Old 11-02-2004, 03:56 PM   #4591
Customworksking's Avatar
Trader Rating: 73 (100%+)
Originally posted by SpeedTech
GT Racer,
The A Bridge block is for the front of the car (the kit comes with D Bridge block) The A bridge block is narrower than the D block and it will sweep the front hinge-pins back a bit to help the car turn in a bit more.
Steve Wang
Hello I want to buy the A ft block where can i get it? thanx
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 11-02-2004, 04:01 PM   #4592
JimmyMac's Avatar
Well I do know that Tamiya USA did distribute a few "spools" and locked pulleys (different than what the normal locked pulley is) around the September time frame. So I wouldn't count out a 415 WCR with a Spool inside. After all, it would be a "limited" kit. And it wouldn't be a "true" Replica if it didn't have a Spool.
But who knows... if Tamiya did announce a 415 WCR before the 415MS is released... I'm sure it would hurt the sales of the 415MS since people would hold out instead and buy the 415 WCR.
Just a thought.. hehe..
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 11-02-2004, 04:46 PM   #4593
Originally posted by BlackKat
Same here bro! 1st race with the 415 & nabbed 2nd in Sportsman Stock (above Novice but below Expert) Led the 1st half of my main but the the guy in second was ripping off some expert stock quality lap times and got around me. Won a new body shell out of the deal though
Had a constant push ALL day though. I ordered an A bridge block to toe out the front arms but was sent the wrong block
So the A block that you get in the Kit is for the rear only? because my local can only find the 1 part# 51065..
Old 11-02-2004, 05:02 PM   #4594
BlackKat's Avatar
Speedtech R/C (www.speedtechrc.com) is the best place to buy Tamiya parts unless you happen to know a TRF driver or live in Aliso Viejo, CA
I don't know the part number for the front bridge block A (Steve, could you post that?) Thats probably why I got the wrong part in the mail
BlackKat is offline   Reply With Quote
Old 11-02-2004, 05:07 PM   #4595
ngo8's Avatar
Send a message via ICQ to ngo8
here you go
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 11-02-2004, 07:50 PM   #4596
dsrbltoys's Avatar
I use the tape to hold the batteries in, But I install a cut down TB02 battery brace to go over the top of batteries, and the under the tape. I can reuse the tape all week even running mod foam. I have had many troubles with the batteries looking like a W before I finaly came up with these solutions.
The only problem runing foams on the car seems to be when you use the LW suspension. The earlier mentioned lowering of the king pin helps if you run 28mm like jaco on the older suspension. If you want to run the LW suspesion, it doesn't allow the backspacing of the 28mm wheel without more modifying of suspension. I am still working on a better setup, I am still a little off pace of where I'd like to be, but thats using some of the best drivers in the nation type of times for a goal.
dsrbltoys is offline   Reply With Quote
Old 11-02-2004, 08:19 PM   #4597
Anybody knows what is the X block for??
SNAIL MAN is offline   Reply With Quote
Old 11-02-2004, 08:22 PM   #4598
razzo's Avatar
Send a message via Yahoo to razzo
Default Re: Re: Pinions????
Originally posted by Hebiki
running a 102T spur.. pick up 28-41T.. TiR pinions are the best. that set covers me for stock and 19T.
41? wow
for indoor carpet, to cover mod through stock, 24 through 30 should cover for 102 spur. On a tight indoor carpet track (80x40), with Monster stock, 102/28 works well.
razzo is offline   Reply With Quote
Old 11-02-2004, 08:25 PM   #4599
BlackKat's Avatar
I'm guessing the higher ones are for 19t
Guys are gearing the snot out of the Reedy Spec 19's
Old 11-02-2004, 09:02 PM   #4600
Originally posted by ngo8
here you go
sweet can I buy IT from you ?
Old 11-02-2004, 09:05 PM   #4601
ngo8's Avatar
HEHEEHEH no its a picture from a website that i copyed it from .
Old 11-02-2004, 09:34 PM   #4602
yah I went to tamiyausa and seen it...I found it @ speedtech but the part# is not the same as the right 1 you have......
it list as D bridge 51064-x and A bridge 51064-x I'm not sure what ordering so, I will e-mail them 1st..Thanx
Old 11-03-2004, 12:12 AM   #4603
Hebiki's Avatar
Trader Rating: 26 (100%+)
i used the 41T on the yokomo handout 19T at the Ko Propo Grand Prix
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 11-03-2004, 12:26 AM   #4604
razzo's Avatar
Another WOW.
I guess for those of us who race on carpet indoors only, we can't even fathom that gear ratio.
US seriously needs more tracks like Tamiya track, you guys in CA are spoiled.
Old 11-03-2004, 01:41 AM   #4605
SpeedTech's Avatar
Customworksking,
to conserve space on our website, a lot of times we consolidate similar parts under one part number. The option you want to select is the A-bridge block.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
