Team Associated B4.2 Thread >
Like Tree4Likes
Old 04-18-2013 | 06:10 PM
  #4336
Originally Posted by t0p_sh0tta
But where's your ESC? WE'VE GOT TO KNOW WHERE YOU PUT IT!
I'm kidding. I haven't tried the 1.7s yet, but I might give them a go next week. The home track has been really dry lately, and I'm kind of tired of going through a set of tires each night.
You try M3 Holeshots or M3 Tasers?
Bob Barry is offline
Old 04-18-2013 | 06:50 PM
  #4337
Tradin Paint's Avatar
Originally Posted by aeRayls
Front
Shocks 1.7 35 2 limiters green spring mounted inside/outside
1a camber link 1mm, -1
2 hole 30* blocks
Spindle shaved and moved up 1mm
2mm bumpsteer
Rear
1.7 32.5 white 2 limiters
Mounted inside/inside
Camber 1B 1mm under studs
A hubs also spaced middle
3 deg toe, 2 anti squat
Shorty pack in the middle 1/2 oz in front of Batt tray, 1/4 in each triangle and the ballast weight.
Which hubs and .0 or .5 also do you have a standard or shaved u brace?
Thanks for posting this
Tradin Paint is offline
Old 04-18-2013 | 07:25 PM
  #4338
Ok fun lets post our setups. I would really like somebody to try mine and tell me what you think.
Front
Shocks: 1/0
Link: 1A
Washers 1 blue 1mm washer 1 silver .030
Ride: 24mm
Bump: 2mm
Caster: 30
Springs: Black
Oil: 32.5 2x1.6
Camber: 1
Limiter: 3
Rear
Shocks: 1/0
Springs: Green
Oil: 30 2x1.6
Link: 1/B, A HUBS
Washers: 0
Wheelbase: Middle
Toe: 3
Squat: 2
Camber: 1
Limiter: 2
Ride: 24
B44 rear arms, ballast weight. Shorty pack all the way forward. No other weight added. Run in stock buggy with 69 spur.
chevmaro is offline
Old 04-18-2013 | 08:08 PM
  #4339
aeRayls's Avatar
Front
2 hole 30* blocks
2mm bumpsteer
Rear
Sorry I had to get back to work... Here's the rest:
0* hubs
Carbon unshaved u brace
Carbon top plate
Carbon front arms
44 rear arms
Ti ni ball studs
Esc in the correct position lol, on the side
Cvd's instead of cva's
Factory Tracks motor centering kit
XP ds1015 servo
Lrp flow 6/2/0/0/3
Reedy 8.5. 23/81
EPA... T 100% B 82%
24/24 ride height
JC finnisher with 6.5 HC wing cut to 1 line.
If traction is up, try gray rear springs.
aeRayls is offline
Old 04-18-2013 | 09:17 PM
  #4340
Originally Posted by Jake S
finally got my 3x1.4 pistons in for racing wednesday, the car was ALOT better on landing, also seemed like i gained alittle jump distance too.
waiting on a pair of green rear springs to come in next week, as it feels like the rear could be alittle softer with these pistons (32.5green/30white) but whites may work fine if i went down to 27.5 as well.
but im thinking green/3x1.4/32.5 front green/3x1.4/30wt might be the ticket because i love the compression/rebound with the 30wt in the rear.
To add to the piston discussion... I have tried Associated 1.6, Avid 1.5/1.1, Avid 1.6 and now Associated 1.4x3 in that order. My car has been really dialed with the 1.4x3. I have been running them with Front 35wt (Pink Kyosho Spring) and Rear 32.5wt (White Kyosho Spring). I feel that the 1.4's "pop" off jumps a little better and land with adequate dampening. The major difference I noticed was that the 1.4's took the "edge" out on low speed dampening especially with a light car.
Ultra7M is offline
Old 04-18-2013 | 10:23 PM
  #4341
Cain's Avatar
Originally Posted by bilster44
Tough to beat them 1.7's...indoor or out,love em!
wow,really? I hated the 1.7's. no pack and the car was all over the place. I guess different strokes for different folks.
hmm, I dont get it , lol. The 1.4x3 should have way more pack the 1.7x2. The 1.7's were ok in the corners, but the chassis slapping was terrible. 1.6 had good pack but were not great in the corners. I really felt like the 1.4x3 very the best of both worlds. Post your entire setup, I am wondering if you did something vastly different with roll centers and camber gain.
