Team Associated B4.2 Thread >
Like Tree4Likes
Old 06-03-2013 | 10:27 AM
  #5806
Wildcat1971's Avatar
Originally Posted by D.Martijn
Shelf is 40mm long, I looked at some other shelfs and I'm not much off I think.
An esc is already 30 x 30 and the lrp flow is almost 35 x 35.. + the motor wires.
I would use a smaller receiver to save weight. Yours is from 1968 I think..
Wildcat1971 is offline
  #5807
D.Martijn's Avatar
Originally Posted by Wild Cherry
Martin
try installing the battery first and make sure it will fit under the shelf .
I will, that's why I made a 3D print.
Shorty will fit direct, stick pack might be close, I think you'll have to add 2mm spacers under the shelf.
D.Martijn is offline
Old 06-03-2013 | 10:29 AM
  #5808
D.Martijn's Avatar
It's just an 3D drawing I downloaded and added my pieces.
Got the micro receiver from Spektrum, don't worry
Old 06-03-2013 | 10:30 AM
  #5809
I would look into maybe supplying the shims with the sale if its cheap enough. Buyers hate to have to shop for extras. I would want it to be able to get a full length pack under it. I think cav ran a wts in his right?
  #5810
No shims needed. I just made a shelf from old servo box. Full size pack fits nicely.
Toyman is offline
Old 06-03-2013 | 10:32 AM
  #5811
Wild Cherry's Avatar
Tech Legend
Default Magical Shelf Mod
Now you got it , no shims , just keep it short enough to be able to slide the pack in .
Have to tilt the pack up quite a bit and makes a tight fit .
Wild Cherry is offline
  #5812
D.Martijn's Avatar
I'll have to look for those shims.
Yes, Cav ran a full stick pack, I'll tell you Wednesday if the full pack fits or not.
Old 06-03-2013 | 10:36 AM
  #5813
yep, that is the same issue with the 22. The receiver and big esc's can make it a pain to get the pack in and out.
Old 06-03-2013 | 11:26 AM
  #5814
Originally Posted by Kellen Guthrie
The b4.2 does not jump as well but it has wayy more forward bite than the rb6, has a large tuning window, and is much more forgiving to drive. With the rb6 you need to be good at setup and very smooth to go fast.
Guys, thank you all for your feedback regard RB6 and B4.2. appreciate it
noworries is offline
Old 06-03-2013 | 11:58 AM
  #5815
Jake S's Avatar
using wts with mine. i have to take the battery pad out to get mine to slide in, but once its in i can put the foam back in, using the old brace and 1mm spacers on both sides... 1mm = not sticker friendly, 2mm = sticker friendly
https://fbcdn-sphotos-b-a.akamaihd.n...80924935_n.jpg
(link for reference w/o esc mounted)
Jake S is offline
Old 06-03-2013 | 01:21 PM
  #5816
D.Martijn's Avatar
I think the length of your tray is also around 40mm?
Old 06-03-2013 | 02:38 PM
  #5817
so i decided on buying the b4 instead of the b44 so ill learn how to drive better.
can you tell me what you think of my "shopping cart"?
gen2 8.5 motor and esc combo. (8.5 is good for the car?)
rpm 4-40 ball cups.
how much power do i need from the servo? cos the weaker it is the fastest.
and what do you say about this battery?
http://www.amainhobbies.com/product_...-ROAR-Approved
ho, i saw the thing about flattening out the esc tray or something. can you explain me about it?
any other tips in building it? any upgrades?
ebay007 is offline
Old 06-03-2013 | 02:45 PM
  #5818
Suspended
rpm 4-40 ball cups.
Tekin has good customer support, but I have not had luck with there ESC's. Every one I have owned I have had issues with. That being said, I would check out the LRP/Reedy combo, or check out Orion. I love the Orion's and Hacker's esc's. (Orion and hacker have the same ESC just different coloring). 8.5 is plently for the car. Ball cups are good. The battery I would recomend using the Protek batteries or check out the High Velocity Racing batteries. Those are 2 of the best batteries I have used. Not a fan of the electron items.
Building it, make sure your arms fall freely, and TAKE YOUR TIME!! Anybody can have a kit done in 4 hrs, but just make sure you follow the instructions. Hope this helps you out a bit
Team G Racing is offline
  #5819
rpm 4-40 ball cups.
8.5 is a lot of motor. If you are learning how to drive better I would get a 17.5. Stock buggy can be fast and a lot of fun. I would get this:
Product(s) Price Qty. Total
Team Associated Factory Team B4.2 2WD Competition Electric Buggy Kit ASC9041 - Team Associated Factory Team B4.2 2WD Competition Electric Buggy Kit
Note: This item is not eligible for FREE Super Saver Shipping
$279.99 $279.99
LRP Flow Competition ESC & Vector X20 StockSpec Brushless Motor Combo (17.5T) ASCLRP81112 - LRP Flow Competition ESC & Vector X20 StockSpec Brushless Motor Combo (17.5T)
$259.99 $259.99
ProTek R/C 100SS Standard Digital "Super Speed" Metal Gear Servo PTK-100SS - ProTek R/C 100SS Standard Digital "Super Speed" Metal Gear Servo
$49.99 $49.99
ProTek R/C 2S "Supreme Power" Li-Poly 100C Hard Case Shorty Battery Pack (7.4V/4300mAh) PTK-LPH-4300-2S100-S - ProTek R/C 2S "Supreme Power" Li-Poly 100C Hard Case Shorty Battery Pack (7.4V/4300mAh)
Note: Lithium batteries cannot be shipped internationally via USPS; shipping more than 2 internationally is now subject to HAZMAT, with fees and limited availability
$89.99 $89.99
RPM Heavy Duty 4-40 Rod Ends (Black) (12) RPM73372 - RPM Heavy Duty 4-40 Rod Ends (Black) (12)
$4.59 $4.59
RPM Long Shank 4-40 Rod Ends (Black) (12) RPM73392 - RPM Long Shank 4-40 Rod Ends (Black) (12)
$4.59 $4.59
Enter Coupon Code
Sub-Total: $689.14
Part of this order is eligible for discounted Super Saver Shipping!
chevmaro is offline
Old 06-03-2013 | 02:46 PM
  #5820
that battery is fine. I have one that is over a year old and it still works great.
