Old 10-27-2004, 01:24 PM   #4456
dawgmeat's Avatar
Default Spare parts
Originally posted by forty6
You can also get 10mm shims to take out some play and center the pulley better.
thankx budd
dawgmeat is offline   Reply With Quote
Old 10-27-2004, 01:45 PM   #4457
koabich's Avatar
Send a message via Yahoo to koabich
I would get some extra blocks such as the front block 1A. Also some extra C and D blocks.
I have been running it on carpet and it is a great car. I have yet to break anything with the exception of the Aluminum Ball Studs on the steering knuckles.
koabich is offline   Reply With Quote
Old 10-27-2004, 01:53 PM   #4458
dawgmeat's Avatar
Are you running diffs or oneway,push come shove I'll run oneway on carpet
Old 10-27-2004, 02:16 PM   #4459
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Curious...
every post ive read concerning the 415 and carpet is everyone needs a diff... is this for Mod/foams only? or everything in general? (i.e. stock/rubber, 19T/rubber, 19T/foams, etc)
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 10-27-2004, 02:16 PM   #4460
Formula1fan's Avatar
SpeedTech and Hardriven RC thank you for your help. Speedtech I will include them on my next order.
Formula1fan is offline   Reply With Quote
Old 10-27-2004, 02:17 PM   #4461
dawgmeat's Avatar
Default Re: Curious...
Stock and 19t
Old 10-27-2004, 02:18 PM   #4462
Hebiki's Avatar
Default Re: Re: Curious...
Originally posted by dawgmeat
Stock and 19t
i must be retarded then me and a friend ran on carpet last weekend with dual one ways (front/center) and the car was dialed. i didnt see anything wrong with the car.
Hebiki Design Works
Old 10-27-2004, 02:45 PM   #4463
razzo's Avatar
Send a message via Yahoo to razzo
double one way works great with rubber tires on carpet, but if you're planning on running Foams (especially Mod), forget about it! With so much more available grip, you'll push like hell coming in and out of corners. You can make one ways work with foam, I've done it before on 414X/414M, but you'll be slower then running a diff in the car, since you have slow WAY down for corners. With diffs and foam, you can get on the throttle LOT sooner then oneway, and get off the throttle LOT later going into a corner then oneways.
edit.. also far as spare parts for running foam/carpet, stock up on front C-hubs! and swing shafts. Might want to get some 2 degree ones too for foams. if you hit the barriers HARD, this is the part that fails first. It's also the only 'non' graphite part)
razzo is offline   Reply With Quote
Old 10-27-2004, 02:49 PM   #4464
dawgmeat's Avatar
Running CRC foams, whats killing me is that it that Speedtech seem to the only one in the us that sell spare parts and the one thing i need they don't have in stock 35T diff pulley.
Old 10-27-2004, 02:53 PM   #4465
razzo's Avatar
dawgmeat, check Tower Hobbies. That's where I got my 415 diff pulley last week, along with rear aluminum hubs. (Speedtech has been out of them for a while). Also, not sure if you're aware or not, all the suspension parts are SAME as TA04 parts, (knuckle, arms, c-hubs, rear hubs) Lot of shops carry TA04 parts, but not specific 415 parts. Tower has lot of 'spare' parts for 415, I've been using Speedtech and Tower, when I can't get stuff from my LHS (which uses Horizon, another place that carries 415 parts)
Old 10-27-2004, 02:55 PM   #4466
dawgmeat's Avatar
Default Gear adapter
can you run the standard gear with the stock set up, sorry for all the questions today, hust I know what I need before I order this car with parts all in shot.
also I can't find the part number for any spare A-arms
Old 10-27-2004, 03:12 PM   #4467
razzo's Avatar
dawg, check your PM!
Old 10-27-2004, 03:25 PM   #4468
razzo's Avatar
53427 is part # for arms. About $17.00, includes 2 front and 2 rear arms.
Old 10-27-2004, 03:35 PM   #4469
|8t
|8t's Avatar
What about the front spool? When we should use a front spool/locked diff???
|8t is offline   Reply With Quote
Old 10-27-2004, 03:38 PM   #4470
dawgmeat's Avatar
Once again thank you to everybody for helping and with a little overnite epress i'll be part of the 415 family!
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