+1 for me on carpet, the 1.7s felt really bad off of jumps. the 1.6's felt great.
Ultra7M: any interest in selling the avid pistons?
Cain is offline
Old 04-19-2013 | 07:40 AM
  #4342
What do you guys feel shaving then raising the front spindle accomplishes?
Jam-Air is offline
Old 04-19-2013 | 07:46 AM
  #4343
t0p_sh0tta's Avatar
Lower hub gives you a bit more droop out front, which gives you more on power/corner exit steering. Raising it does the opposite, as the weight transfers to the rear faster.
t0p_sh0tta is offline
Old 04-19-2013 | 07:47 AM
  #4344
I run on fairly low-bite outdoor dirt tracks. What has been working for me is as follows.
Front
Shocks: 1/0
Link: 1A
Washers 1 blue 2mm washer
Ride: 24mm
Bump: 2mm
Caster: 30
Springs: Green
Oil: 32.5 2x1.6
Camber: -.5
Limiter: 3
Rear
Shocks: 1/I
Springs: White
Oil: 30 2x1.6
Link: 1/B, C HUBS
Washers: Shaved brace 0 washers
Wheelbase: Middle
Toe: 3
Squat: 2
Camber: -1/2
Limiter: 2
Ride: 23.5
All Plastic Parts. 0.5 Degree Rear Hubs, Wolfpack Shorty with center mount esc. Shorty Pushed forward with 14g behind servo. Full ballast under tranny mount. Running 8.5 with 24/81 gearing
Would love to hear suggestions on a better setup. So far this works fairly well; however if I touch the throttle at all on corner exit it wants to swap ends.
rnpnick is offline
Old 04-19-2013 | 07:52 AM
  #4345
Hub? I thought you guys were lowering or raising the spindle to control how the car turns. Did I miss something?
Jam-Air is offline
Old 04-19-2013 | 08:07 AM
  #4346
Wildcat1971's Avatar
Tech Prophet
Front
Shocks: 1/0
Link: 1A
Ride: 24mm
Bump: 2mm
Caster: 30
Springs: Green
Oil: 32.5 2x1.6
Camber: -.5
Limiter: 3
Rear
Shocks: 1/I
Springs: White
Oil: 30 2x1.6
Link: 1/B, C HUBS
Wheelbase: Middle
Toe: 3
Squat: 2
Camber: -1/2
Limiter: 2
Ride: 23.5
Would love to hear suggestions on a better setup. So far this works fairly well; however if I stab the throttle at all on corner exit it wants to swap ends.
stabbing the throttle is a bad idea always in the corner. roll in roll out.
Wildcat1971 is offline
Old 04-19-2013 | 08:20 AM
  #4347
I edited my post. The initial touch of roll in causes the car to become unsettled unless it is perfectly strait. I want to be able to roll the throttle on corner exit while still turning. The car seems good on low speed corner entry through mid but is loopy on exit unless strait. Car is perfect in sweeper, rear end stay planted and I can steer out with throttle.
rnpnick is offline
Old 04-19-2013 | 09:26 AM
  #4348
aeRayls's Avatar
The track is a fairly loose outdoor track right? Is it rough/uneven in spots? Elevation changes or off camber turns? If so A hubs with unshaved brace and 0 washers would be a good options.
However, I'd go down to only 2 limiters in the front first.
The white spring in back may be a touch too stiff as well.
Personally after all my indoor testing, I'm pretty sure there is no way I'm going to use the 1.6's in mine for outdoor season.
aeRayls is offline
Old 04-19-2013 | 09:29 AM
  #4349
DanielC.'s Avatar
More front droop = more weight transfer to rear on power = less on power steering and more rear bite. Opposite for when you raise the spindle.
DanielC. is online now
Old 04-19-2013 | 09:33 AM
  #4350
Tech Prophet
I would definitely start with a softer spring in the rear. Also, I am not sure the shaved brace and C hubs are the best for you. And your rear ride height might be too low for low bite out door. at least come back up to 24mm maybe even 24.5. Removing limiters can be a pain. I would try unscrewing the front shocks 1 turn at a time to see if you like the droop changes.
