Team Associated B4.2 Thread >
Like Tree4Likes
Old 03-14-2013 | 09:59 AM
  #2836
Originally Posted by Wildcat1971
I would like to see the track change during the heats. That is the way I race, lol. Different tires and minor setup changes for each round..... And if the wind blows, the track changes even more. Lol, we should just race carpet or astroturf, lol.
You would be susprised how fun carpet offroad is if you have not tried it before.
micrors4guy is offline
Old 03-14-2013 | 10:10 AM
  #2837
Wildcat1971's Avatar
lol, I kinda prefer dirt. Too much traction lets bad people look good. On a loose track, you need a good trigger finger. So easy to go around the track on rails. But I understand that want all of the qualifiers to be fair. At my track, it would be impossible to keep it fair. even between heats 1 and 2, lol. Heat 1 gets a very wet track that will require you to clean your tires, heat 2 gets a much drier track with clean tires, lol.
Wildcat1971 is offline
Old 03-14-2013 | 10:13 AM
  #2838
I have raced on carpet. The fast will still be much faster and the other guys will be more predictable so its accually easier to pass them. I still enjoy dirt also. Its just fun to have options to challange yourself
Old 03-14-2013 | 10:22 AM
  #2839
Eli's Avatar
Eli
Thumbs up Factory one
Live rc hooking factory one up with some love. Heres the link: http://www.liverc.com/news/new_produ...is_protectors/
I will have one of these bad boys soon to test out.
Stay tuned for some of their other products coming out soon. For example, the big bore ultra bushings and a few different tire brushes for various uses.
Eli is offline
Old 03-14-2013 | 10:24 AM
  #2840
aeRayls's Avatar
Originally Posted by Bob Barry
Tire bill isn't as crazy as you may think though. I mean if you go nuts on practice, sure.
But even if you had to put 'new tires' every run... That's what, 7 runs max IF you made the A's. And if you made the A's, one would assume you have sponsor help for tires anyway .
And trust me, it's no different now than to do it like we did back then. Buy 7 pairs of tires or 4 batteries, 2 or 3 motors, AND 4 sets of tires.
Oh believe me I'm not disagreeing with ya... But thats for 1 class!! There's is no way I'd only run 1 class at a 500 entry event. I'd do 3.... In modified to have your best shot you're going to run a new set every qualifier. Probably 2 MAYBE 3 practice runs a set. At a minimum with 3 classes... You'll go through 6 sets of rears in practice. For the quals you're going to mount up all new fronts as well. So that's 15 pairs for qualifying... Even with a 50% deal... Yikes!!! For a privateer!!!! God damn!!! LOL $$$$$$$
Traction is great, but it makes crappy drivers look better and the problem is that too many people think they are faster than they are!!
Believe me, I'd rather be racing on ifmar studs or ifmar pins outdoors!!!!
aeRayls is offline
Old 03-14-2013 | 10:28 AM
  #2841
Eli's Avatar
Eli
^^^Exactly why i didnt go, plus getting the extra time off work was gonna be a pita.
Eli is offline
Old 03-14-2013 | 10:51 AM
  #2842
asc6000's Avatar
I took over 100 sets to the nats with my XX back in the day, I still have a lot of them including a new mounted set of Losi7364S Ifmar Studs.
I'm happy just to not need 4-6 batteries per class now with multiple chargers and dischargers and matchers, not to mention a box of motors and all the assorted support equipment like motor lathes, dynos, magnetizers, and new brushes every run. Racing is much cheaper now than it was 20 years ago. Well, maybe the $9 tire foams are ridiculous...
One tire I would love to see back from the dead is the CRP 4223, that thing had crazy grip due to the rubber that no one else had.
asc6000 is offline
Old 03-14-2013 | 10:54 AM
  #2843
+1 to studs
Anyway, A month or so ago, I commented to my wife that the novice drivers are a lot better than the novice drivers 10-15 years ago. At first i thought, well the advances in the cars. I think that is part of it, but I think its tires and new style tracks. Plus the lack of drag on brushless systems. I remember novices going hard into a corner, letting off and spinning out or pushing all the way into the pipe. A few weeks ago, the track was REALLY loose. Like rooster tails all the way around. Several of the drivers were complaining and refused to practice. I was like, so what you cant stomp the throttle and must use some control.
Old 03-14-2013 | 03:58 PM
  #2844
Cain's Avatar
Tech Legend
anyone got an opinion on these:
http://www.exotekracing.com/b4-b44-s...-rear-hub-set/
Cain is offline
Old 03-14-2013 | 04:14 PM
  #2845
Waflet's Avatar
Originally Posted by Cain
Hideeho
Aside from the fact that they are a-tower only, they seem to be good. I've used exotek stuff on other vehicles & seen the sc10 4x4 chassis in use. From what I've seen they make a good product. That said, if I were getting new aluminum hubs they would be the yaiba hubs. The yaiba hubs are still the only ones that are 0*, c-tower height (shim to get to a-tower), & vertical studs.
http://www.tresrey-usa.com/yaiba-rac...num-rear-hubs/
Waflet is offline
Old 03-14-2013 | 04:26 PM
  #2846
Originally Posted by Waflet
Hideeho
+1
Old 03-14-2013 | 04:49 PM
  #2847
Hideeho
Jason Haas runs these. He's said countless times that you get C hub height by running the short neck ball studs.
Bob Barry is offline
Old 03-14-2013 | 04:53 PM
  #2848
they are 2mm shorter?
Old 03-14-2013 | 04:56 PM
  #2849
bds81175's Avatar
Moderator
+1 I run them and like them quite a bit. They don't have set screws to lock onto the hinge pin and the outside hole isn't a through hole so if you break off a ball stud you might have a tough time getting it out. But the machining is fantastic. VERY tight fit with the bearings.
bds81175 is offline
Old 03-14-2013 | 05:17 PM
  #2850
they dont thread through? hmm, that is not good. getting a broken stud will be hard
