Like Tree3Likes
Tamiya TRF415
Old 11-03-2004 | 12:42 AM
  #4606
SpeedTech's Avatar
Originally posted by razzo
Another WOW.
I guess for those of us who race on carpet indoors only, we can't even fathom that gear ratio.
US seriously needs more tracks like Tamiya track, you guys in CA are spoiled.
5.76 is where I ended up gearing at the KO race. For 23T TCS Nationa...we were down to 5.6 something
Steve Wang
SpeedTech is offline
Old 11-03-2004 | 09:06 AM
  #4607
Just wondering if anyone has tried a spool on carpet 19T and what your opinions are about using a spool on carpet and asphalt.
Ive tried it on carpet in stock and like it almost as much as a diff. A front diff is a little smoother than the spool going into a turn and mid corner, but the spool had a little more rip out of the corners. my lap times have become more consistant than with a one way.
Cheerz
Obsidian is offline
Old 11-05-2004 | 04:55 AM
  #4608
Fatboy Joe's Avatar
Speedtech: Hi, do you have spools available for the 415?
To everyone: Any basic spool set-up for the 415? Thanks in advance
Fatboy Joe is offline
Old 11-05-2004 | 05:42 AM
  #4609
Default Setup With Spool
I am very surprised with how quiet it has been considering Marcs win. I really want to try a spool and get my car setup with one and after marcs win i thought people would be talking alot. I run standard suspension with 1degree rear uprights. I tried one on carpet a couple weeks ago with T27 tires and it was really good. I just want it to be a bit more agreesive. I noticed marc was running no spacers under rear wishbones. This mean he was running evo blocks or that he had taken the 1mm out. This will make what difference?? Ive always found the rear to rotate more and make it more twitchy but people will no doubt disagree. Want a good high corner speed spool setup using old suspension, something like some of Tamiya team used at Reedy Race.
Rob
Robz is offline
Old 11-05-2004 | 08:43 AM
  #4610
rtypec's Avatar
DS, this is Rod...here are the links to a couple of the Tamiya America setups. One for spool and the other for one-way.
As for changes on the spool setup, I think I ended up using a C/A or D/A front suspension block setup to get more mid-exit steering. I also used yellow sway bars all the way around.
I hope this helps.
415 One-Way Setup
415 Spool Setup
rtypec is offline
Old 11-05-2004 | 09:48 AM
  #4611
×Ç|®8tËÐ's Avatar
Anybody have a good setup for me to use on a high traction ozite track, long track, stock motor and foam tires??
Thanks!
Also if I put a spool for the mod class, did I need the center locked pulley???
×Ç|®8tËÐ is offline
Old 11-05-2004 | 09:56 AM
  #4612
koabich's Avatar
Thanks!
Look a couple of pages back. I posted my carpet setup for a tight track....It should be pretty close.
koabich is offline
Old 11-05-2004 | 11:23 AM
  #4613
Hebiki's Avatar
Default Lightweight suspension review
hey guys.. i wrote a review on the lightweight suspension kit for the 415 if you guys wanna read it. you can check it out at our team website.
www.taobracing.net
Hebiki is offline
Old 11-05-2004 | 02:06 PM
  #4614
dawgmeat's Avatar
Default LW conversion
I plan on using 28mm foam with the LW conversion will it exceed 190mm?
dawgmeat is offline
Old 11-05-2004 | 03:54 PM
  #4615
TJ's Avatar
TJ
rtypec:
Is these setups with the LW convertion kit on it?
I hope this helps.
415 One-Way Setup
415 Spool Setup
TJ is offline
Old 11-05-2004 | 04:19 PM
  #4616
Hebiki's Avatar
Originally posted by TJ
rtypec:
stock suspension.
Hebiki is offline
Old 11-05-2004 | 04:38 PM
  #4617
linger's Avatar
Default Re: LW conversion
With 28mm foams, it's hard, if not impossible to fit the tires and stay under 190mm. The front steering knuckle interferes with the tire near the steering tie rod....not a whole lot you can do about that.
linger is offline
Old 11-05-2004 | 04:45 PM
  #4618
Default Re: Lightweight suspension review
www.taobracing.net
Nice article. Is there a part number out yet just for the arms?
Thanks,
A-Ko is offline
Old 11-05-2004 | 05:33 PM
  #4619
rtypec's Avatar
rtypec:
Nope, I've got a set but have not put it on yet
rtypec is offline
Old 11-05-2004 | 06:08 PM
  #4620
BlackKat's Avatar
Hey guys,
Got some snapshots of the new Parma Alfa painted up!
http://photobucket.com/albums/v207/TheBlackKat/
Not the best pictures on earth (improper lighting) but they'll do until some sunshine hits us
BlackKat is offline
