
djzipper- strange, PM me if you have more questions. Please send it to us so we can look it over if there is an issue.
nikos2002 is offline
  #10324
nikos2002's Avatar
BTW- thanks to all the help and answers guys!!
Old 04-30-2014 | 10:24 AM
  #10325
emacrimes's Avatar
New to e-buggy.
Thoughts about the VTX8 and with what motors works the best?
Thanks!
emacrimes is offline
Old 04-30-2014 | 10:59 AM
  #10326
Tarimon's Avatar
Unhappy
Originally Posted by jsrracing
I have a problem with a new vtx8 and a vf8 motor.
when I go from full brake to full throttle , its like a off then bam 100 and nothing in the middle it has gotten so bad that I have to move my finger really slow to get the car to run . any ideas
I have a similar problem with my new Viper combo, the car drives about 4-5 minutes normally, then loses power quite quickly, and begin to cogg little later and then revs up no longer. Temperatures are within the normal healthy range around 70 ° Celsius. No error message on the LEDs on the power switch. Software is the a64, Profile 1 standard without any changes. Any ideas or solutions?
Thanks for your help!
Tarimon is offline
Old 04-30-2014 | 01:49 PM
  #10327
bds81175's Avatar
Moderator
Try downgrading to the previous version of software. That's what fixed mine.
bds81175 is offline
Old 04-30-2014 | 02:51 PM
  #10328
Tarimon's Avatar
Thats bad, cause I dont habe the pclink...
Tarimon is offline
Old 04-30-2014 | 04:56 PM
  #10329
nikos2002's Avatar
Tarimon- sounds familiar did you email us this question? If not check you protection settings. battery cut off, motor temp and esc. Remembering that the temp cut off can read 50-80 different internally than wha is measured externally on the can of the motor.
I have seen a few cases that the motor temp cut off if just in the edge if triggering so the unit would cause the motor to stutter which some believe is a cut off. If the protection setting is raised or disabled the stutter goes away. Just a thought to try.
Old 04-30-2014 | 08:06 PM
  #10330
I am having a problem with my VTX10 ESC. I turn it on, all works great. Once I use the breaks, I loose forward. It will only go in reverse. It will not shut down if I hold the red button down either. Only way to turn it off it to unplug the battery. I can not get it into program mode either.
Is it toast?
Buzz.
blvdbuzzard is offline
Old 04-30-2014 | 08:30 PM
  #10331
nikos2002's Avatar
buzzard- how long before it stops? Minutes? 30seconds? If it happens quickly it may be a fault in the unit. Fets just have to warm up before some fails. If you run for minutes and it happens - would be really strange not a "typical" failure. If there is one. As I mentioned before if the unit is still in warranty period please send it in, we would be glad to look at it.
Old 05-01-2014 | 03:54 AM
  #10332
djzipper's Avatar
Thanks, PM sent.
djzipper is offline
Old 05-01-2014 | 06:52 AM
  #10333
I bought it from A Main on Feb 17th, is it still under warranty?
Funny thing, I can run for 1, 2, 3, 5 minutes as long as I do not use the breaks. Once I use the breaks I loose forward. Something is wrong because I can not turn it off. If I hold the button down, nothing happens. Once I turn it on, it goes through the boot, then the red LED just flashes. I can not get it into program mode or turn off.
Buzz.
Old 05-01-2014 | 06:58 AM
  #10334
Wildcat1971's Avatar
Tech Prophet
Buzz.
weird. also it will NOT turn off if the throttle is not at neutral. Some radios have a little drift around neutral. So you might want to change the dead band. Also, I had fail safes configured on mine radio and it just didnt play well with the viper. I turned them off. But the whole thing where you use your break and it instantly stops working is weird. I would send it in it it stops working every time you hit the breaks.
Also, the vtx10 has a 1 year warranty.
Wildcat1971 is offline
Old 05-01-2014 | 07:20 AM
  #10335
Tarimon's Avatar
Nikos, what is the maximum of degrees the Motor should able to handle? I dont want to disable the protection, because of my nervous 'nitro-finger' on The throttle
Had a small test drive today and it seems to be the Motor tempetature cut off is the problem. Which adjustments can i do, to lower it? PWM down on both, throttle ans brake..?
Thanx for help...
Tarimon is offline
