RC10B4.1 FT/WC
Old 09-02-2012 | 03:10 PM
  #19786
mxracer458's Avatar
has anyone ran the vts slipper and no running the avid?i would like a comparison between the two
mxracer458 is offline
Old 09-02-2012 | 03:16 PM
  #19787
racer1812's Avatar
Super Moderator
Originally Posted by Matt Trimmings
Dont count on it, the new BB shocks should have a larger diameter shock shaft.
pre-production units I saw had the same size shaft as the V2's
racer1812 is offline
Old 09-02-2012 | 03:21 PM
  #19788
Matt Trimmings's Avatar
Hmm...i didnt pay too much attention to the shaft size last time i saw them but someone else said that they were looking at Hartson's car a couple weeks back and the shafts were larger.
Matt Trimmings is offline
Old 09-02-2012 | 03:49 PM
  #19789
racer1812's Avatar
Super Moderator
I haven't seen them in a while so I wouldn't know if they made any changes or not.
Old 09-02-2012 | 04:11 PM
  #19790
RED-LINE M03's Avatar
Originally Posted by ryanpatrickgore
Haven't gotten the avid rack yet, but in general slop in a buggy is good.
If you have no slop it gets super twitchy and hard to drive. So I've been told by a few....
I was told the AE Factory drives b4.1wc cars are full of slop and that's how they like them. Not just the steering but the whole car.
I know one time my buddy wanted to freshen up his buggy so he put on all new plastic on the car and it drove like crap. When he put back on the old slop parts it was dialed again. The setup was never changed just the parts. So I agree some slop is a good thing.
RED-LINE M03 is offline
Old 09-02-2012 | 04:14 PM
  #19791
No truer words have even been typed on the interwebs..........
Bob Barry is offline
Old 09-02-2012 | 04:32 PM
  #19792
asc6000's Avatar
Racing 3 times a week for a couple years I had to build a new car every couple months and it took a couple weeks to get it right. So that was the practice car that got put into the mix as the oldest one just got worn out. Good old gold tubs....
asc6000 is offline
Old 09-02-2012 | 04:53 PM
  #19793
Gopher15's Avatar
I read about the last 25 pages, with installing any of the BB shocks, do you have to change the top shock mount, or do the stock ones work with the bigger shock?
Gopher15 is offline
Old 09-02-2012 | 05:23 PM
  #19794
my old car....
you add a 1mm shim to space out the shock bushing and then you file away the shock tower just a bit to allow room for the collar.
Old 09-02-2012 | 05:24 PM
  #19795
and yes that shock tower is more "aerodynamic" haha
Old 09-02-2012 | 06:05 PM
  #19796
vicdamone11's Avatar
+1 so true....never ever put fresh plastic in before a big race. I like a bit of chatter in my front end always. Do it 2 Weeks out id say. I run about 3 times a week.
how many of you guys are trying out The avid slipper? Im building up a blinky car in tge next couple of Weeks.
vicdamone11 is offline
Old 09-02-2012 | 07:06 PM
  #19797
Waflet's Avatar
Anyone like the slop in the AE steering rack over the Avid steering rack?
Not sure if having a steering locked down with the Avid is a good thing in a buggy.
I would think a little slop is good in a buggy.
What do you guys think?
Do you preffer the Avid rack or the stock rack?
I may buy one just to test it out.
Hideeho
Some slop in it is good, but there is a limit. With the stock steering blocks I could see the front wheels bouncing left & right as I went around corners. It was so bad it made it feel like a push. With the avid blocks there is a much more planted feel to the steering. Kind of hard to describe, but with stock block (even glued, which is better) I would put the wheel on the transmitter somewhere between here & there & wiggle it a little to try & compensate as I went around the corner. With the avid blocks (& a good servo!) you just turn the wheel to where it needs to be & it sits there all the way through the corner.
Waflet is offline
Old 09-02-2012 | 08:22 PM
  #19798
Can someone help with a question about front hex conversions.
I have two B4.1's I did the Front hex conversion with AVID/SC10 knuckle. Now The b4 with the front hex conversion doesn't have as tight of turning radius as my plain stock b4.1. Its at least 3mm difference just looking at the wheels cranked to the side. Is this normal, I can't imagine people would lose steering angle with this mod. thanks
Chase1472 is offline
Old 09-02-2012 | 08:29 PM
  #19799
I have two B4.1's I did the Front hex conversion with AVID/SC10 knuckle. Now The b4 with the front hex conversion doesn't have as tight of turning radius as my plain stock b4.1. Its at least 3mm difference just looking at the wheels cranked to the side. Is this normal, I can imagine people would lose steering angle with this mod. thanks
Something else is wrong...by going to the hex conversion you should not lose any amount of steering travel..are your caster blocks back on the correct sides?
Old 09-02-2012 | 08:32 PM
  #19800
AWWW SH&T I did put them on back words thanks I was about to throw this new worlds car out my window!!! Thank you
