Speed Passion Thread >
Like Tree4Likes
Old 02-05-2013 | 10:05 AM
  #3076
I wish the R/S had a bit more BEC power. 2A with a Spektrum radio is a scary proposition.
cr133r is offline
Old 02-05-2013 | 01:22 PM
  #3077
2canSAM's Avatar
I would venture to say it is underrated. I have run the R and S both with a Spektrum DX3S/3100 and have had no issues at all. Even running a Savox on them and I was fine even without a Glitch Buster.
2canSAM is offline
Old 02-05-2013 | 03:08 PM
  #3078
beazer30801's Avatar
Default GT 2.1
anyone know if the GT 2.1 will run the tekin Pro 4 4600kv like the GT 2.0?
Thanks Beazer
beazer30801 is offline
Old 02-05-2013 | 03:17 PM
  #3079
AlanHall's Avatar
I also have a pro 4 question . I understand that we can't run any of the boost software but in the mod setting can I at least adjust the punch level and the timing settings available in the LCD box? Its strange to me the PRO would have issues. The amperage ratings aren't far from other ESC that run these motors.
AlanHall is offline
Old 02-05-2013 | 05:23 PM
  #3080
Originally Posted by kwiksi
Anybody test or have info on what's the best high torque rotor to put in the 17.5 MMM's. Planning on running blinky in RB6 and RT5. There's quite a bit rotors on the site.
Anyone?
kwiksi is offline
Old 02-05-2013 | 05:41 PM
  #3081
dvsstrike's Avatar
Anyone?
David this is the biggest rotor you can use that is legal
http://www.speedpassion.net/shop/det...=RS13803&c=MTR
dvsstrike is offline
Old 02-05-2013 | 06:37 PM
  #3082
Originally Posted by micrors4guy
BLUETOOTH help needed.
bought and installed one. It worked for a couple changes then stopped when i mounted it in the car. When it is plugged in i get no drive to the motor. However I will retain steering.
When i connect to the phone it will connect but i am unable to make changes then it will say it can not connect.
I have tried it on 3 different reventon pros and it is the same on all of them. I have gone threw the setup mode with it several times and it will not work properly.
Is there something that I am doing wrong? anything that i may be missing in setup or trouble shooting?
Maybe a 3rd time will be the charm to get an answer?
micrors4guy is offline
Old 02-05-2013 | 07:06 PM
  #3083
No i see a post about Rotors, What is the difference fo changing rotors, How do you know what to change to. what each will do?
ALIEN3T is offline
Old 02-05-2013 | 07:35 PM
  #3084
dvsstrike's Avatar
try changing the cables, most the time its a connection issue. i see the connections the cable is in backwards at times
Old 02-05-2013 | 08:06 PM
  #3085
Cain's Avatar
Thanks Beazer
no
The Pro4 motors don't like timing. Punch you can adjust however.
Cain is offline
Old 02-05-2013 | 10:54 PM
  #3086
Default gT 2.1
Ok thanks
Old 02-05-2013 | 11:30 PM
  #3087
I've had an issue with an SR300/Spektrum S6040 servo with a Reventon R. Never got a chance to try a glitch buster, but at about 70% travel in one direction it would brown out, go to center then turn again. Repetetive cycle. Could have been the 6040 servo has a small issue, but it didn't happen with my trusty Novak Kinetic. Oddly, it didn't happen with an SR3520 RX either.
cr133r is offline
Old 02-06-2013 | 01:07 AM
  #3088
MOmo's Avatar
For those running the SC104x4 out there...
I'm swapping out my HW 120A ESC and I want to use my GT2.0 LPF ESC. I am using a 5.5 2pole motor. Does anyone have any suggestions? I'm retiring my B4.1 and want to use the ESC from it in my SC104x4. Need some good setup advice.
MOmo
MOmo is offline
Old 02-06-2013 | 02:45 AM
  #3089
Carlos69's Avatar
Default SP Reventon LCD smart programming card
Does anyone know where online to buy the above ... ? The postage from Speed Passion online store is as much as the card itself putting the cost with shipping at about $75USD ... Extortion if you ask me... Anyone ?
Cheers
Carl
Carlos69 is offline
Old 02-06-2013 | 03:23 AM
  #3090
Cheers
Carl
Do u live in the US? Make sure to check the USPS shipping not Fed X.... I buy from the US store and the shipping is around $6
kerby is offline
