Like Tree4Likes
Viper RC -
Old 04-27-2014 | 05:44 PM
  #10306
I have a problem with a new vtx8 and a vf8 motor.
when I go from full brake to full throttle , its like a off then bam 100 and nothing in the middle it has gotten so bad that I have to move my finger really slow to get the car to run . any ideas
jsrracing is offline
Old 04-27-2014 | 05:47 PM
  #10307
nitro neil's Avatar
What radio and what software version would be helpfull
nitro neil is offline
Old 04-27-2014 | 05:56 PM
  #10308
sounds like it's not calibrated correctly. Start from scratch. Go to a new model on the radio, rebind everything. Set all your end points to 100. Rebind the ESC to the radio and then try
Bob Barry is offline
Old 04-27-2014 | 05:57 PM
  #10309
mt4 radio v64 on esc
I have reset the radio re bind and recal of esc still the same .
it only does it from brake not from neutral
Old 04-27-2014 | 07:43 PM
  #10310
the malfunction only happens when I set the motor direction in reverse .
when I set it to normal it works perfect . changing it in the radio has no affect on the direction . please tell me that it is a soft ware glitch and can be fixed
I run a rb e one r and the motor has to run reverse.
Old 04-27-2014 | 07:54 PM
  #10311
grr
Old 04-27-2014 | 08:13 PM
  #10312
godofcable's Avatar
on my plane esc I can just swap any 2 of the three motor leads and change direction . can I do this on the viper to solve the problem
No because it's sensored. Did you recal the radio after you reversed motor rotation in the esc?
godofcable is offline
Old 04-27-2014 | 08:42 PM
  #10313
yes
I rebind the radio ,and recal the esc works great when I set it to normal
when I set it to reverse and recal,which my car requires . maybe I have a defective esc or motor guess I have some phone time to look forward to grrr
this sux
Old 04-28-2014 | 04:03 AM
  #10314
djzipper's Avatar
Default VTX 10R BE - problem
I was hoping someone might be able to help?
I was at a meeting yesterday and in practice all was good. For the first round of quali I turned on my VTX10r BE and it made the usual noise. I had steering but the throttle did nothing. I took off the shell and the button has 1 solid red light on the 'P' and no other lights. The button doesn't do anything, even holding it down will not turn of the ESC. It has A64 firmware on it.
djzipper is offline
Old 04-28-2014 | 04:40 AM
  #10315
godofcable's Avatar
yes
this sux
did you try reversing the motor in your radio but keeping it normal in the ESC then recal?
Old 04-28-2014 | 07:27 PM
  #10316
ya tried it all . call and talked to tech at viper nice guy .
we are guessing that it is a sensor in the motor causing the skip as all these motors are set to o so off in the mail it goes .
IM thinking I can flip the diffs because it works perfect in normal but the problem with that is my buggy uses helical pinions on the diffs so im not sure .
but it would be nice to run motors forward . French buggies go figure lol
on the bright side I have gotten a education on sensord 1/8 buggy esc and motors .
Old 04-30-2014 | 03:57 AM
  #10317
Drerc's Avatar
For people that are struggling calibrating their VTX10/R :
https://www.youtube.com/watch?v=w7t1...ta_HffxurdxOeT
For people that would like to now how to program your viper esc + explanation of the settings !
https://www.youtube.com/watch?v=gsHj...ta_HffxurdxOeT
Drerc is offline
Old 04-30-2014 | 07:20 AM
  #10318
Devin's Avatar
My buggy is almost ready to be wired up for power, one thing I noticed: There was no instruction sheet in the box for the VTX10 combo. Had to wait till I got to work and print some instructions found on the site. For the 10 cents it costs it would have been nice, no internet in my workshop.
Devin is offline
Old 04-30-2014 | 07:23 AM
  #10319
Grasschopper's Avatar
Did you look under the cardboard in the bottom where the stickers and double sided tape are? I'm pretty sure that all of my Viper ESCs have come with instruction sheets.
Grasschopper is offline
Old 04-30-2014 | 07:24 AM
  #10320
Wildcat1971's Avatar
weird. All of my esc's came with instructions.
Wildcat1971 is offline
