Like Tree4Likes
Viper RC -
Old 01-17-2014 | 05:21 PM
  #9721
silvalis's Avatar
Originally Posted by bigjerry
Anyone running Tekno 410 help with setup on VXR 4.5 copperhead give me some good starting spots
Originally Posted by nikos2002
silivas- here is the copperhead set up I have run before:
Brake strength- level 7
Brake curve- exp+2
Drag brake- level 2
Throttle punch - level 3
Curve - Exp +1
Dead band - middle
Motor Timing - Level 6
Run Mode- 1 second Reverse
Motor Direction - normal
Start Power- Level 6
Forward Power Level 10
I fiddled around with his settings a bit for the following race settings:
VXR4.5/Copperhead R/Tekno SCT410 geared at 16/44
Brake strength- level 9
Brake curve- lin
Drag brake- off
Throttle punch - level 7
Curve - lin
Dead band - narrow
Motor Timing - Level 7
Run Mode- Forward Only
Motor Direction - reverse
Start Power- Level 8
silvalis is offline
Old 01-17-2014 | 05:34 PM
  #9722
nikos2002's Avatar
Thanks silvalis!!
nikos2002 is offline
Old 01-17-2014 | 05:35 PM
  #9723
nikos2002's Avatar
Originally Posted by Jim Hustins
FYI: our VF8 motors are plenty fast. They can't be produced fast enough. lol
I will sell no motor before its time.......
wait was that wine? maybe I just need a drink......
Old 01-18-2014 | 07:09 PM
  #9724
bluegroovelosi's Avatar
Default VTX8 weird shutoff behavior!
Beginning last week, and continuing this week, my VTX8 is exhibiting consistent shutoff/lockout behavior.
The motor runs at full power for 4-5 laps and then the VTX8 goes into some sort of safety mode:
1) The forward and reverse led's blink at the same rate as the normal green 'blinky mode' led and all power to the motor is stopped.
2) Power to the servo continues, as well as power to the transponder.
3) Neither the VTX8 or the VF8 motor are even close to being in thermal shutdown. The motor has been around 130 degrees each time it stopped. The VTX8 is cool at under 110 degrees.
4) As soon as the VTX8 is re-booted, it functions normally- even if it's only 10 seconds later. Then it will run normally for a 4-5 more laps, only to shut down again.
The VTX8 worked consistently well for the past 4 months and this is the first sign of a problem. Is there a 'reset' function under which I can wipe out all of the custom profiles and return it to it's original factory setting?
Or am I looking at sending it back to get fixed?
Robert Conner
Omaha, Nebraska
bluegroovelosi is offline
Old 01-19-2014 | 08:27 AM
  #9725
Cain's Avatar
Tech Legend
you could probably just set a profile back to what the settings are in the manual.
Cain is offline
Old 01-19-2014 | 08:46 AM
  #9726
jkas10's Avatar
R/C Tech Elite Member
Robert Conner
Omaha, Nebraska
If you have a progauge or EZ link, just "LOAD" profile 1 to get back to default settings. If you don't have the progauge or EZ link, here are the manual instructions: http://www.viper-rc.com/downloads/VT...l_20130403.pdf
1. Connect a proper/charged battery pack to the ESC.
2. Power on transmitter.
3. Press and hold the red power button on the V-PORT for three seconds.
(Followed by beep tone, F/N LEDs on the V-PORT will be indicated as the image shown at right)
4. Press the corresponding number of time of the desired profile (refer to TABLE.1 below) on the red power button
on the V-PORT. For example, press 5 times if you wish to load profile 5. The F/R LEDs will be indicated on
every button press.
5. Release the power button for 3 seconds. The VTX ESC will save the profile number and F/R LEDs will be
flashing the number of time of the corresponding profile that it was saved.
