Team Associated B4.2 Thread >
Like Tree4Likes
Old 04-13-2013 | 08:17 AM
  #4186
BRSracing's Avatar
Originally Posted by joelwhite
How cool!!
Its the new B5 finally
BRSracing is offline
Old 04-13-2013 | 08:39 AM
  #4187
Waflet's Avatar
Hideeho
Roflmao!
Waflet is offline
Old 04-13-2013 | 09:07 AM
  #4188
huzzler's Avatar
I wish they would re-release the gold pan. Hey they say history repeats itself.
huzzler is offline
Old 04-13-2013 | 09:22 AM
  #4189
Waflet's Avatar
Hideeho
On a more serious note...
What would you change from the b4.2 to make a b5?
+7 more on chassis? Been there, done that, all but ready to come back. It's easier to drive when the skill level is not that high, but as my skill level is increasing & I'm about to the point where the shorter chassis & quicker handling would be a bigger help than slower reactions when sliding.
Aluminum chassis? Seems like a good idea on the surface, but the plastic chassis flexing helps the handling. If an aluminum chassis flexes any significant amount it will bend or warp. Just ask the 22 drivers.
Carbon fiber chassis? Again seems like a good idea, but again no flex or it breaks. Then again cf works very well for the b44 series & Schumacher. I would think cf would be a better option than aluminum.
Narrow nose with longer, maybe gullwing front arms? That's a possibility, but if its too much narrower there will be structural issues.
Redesigned front end to allow adjustable kick up, like an 8th buggy? This would be on top of my list if I were working on it.
Easier/more adjustable rear anti-squat/toe? This would be #2 on my list. Again, look at how a 1/8 buggy does it.
Mid engine? Jury is still out on this one, but x-factory seems to be able to get their cars to handle on dirt pretty well. I would be HIGHLY interested to see what AE could do with the design concept. Making it convertible is terribly convenient, but is terribly compromised, unless the conversion is a huge conversion & requires a ton of parts to do.
A true limited slip differential? This would have as big or bigger impact on the rc world as lipos & brushless combined! But, I don't think it's doable for a reasonable price.
What else would everyone like to see on a b5? Keep in mind a b5 would probably start with a clean sheet of paper, so the sky is the limit.
Waflet is offline
Old 04-13-2013 | 10:09 AM
  #4190
bds81175's Avatar
Moderator
Way back in the day, I had a foam core carbon fiber sandwich RC10 chassis that was relatively stiff (but definitely not as stiff as the other carbon fiber chassis at the time), tough, and super light. I think you could model the chassis design with the thickness of the sandwich slices to get optimal stiffness, especially if you increased the thickness of the carbon fiber in specific areas. The other nice advantage of the carbon fiber sandwich is you could add weight down the center of the sandwich stack which would keep your center of gravity super low.
Speaking of back in the day, my brother had an RC10 with externally adjustable rear toe that you adjusted through a slot in the bottom of the chassis as I recall. It wasn't very durable but the concept was great and with todays manufacturing/design technology we should be able to make one that works better. I would agree on the front kick up. Having that adjustment available would be pretty nice.
I would also like to see captive rod ends with high resolution and simple roll center adjustability.
What about some form of droop adjustment? I kind of appreciate the droop screws on my 4x4 sct.
I actually think there is quite a bit more risk for AE to step out and come up with a new design from scratch as opposed to Schuey, TLR or Kyosho. If they come out with a new design and it isn't quite what they hoped it be a huge, glaring black eye. If Kyosho comes out with a Triumph (yikes!!)....no big deal.
bds81175 is offline
Old 04-13-2013 | 11:25 AM
  #4191
Current chassis length is fine, IMHO
I prefer aluminum over carbon fiber sheets.
I would prefer two purpose built buggies, but I'm ok with a convertible chassis, so long as they do their homework and design it to utilize both layouts to the max.
Ball diff is fine. I'd like to see ceramic thrust balls included.
