Like Tree2Likes
Tamiya TRF415
Old 09-16-2004, 08:02 AM
  #3856
racer's Avatar
Default Re: Re: Re: Evo 3 diff outdrives
Originally posted by wiget
Thank you !
no problem
racer is offline
Old 09-16-2004, 09:08 AM
  #3857
gcooper's Avatar
Originally posted by linger
Close, but not quite.
..I'm measuring them right now.
Measured distance of hingepin centerline above chassis:
414 = 4 mm
415 = 5 mm
Evo3/4 = 6 mm
All the screw holes match up.
The 415 A block, the Evo3/4 A block and the "no dot" 414 block are exactly the same width.
Thanks Linger for your help.
Coop
gcooper is offline
Old 09-16-2004, 11:39 AM
  #3858
SpeedTech's Avatar
Originally posted by Dragonfire
Out of Stock!!!
Have ordered my new 415 but I need the arms to go with it!
Anyone know where I can get these arms from??? (on-line)
We should be getting them in either end of this week or next week. We just put in a huge order with Tamiya USA Also, we have a good shipment of Square hop-up parts coming in for the TRF415 as well. That should be arriving next week too.
Steve Wang
SpeedTech is offline
Old 09-16-2004, 12:28 PM
  #3859
Kenshin's Avatar
414 = 4 mm
415 = 5 mm
Evo3/4 = 6 mm
If this is the case, why didn't Tamiya just include the Evo3 blocks (since it is 1mm higher) instead of the 1mm spacer that is needed underneath the 415 blocks?
Kenshin is offline
Old 09-16-2004, 01:21 PM
  #3860
the option of not running the shimms? lots of people do this indoors
Evo_Uk is offline
Old 09-16-2004, 01:36 PM
  #3861
Greetings everyone,
Does anyone know the website address to Square racing products?
Cheerz
Obsidian is offline
Old 09-16-2004, 01:49 PM
  #3862
Steve Wang
cool...
will keep the car all tamiya for now tho so not really interested in square.
Now where can I pick up a V2???
Dragonfire is offline
Old 09-16-2004, 02:46 PM
  #3863
Turbonium's Avatar
Trader Rating: 27 (100%+)
Originally posted by Obsidian
Greetings everyone,
Cheerz
if i remember right, its www.rc-square.com ... try that. you will probably have to use a translator, such as the Babelfish one at www.altavista.com
Turbonium is offline
Old 09-16-2004, 03:25 PM
  #3864
jeffreylin's Avatar
The spacers are only used for the rear, not front. Plus the spacers are 0.7mm, not 1mm.
jeffreylin is offline
Old 09-16-2004, 03:43 PM
  #3865
TryHard's Avatar
guys had something happen to me tonight that has happened a number of time recently, and I was wondering if anyone else has had this problem, and if so how they've cured it.
Basically the grub screw holding my spur gear mount in place keeps coming undone, even with threadlock (although i think this is part due to how difficult it is to get a good amount of threadlock on the screw). With a stock, it takes about 3 rounds, however with a mod (as I experienced last weekend) it can almost take 5mins, I just have to make sure it's real tight before I put the car on the track.
Now I know a simple solution would be to check it before every run, but surely there has to be a better and more reliable way to solve this.
If it's of any use, I'm using a gold colour grub screw, as per the kit instructions.
Regards
Ed
TryHard is offline
Old 09-16-2004, 04:33 PM
  #3866
JimmyMac's Avatar
I use a longer black grub screw.. and thread lock of course. Just make sure you are tightening down on the flat spot.
JimmyMac is offline
Old 09-16-2004, 04:34 PM
  #3867
stonedgti's Avatar
Trader Rating: 15 (100%+)
Anyone knows the part # for the A Bridge block?
stonedgti is offline
Old 09-16-2004, 04:38 PM
  #3868
rcspeedo's Avatar
Never had that happen to me eversince I had the car. I run Mod and 19 all the time and constantly do maintenance by dismantling the car and putting it back.. The only thing to watch out for is not to overtighten this. You may want to check wether the spur gear holders' thread is still good as well as the grub screw.
Hope this helps.
rcspeedo is offline
Old 09-16-2004, 06:51 PM
  #3869
FUK_WRX's Avatar
Originally posted by racer
here you go:
53627
thankx
FUK_WRX is offline
Old 09-16-2004, 09:05 PM
  #3870
ngo8's Avatar
ngo8 is offline
