Team Associated B4.2 Thread >
Like Tree4Likes
Old 06-03-2013 | 05:55 PM
  #5836
Wildcat1971's Avatar
push? pfff drive a 22 and I will show you push..... lol.
is your rb6 pushing? just curious to how it is working out for you.
Wildcat1971 is offline
Old 06-03-2013 | 05:56 PM
  #5837
Suspended
Rb6 is fine
Team G Racing is offline
Old 06-03-2013 | 06:05 PM
  #5838
btw, stop saucing your rear tires and you wont push
Old 06-03-2013 | 06:18 PM
  #5839
Suspended
I don't only at W3.
Old 06-03-2013 | 06:27 PM
  #5840
SCDriver's Avatar
I moved the battery around too and it didnt help me either, but I cant move it far since its a full size pack.
SCDriver is offline
Old 06-03-2013 | 06:29 PM
  #5841
Suspended
I run a shorty and It helped a little.
Old 06-03-2013 | 06:32 PM
  #5842
the shorty makes the b4 quite a bit more nimble.
Old 06-03-2013 | 07:41 PM
  #5843
Jake S's Avatar
Originally Posted by D.Martijn
I think the length of your tray is also around 40mm?
i measured it and its 48mm. sticks out alittle from the speedo in the front, so i dont see 45mm being a problem either, as long as you run 2mm spacer for full pack. like i said 1mm spacer works with a full pack on my setup, but id suggest the 2mm - i have not cared to change mine back to 2mm.
Jake S is offline
Old 06-03-2013 | 07:42 PM
  #5844
Jake S's Avatar
i run the wts pack with no weight for indoors, so basically a shorty, with the esc in the 'norm' spot i ran full pad in the front, on the shelf i run thing pad in the front on it.
Jake S is offline
Old 06-03-2013 | 07:47 PM
  #5845
silveraider14's Avatar
I lightened up my front shock oil and changed my tires from green barcodes to m4 suburbs and it is awesome!
silveraider14 is offline
Old 06-03-2013 | 08:34 PM
  #5846
So I havn't raced since december and most of the setups I see are using the front carbon arms, top plate, and u brace. Is everyone else using the carbon mods?
chancejeff is offline
Old 06-03-2013 | 08:35 PM
  #5847
BLKXJ96's Avatar
I have been running my B4.1/2 three days a week for about the past four weeks at the local track. I have ask all the fast guys about their set up as far as tires and shock oil and pistons and foams and battery position. I have come to the conclusion that not everyone's setup will work for me, even with their best efforts to try to help. In the last week I stopped banking on what works for everyone else, and started to learn what works for me and my driving style by trial and error. Granted i'm not running the same springs or times as the fast guys but I shaved about two seconds off of "my" lap times in a week.
I appreciate everyone's help at the track greatly, but I feel I used their info to help me learn more about my car and how to tune it in the right direction.
BLKXJ96 is offline
Old 06-03-2013 | 09:02 PM
  #5848
That's a good way to go about it. Pretty much what I do is trial and error too. I learn a lot that way. I wouldnt expect to copy my local pro setup it just wouldnt work. However I can tell him what is wrong with my car and he can help me get it tuned in faster. Just make sure you are asking the right question "What spring should I run" Not "what are you running".
chevmaro is offline
Old 06-03-2013 | 09:25 PM
  #5849
Suspended
This is what most people asking for setups don't understand
PFKAOG is offline
Old 06-03-2013 | 09:32 PM
  #5850
Wild Cherry's Avatar
Tech Legend
One thing I have learned though the years is to trust the Ae factory driver's set-ups because they are proven to perform well ...
Better then guessing and learning the hard way ....
Wild Cherry is offline