6. The VTX ESC will then run an auto system reset. The F/R LEDs will be flashing the corresponding profile number
every time after beeping of system initialization.
jkas10 is offline
Old 01-19-2014 | 07:52 PM
  #9727
Motorman007's Avatar
Originally Posted by DoogieLee
I would also look at going to an 18 or 19t pinion... I know it seems high, but that motor needs to be in the sweet spot, and I think you are way undergeared. Making all those changes should get you a very quick buggy with power to spare.
Just want to say the changes and pinion was the ticket. man it shot out of the turns like a rocket.
I ran.the 19 pinion.
I.also have 18 to try out.
Thanks all for the great help
Motorman007 is offline
Old 01-19-2014 | 08:04 PM
  #9728
My esc died(lost communication). I bought under year ago. My understanding, its warrantee is a year.
Do i email viper or go back to hobby shop?
braderb is offline
Old 01-19-2014 | 08:14 PM
  #9729
bdyche's Avatar
Fill out the service request here and send it out. Remember to include the purchase receipt for warranty work.
bdyche is offline
Old 01-20-2014 | 07:59 AM
  #9730
Rybeau40's Avatar
Default Viper esc
Hi all,
Quick question: I have a viper 10r BE. Does the timing setup on the esc add to the timing setup on the can?
Thanks!
Rybeau40 is offline
Old 01-20-2014 | 02:19 PM
  #9731
silvalis's Avatar
yes
silvalis is offline
Old 01-21-2014 | 04:04 AM
  #9732
silvalis's Avatar
Brake curve- lin
Drag brake- off
Curve - lin
Dead band - narrow
Fiddled around with the settings at the track again today and change Punch to 10, timing to 10. The lower punch settings made it feel like it hesitates - really noticed this between jumps (ie, a double into a triple, etc). Behaviour of punch feels different to the VTX8/10. The timing was increased because I was trying to make it carry more speed. I think I need to go to a 17t pinion, but coming from a tenshock sc411, there isn't much high rpm torque to play with. Starting to really like this little esc/motor, but seem to have to keep the revs up to get the most out of the motor.
Nikos, can you comment on the following?
1) Motor timing setting vs gearing up - is there any value in dropping timing on the ESC down and going up a tooth instead? I imagine going up a tooth will have a larger impact on speed/torque?
2) Throttle Punch vs Start Power - start power affects from 0 rpm? Or is there a threshold where it is still in effect, eg, 100rpm? Do both settings take effect at 0? eg, at standstill and you push the trigger, start power setting and throttle punch setting are in effect?
3) Volts cutoff behaviour - I had it set at 3.2V/cell, had it continuously shutoff. I think a couple of my batteries were playing up. Does the cutoff do an immediate power off or something else?
silvalis is offline
Old 01-21-2014 | 11:11 AM
  #9733
nikos2002's Avatar
silvalis - 1) you have the right idea, gearing up can be a bigger change, but I would drop motor timing down if you gear up to confirm no heating issues.
2) Start Power really effects the lag that the throttle trigger will feel before you get reaction from the system. Higher should make it react faster - but will cause the esc to run hotter since its purely a software driven function. Punch is more "at the wheels" with the power relayed to the motor at that instance. Lower will keep the wheels from spinning.
3) If you if hit voltage cut off, the system will shut down and reboot, all 4 pole motors are very hard on batteries. These things hit with really high amp spikes.
Old 01-21-2014 | 11:25 AM
  #9734
nikos2002's Avatar
bluegroovelosi - what do you have the temperature protection settings at the for the motor and esc. Generally need to be set around 220 - 230. Remember they read internally off the rotor and circuit board of the systems they are measuring and can be 40-60 hotter than what you get outside the case. So if you set the motor cut off to 160 or 180, it may be too low, and cutting off early.
Old 01-21-2014 | 12:42 PM
  #9735
Cain's Avatar
Tech Legend
great info as usual
I remember my issue with the stuttering I had on power. It looked like my vehicle was multishifting. The VTX8 is more hardcore with voltage cutoff than what I was used to, and to be honest the more I think about it thats a good thing as in a way it tells you "hey, your battery is dropping below the threshold" by doing that versus others ESCs that just let it go by.
Cain is offline
