Like Tree4Likes
Viper RC -
Old 05-11-2014 | 09:30 AM
  #10471
nikos2002's Avatar
Deven - thanks replied
Buzz sent you a PM.
nikos2002 is offline
Old 05-11-2014 | 10:57 AM
  #10472
Devin's Avatar
Talking
Buzz sent you a PM.
Nikkos basically told me that he really thought it sounded like a transmitter problem and he was worried if I sent it in under warranty nothing would be wrong with it and I'd be out the shipping and the time.
So I went to the field to see if anyone had some thoughts. It is now running strong on a Turnigy backup radio. Not sure what the issue was, but it was totally on my end.
It's spinning out everywhere, next step is figuring out how to use the little programming device to turn down the punch.
Many thanks.
Devin is offline
Old 05-11-2014 | 11:49 AM
  #10473
DaveG28's Avatar
Hey guys,
Are there any plane to update the 540 motor line?
Wondering as it must be just about your oldest product now?
DaveG28 is offline
Old 05-11-2014 | 12:03 PM
  #10474
I have not used the radio to change any of the settings. I will put it in my back up SC10.2, different Rx, model slot and see what happens.
Funny though, I put in a budget setup, calibrated it and it is working very well. I have not changed any radio setups between the motor ESC combo's.
Buzz.
blvdbuzzard is offline
Old 05-11-2014 | 05:33 PM
  #10475
Jim Hustins's Avatar
Many thanks.
Great. Glad Nick was able to point you in the right direction.
Jim Hustins is offline
Old 05-11-2014 | 05:40 PM
  #10476
Wildcat1971's Avatar
hmm, lol. I cant get one of my vipers into calibrate/profile changing mode. It must be contagious. I will play with it again later. I just pulled out my pro-gauge and changed the profile.
Wildcat1971 is offline
Old 05-11-2014 | 05:54 PM
  #10477
You have been assimilated into our collective of no programming mode.
I have not had a chance to install the setup yet. Been a painful day. I should be able to get to it this Tuesday.
Buzz.
Old 05-11-2014 | 09:47 PM
  #10478
nikos2002's Avatar
Originally Posted by DaveG28
Hey guys,
Work in progress. We have some select drivers testing all the time. Biggest hold up has been trying to see if ROAR was going to change any rules or not with 17.5. We are going to start working on new modified motors and figure out 17.5 when its clear (if its ever clear).
Old 05-11-2014 | 09:50 PM
  #10479
DustinH's Avatar
13.5?
DustinH is offline
Old 05-11-2014 | 11:31 PM
  #10480
nikos2002's Avatar
Originally Posted by DustinH
13.5?
Yes, there will be one made.
Old 05-12-2014 | 07:29 AM
  #10481
2canSAM's Avatar
R/C Tech Elite Member
Originally Posted by 2canSAM
Bullets are fresh and I have solid continuity from post to end of bullet. Also good continuity from each of the motor post to the end of the wire. I am out of town right now and will test with just the ESC on and not plugged in to the receiver when I return. Good idea! A55 FWIW.
ESC only hooked up to battery and still seeing similar results with the ESC shutting down when dropped from 3-4 feet. Connected to battery only, The RED P light is all that is lit, but when dropped it is blinking off and staying off. It is not turning itself back on now and looks to be dead. I had seen this before when I did my initial testing and thought the ESC was totally dead but after letting it sit for a day it came back on. Again I have solid continuity from each post (Battery +, Battery - & Motor A,B,C) to the end of the wire. So far I have replaced everything but the truck I have tried 4 batteries (Fully charged) 2 Receivers, 2 Transmitters, 2 Servos, 2 Motors, multiple sensor wires and soldered on new bullets. I already have an open RMA and at this point all signs point to ESC. Thanks for all the help Nick. Here to hoping for a quick turnaround
2canSAM is offline
Old 05-12-2014 | 08:53 AM
  #10482
Drerc's Avatar
Could be a bad switch connection, mine also looked dead after 1 race, nothing anymore, no lights... Send it back, really want to know what it is.... But I think a bad connection on the switch....
Drerc is offline
Old 05-12-2014 | 09:07 AM
  #10483
DavidAlford's Avatar
Make sure you don't have dirt in your switch. I had a VTX8 that wouldn't go into program mode because of that. Little air, good to go.
DavidAlford is offline
Old 05-13-2014 | 12:00 AM
  #10484
nikos2002's Avatar
Coming soon to a hobby shop and race track near you:
Old 05-13-2014 | 07:16 AM
  #10485
2canSAM's Avatar
That motor looks awesome. Makes me want to get a 4x4 SC Nikos2002 you have a PM
2canSAM is offline
