Team Associated B4.2 Thread >
Like Tree4Likes
Old 07-31-2013 | 08:49 PM
  #7486
WILDWILLIE 9's Avatar
How do you know when you need to run mid motor? Or how do you know what surface is going to be better to use mid motor over rear motor?
WILDWILLIE 9 is offline
Old 07-31-2013 | 09:59 PM
  #7487
BIGSKI15's Avatar
Which front tires are more aggressive, ribbed or bar type tires? My jc green rips seem more forgiving and less twitchy compared to my green barcodes making it easier to drive on certain tracks. Just curious if this is normal for most people.
BIGSKI15 is offline
Old 07-31-2013 | 10:07 PM
  #7488
Wildcat1971's Avatar
ribs can be kinda grabby. it really depends.
Wildcat1971 is offline
Old 07-31-2013 | 11:25 PM
  #7489
Cridd's Avatar
Ribs are supper grabby for me. I would think in silty loose dirt they would be good....or gravel, bashing arenas.
Cridd is offline
Old 07-31-2013 | 11:38 PM
  #7490
fatbear's Avatar
Easy, run a mid motor all the time and you can't go wrong.
fatbear is offline
Old 07-31-2013 | 11:45 PM
  #7491
slashracer111's Avatar
I feel that the treaded-ribbed front tire is solely dependent on track. It's best to have both and find out for yourself what works. Driving style also effects the front tire choice.
It seems like a treaded barcode or scrub works fantastic on a packed surface, but is awful on anything with loam, dust, or loose dirt.
The JConcepts Rips are the most consistent front tire I've ran. They don't seem as edgy or aggressive as your standard 3 or 4 rib front tire like the Proline 4-rib or the JConcepts Groovy.
I have personally never gotten my B4.1 or B4.2 to turn on a treaded front tire. The tracks I run on and my driving style just don't cater to anything but Rips.
On another note a few pages back, everyone was flipping out about the camber link rubbing on the rear shock bodies. I just finished up my B4.2 minutes ago. Has anyone mounted their hub towers like I have? I just moved it to the rear of the hub, which moved it 2-3mm. It look's a little goofy, but I'd rather have free movement.
slashracer111 is offline
Old 08-01-2013 | 04:14 AM
  #7492
Grasschopper's Avatar
Yes I can run that way with the C hubs but not with the A or B as I get wheel rub.
Grasschopper is offline
Old 08-01-2013 | 05:33 AM
  #7493
those A hub uppers will rub the wheel
Old 08-01-2013 | 05:54 AM
  #7494
I REALLY want a set of the Yaiba hubs in blue ano. Love the vertical ball stud. Maybe I get a set and get them black anodized with stuff from work.
Old 08-01-2013 | 06:02 AM
  #7495
or just sharpy them... lol. because of all my avid bling, my car is mostly black. if I got red washers and front pin brace, then the hubs would look fine. the red and blue mixed is not great looking though.
Old 08-01-2013 | 06:20 AM
  #7496
The red won't look good with my paint scheme. And I'm too AR to sharpie them...won't look right to me...yes even though you can't see them unless the wheels are off.
Old 08-01-2013 | 07:56 AM
  #7497
Oh.
I haven't put wheels on my car yet in my defense.
Thanks though. I was unaware.
Old 08-01-2013 | 08:30 AM
  #7498
Ok I want to confirm what I believe to be true. The transmission housing for the gear diff and ball diff are the same. Correct?
So if I want to convert from a gear diff to a ball diff I need the ball diff (outdrives, rings, main gear, balls etc) and that's it. Is that also correct?
Old 08-01-2013 | 08:38 AM
  #7499
aeRayls's Avatar
Yes, buy a complete ball diff and it'll drop right in.
Make sure you buy the "sc10 ball diff" it's what fits the metric bearings.
aeRayls is offline
Old 08-01-2013 | 08:58 AM
  #7500
Thanks. It's actually cheaper to buy the parts separately for some reason. So follow up question: ASC7677 Diff Rebuild Kit includes balls. Are those the diff balls or the thrust balls? The photos seem to show 6 balls so I'm guessing they are the thrust balls but thought it best to confirm.
And I guess another question would be is the MIP kit better than the AE kit? I would get BFast but AMain doesn't sell them and I'm putting together an AMain order.