Some things I'd like to see:
- Narrow Aluminum chassis, with tunnels for the servo/esc wires.
- Adjustable Battery holders (ala RB6) so that you don't have to use foam to hold into a shorty.
- I don't mind a RM/MM convertible chassis, but would rather see two purpose built kits (maybe a US version and a Euro version).
- Metric screws
- Teflon shock bushings
- Ceramic Thrust balls
- Ceramic diff balls (cause WildCherry says their better).
- Wing mount that use screws
- Adjustable kickup
- Vertical ball studs for camber links (I know some will disagree, but I like the finer adjustments you can get with the ballstuds in a vertical position)
- Delrin upper shock bushings
- Rear toe mounts in aluminum with teflon inserts (see SpecR R1 design).
In other words, I'm not asking for a lot.
JiuHaWong is offline
Old 04-13-2013 | 01:08 PM
  #4192
- Narrow Aluminum chassis, with a tunnels for servo/esc wire.
- Metric screws
- Adjustable kickup
love your suggestions....
Most of all......... Metric hardware!
would like to see alum chassis that has more 'centered' electronics philosophy.
revised suspension parts built around the 12mm shocks (nothing drastic, just make things fit properly with out grinding or rubbing)
redesigned rear hubs, maybe even in plastic, that don't wear as bad as current ones,
no more battery foam (seems petty, but adjustable brace is just a better solution)
I like the idea of adjusting the rear toe with blocks on the back of the hingepins rather the front...just allows for quicker changes.
Arms that support flex tuning plates for high bite surfaces.
Bob Barry is offline
Old 04-13-2013 | 01:56 PM
  #4193
Default New b4.2 shock problems
Hi just got my RC10 b4.2 built im having a problem with the upper shock mount. The shock cap is very tight when its installed on the shock tower mount. Should i sand it or drill the shock cap. thanks
kevdogb3 is offline
Old 04-13-2013 | 02:19 PM
  #4194
brian cox's Avatar
I chuck my shock bushings in a drill and sand the anodizing off the ball end with some maroon scotch brite..seems like the tolerances are just a bit off..
brian cox is offline
Old 04-13-2013 | 02:28 PM
  #4195
Jake S's Avatar
Leading the way is 4x World Champion Ryan Cavalieri who will start 4th. Next up is Kody Numedahl and Brent Thielke in 7th and 8th. All three drivers are using the CML C4.1 conversion for the B4.2
Jake S is offline
Old 04-13-2013 | 02:37 PM
  #4196
Tradin Paint's Avatar
Wonder why Maifield didn't attend?
Tradin Paint is offline
Old 04-13-2013 | 03:02 PM
  #4197
Wildcat1971's Avatar
I think some used simple green and that worked. The work around was posted here
Wildcat1971 is offline
Old 04-13-2013 | 05:05 PM
  #4198
snowman_evil's Avatar
Has anyone tried the CML C4.1 conversion? If all those guys from associated are using them it must be pretty damn good. Is there a certain type of grip/track that suits it more specifically? What's the pro's and con's of a mid motor configuration vs standard?
Also where is the best place to buy it from?
Thanks!
snowman_evil is offline
Old 04-13-2013 | 05:42 PM
  #4199
Matt Trimmings's Avatar
Thanks!
The only reason they are using it is because they are racing on carpet. Brent went to that race last year as well and ran it. You have to get it from CML or a distributor. Mid motor is more for the higher grip tracks like carpet or anything similar. Rear motor should prevail in anything less than that.
Matt Trimmings is offline
Old 04-13-2013 | 06:51 PM
  #4200
neallewis's Avatar
Originally Posted by F18engineguy
I would be fine with that if there really was a new car coming out next year. Do you have reason to believe there will be a new car out? Considering that they just did the upgrade to the worlds car this year I just don't think we will see a new car out that soon. AE does not move that fast. Thoughts?
They just need to make a plastic tub chassis and gearbox case for the Centro C4.1. Everything else is done.
neallewis is offline
