Like Tree4Likes
Viper RC -
Old 05-10-2014 | 07:01 PM
  #10456
Devin's Avatar
Originally Posted by Jim Hustins
Sorry to keep asking the same question. But are you holding the power button down while the ESC is off?
I took a video on my iPad, googling how to post it to the internet but I am out the door soon taking my wife to the movies.
I plug in the ESC to the Lipo, open the Tx, and then hold down the red button waiting for the two beeps. Yes this is being done while it is off.
Devin is offline
Old 05-10-2014 | 07:09 PM
  #10457
Devin's Avatar
This took way less time than I expected: Here is a link to the video of my issue:
https://www.youtube.com/watch?v=p7Z_...ist=WL&index=3
Devin is offline
Old 05-10-2014 | 07:10 PM
  #10458
Jim Hustins's Avatar
If u can't upload it, email it to me. [email protected]
Jim Hustins is offline
Old 05-10-2014 | 07:26 PM
  #10459
I emailed Nick your video.
Old 05-10-2014 | 08:21 PM
  #10460
That is just about what mine was doing. No matter what I could not turn it off or get it into program mode.
I was able to get it to program with the PC link after about 45 minutes of very adult words. After updating to the new firmware, I was able to program it, but it has other issues now. I am not able to turn off the drag break, the LVC kicks in at around 7.1 volts even though I have it set for 2.0 volts.
I should have it in the mail on Tuesday. Should I send the motor and ESC or just the ESC?
Buzz.
blvdbuzzard is offline
Old 05-10-2014 | 09:02 PM
  #10461
nikos2002's Avatar
Deven - Jim sent me your video -- some things to check and try.
- on your radio - make your your EPA is set at 100 for throttle and brake no EXP
- when you hold the bottom down for the programming (in the video) thought it would be just a few more second before the calibration starts. BTW, if the unit doesn't calibrate it doesn't know its in neutral, so it wont turn off by the VPort, need to be in neutral.
- ---If holding it down longer doesn't make any effect. Check these steps:
- Make sure plug is in receiver in the correct direction - positive, negative, signal wire -- for your receiver
- make sure its in the correct slot for a speed control (typically Channel 2 or it will say THR or THL)
- If your radio has multiple models - try a different model
- On your transmitter - move your throttle trim forward about 3-4 clicks - then start calibration process (do not move the trim back), this moves neutral point in signal, so its clearer.
Another thing I like to do if anything is happening strange, is go back to basics. Take out the electronics and clean out the car, then put all the pieces back in - electronics are funny, sometimes they just want a little TLC.
PM me if you have any more questions.
nikos2002 is offline
Old 05-10-2014 | 09:06 PM
  #10462
nikos2002's Avatar
Buzzard - before you send it in - check the settings you are running with.
- If the system has too much drag brake either the drag brake or Smart Brake settings are too high. If you have changed them - check to verify you saved the settings after the change. Other than esc also check that motor and transmission are spinning freely, because that can lock up the rear as well and feel like drag brake.
-- How exactly is the system cutting off? Because our LVC cut off software version a64 is not a cut off. You loose throttle control but keep steering. If using older version software - the unit will shut off and reset itself (a hard reset - play the tune, lights flash, whole start up cycle). PM me with which issue you are having.
Old 05-10-2014 | 11:16 PM
  #10463
Devin's Avatar
I definitely held the button long enough in previous attempts before I took the video. And I have tried an uninstall/re-install of the electronics.
It's late now, I'll try all this in the morning. I understand how to do all these fixes work except the receiver wiring double check. Which colours on the ESC represent the positive, negative and signal wire?
(Also isnt the red one in the middle, figured that would be positive?)
Devin is offline
Old 05-11-2014 | 03:39 AM
  #10464
nate79's Avatar
Just wanted to get on here and say thanks to viper. I set my esc in on Monday and received it back on Saturday. Now that is customer service
nate79 is offline
Old 05-11-2014 | 06:53 AM
  #10465
DRTMI's Avatar
Super Moderator
The black or ground wire should be towards the outside of the receiver, the white or signal wire towards the center of the receiver.
DRTMI is offline
Old 05-11-2014 | 06:59 AM
  #10466
ridgerunner1's Avatar
Your right there they have a good team fast turnaround times.
ridgerunner1 is offline
Old 05-11-2014 | 07:42 AM
  #10467
Cain's Avatar
Tech Legend
Hey guys, I got my Viper 10.5 and 17.5 motors. I plan next weekend to have these run in a 'mod' class, so boosting features, etc can be used.
Is there a recommended setting on the motors themselves for timing when doing this? these will be used in 1/10 2wd buggies.
Also, the 17.5 will be run sometimes in a blinky 17.5 class, any recommended starting points for timing there on the can?
Cain is offline
Old 05-11-2014 | 08:18 AM
  #10468
On the 17.5, crank the can timing up to 45*. Small amounts of ESC timing will result in a lot more speed. 10 degrees of accel timing and 5 degrees of top speed timing would be a good starting point. Slew rate of 3. Keep an eye on motor temps and hold on. Play with the rpm range when it comes on and the top speed timing should be set at the top rpm's of the motor.
Old 05-11-2014 | 08:31 AM
  #10469
Devin's Avatar
Ok Still having issues. Sent Nikkos a PM as requested.
Devin is offline
Old 05-11-2014 | 09:19 AM
  #10470
I have full steering, it starts to stutter, then stutters more until it will not go forward. I check the battery and it is fine. I put the battery in my Slash and ran for another 30 minutes or so.
When I changed the settings with the program card it said COMPLETED! Then I held the button down, it turned off then I turned it back on.
The gear train on the truck is fine. Runs well is smooth. I have a budget power setup in it now and it works without a problem.
Buzz.
