Old 11-05-2004, 10:53 PM   #4621
SpeedTech's Avatar
Default Re: Re: Lightweight suspension review
Originally posted by A-Ko
Nice article. Is there a part number out yet just for the arms?
Thanks,
For just the arms, I believe it is TAM51103, and it is readily available
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 11-06-2004, 12:10 AM   #4622
JimmyMac's Avatar
If you are trying to fit 28mm tires.. try the silver 6mm Tamiya wheel hexes and using A blocks up front. This "should" keep the car within 190mm. You "should" beable to do this with both the stand and LW suspension.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 11-06-2004, 12:22 AM   #4623
Send a message via AIM to A-Ko
Default Re: Re: Re: Lightweight suspension review
Steve Wang
Thanks Steve
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 11-06-2004, 05:43 AM   #4624
dawgmeat's Avatar
Default LW conversion carpet feedback
Sad too sat that it will not work with 28 foams because of the steering post rubbing against the wheel, as of a matter of fact you can't even get wheel on, so I will be running LW in the rear and standard in the front and i will use the wheel spacers as needed
dawgmeat is offline   Reply With Quote
Old 11-06-2004, 06:11 AM   #4625
dawgmeat's Avatar
Default Part question
who sell the aluminum hub carrier for the Ta04 STB-36B
Old 11-06-2004, 06:24 AM   #4626
Guys,
What is the part number of these 6mm wide Tamiya Wheel Hex Drives?
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 11-06-2004, 08:34 AM   #4627
SpeedTech's Avatar
Default Re: Part question
dawgmeat,
we have 1 more pair of those in stock (blue anodized) please email me if you're interested.
Steve Wang
Old 11-06-2004, 08:34 AM   #4628
SpeedTech's Avatar
Originally posted by 190mph
Guys,
190mph,
TAM53570 I believe is the number you're looking for
Steve Wang
Old 11-06-2004, 12:27 PM   #4629
markp27's Avatar
Send a message via ICQ to markp27
Talking Ready for action!
Winter is drawing in and my Nitro season is over, so my attention has been turned back to my TRF-415 which I bought a couple of months ago.
After finding the build process a little more fiddly than I liked (I built the 415 straight after the Xray T1 FK, which went together like a dream!), my opinion of the 415 has gone back up.
I'm very impressed with the weight distribtion of the chassis - I found with my setup, front and back + left and right are perfectly balanced. I had expected the weight of the battery pack to mean that the car would be heavier on that side, but to my surprise left and right are equal.
Also the weight of the car is perfect in my opinion - 1475 grams with the shell. This should mean with my personal transponder I won't have to add any weight to the chassis (which I have added until I mount the transponder).
With the Xray, I had to add over 100 grams of aditional weight to bring it up to the legal limit - meaning there are bits of lead stuck all over the chassis!
Anyway, before I start my testing of the two cars, here's a pic of my 415:
markp27 is offline   Reply With Quote
Old 11-06-2004, 01:22 PM   #4630
koabich's Avatar
Send a message via Yahoo to koabich
I am currently running 28MM foams on my 415 with stock suspension. I use the factory wheel hexes but use 1.5mm of Tamiya wheel spacers for each wheel. I run the A1 front rear block and the D1 Front front block and i am at 188mm. You will be fine either using my methed of the 6mm Tamiya hexes. i bought the hexes but never used them...they just don't look as cool as using the blue hexes with the red and blue wheel spacers !!
koabich is offline   Reply With Quote
Old 11-06-2004, 01:29 PM   #4631
ngo8's Avatar
Send a message via ICQ to ngo8
i am doing the exact same thing all i do is i shave off half mm of the wheels and its a perfect fit i took some pictures to show you guys .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 11-06-2004, 01:42 PM   #4632
ngo8's Avatar
here is one
Old 11-06-2004, 01:51 PM   #4633
ngo8's Avatar
Originally posted by ngo8
here is one
one more
Old 11-06-2004, 02:39 PM   #4634
Default Re: Ready for action!
Nice car
Chazz
Chazz is offline   Reply With Quote
Old 11-07-2004, 04:29 AM   #4635
I can't see why you would need 28mm foamies on a EP car.
I run foam on my 415 fine with LW sus.
Dual a-blocks on the front with 6mm hubs all round.
Add 1mm spacer to front and u fit 26mm foams easy, you can run whatever size foams on the rear but large foams will only reduce corner speed.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
