Team Associated B4.2 Thread
#7338
#7341
#7344
Live and learn I guess.
#7346
#7347
Just finished my transmission and slipper assembly tonight. Everything is really smooth, but that slipper assembly is massive!! Does the new slipper really provide anything significant over the last version?? It almost looks over-engineered or over-complicated. Just curious.
#7348
They are using c4.1 conversations. The C4.2 are not ready just yet. You can be sure they they will have them for the worlds most likely the Nats. Also if the chassis you see are silver color they are extended 10mm chassis made by a guy in the UK Tony Parr. Most all the UK Centro/ team associated drivers use this chassis. If you see them with a black chassis then it's a Centro.
It looks like the rear tower and wing mounts are AE. The c4.x used screws to mount the wing. And the tower looks different to me. The tranny case "looks" like the c4.1 case, but its so basic and plain it could be a protype or just the c4.1 tranny. The entire front end is a b4 front end with what looks to be brass posts up front. I dont think AE used the brass bulkhead though. The battery mounting system looks the same to me. The chassis could be different. Alum proto chassis are pretty easy to make, but I kinda think its a c4.x chassis. Since so many AE parts are used in the conversion, I can only imagine that chassis and tranny would be the main focus for improvement. i.e. flex, length, tranny height, etc. And like I said the rear tower looks different. But to my untrained eye, it looks like a b4.x with 98% of the c4.x conversion.
#7349
Man Avid comes up with some great products for the B4.2. Just saw that new adjustable ESC center mount. Allows you to run Reg and Short batteries. Allows you to slid the esc forward and back to adjust where you want the weight. Looks like a nice piece.
http://www.avidrc.com/product/5/acce...cessories.html
4Likes
