Like Tree5Likes
SC10 4x4 Thread
Old 07-31-2012 | 08:48 AM
  #27556
Wildcat1971's Avatar
Tech Prophet
Originally Posted by Evil Genius jr.
I have 3mm under the front. Should I add more?
Back has nothing but I have the parts for the 8mm mod. That should help right?
Trying to avoid traction rolling on medium/high traction track.
The 8mm mod works great on preventing traction rolls.
Wildcat1971 is offline
Old 07-31-2012 | 08:58 AM
  #27557
Evil Genius jr.'s Avatar
Thanks I'll give it a go.
Evil Genius jr. is offline
Old 07-31-2012 | 09:12 AM
  #27558
long front like helps to on tration roll +1 on 8mm
9turn is offline
Old 07-31-2012 | 09:18 AM
  #27559
ryanpatrickgore's Avatar
Anybody else boosting an rx8 and a 2 pole 550? Whadda ya settings?
ryanpatrickgore is offline
Old 07-31-2012 | 09:19 AM
  #27560
Tech Prophet
I liked the 8mm mod and will probably put it back on. Has anyone used less than 7mm on the inside? What were the results?
  #27561
Mizchief's Avatar
I dont know why you guys give WC a hard time. His information is good if you just filter out the AE fan boy stuff.
I agree up to the point where fanboism replaces accurate information.
Mizchief is offline
Old 07-31-2012 | 09:25 AM
  #27562
Tech Prophet
yeah, I agree. I just separate it out
Old 07-31-2012 | 09:28 AM
  #27563
Jake S's Avatar
i have tried 5mm, 6mm, 7mm, and 8mm.... i liked 6mm the best on a medium traction outdoor track. not indoor season yet to say what i like best on super high bite
6mm felt the most consistent, but with 7mm ran faster laps.... 8mm was too much and 5mm was too little for me.
Jake S is offline
Old 07-31-2012 | 09:32 AM
  #27564
Tech Prophet
less = more camber gain?
Old 07-31-2012 | 09:45 AM
  #27565
So I went to 4seasons rc Sunday. Indoor tight clay track high traction. I tested the Exotek front locker hub all day. Back and forth on and off 3 times over. I have concluded that I prefer the stock v2 on the factory team over the exotek. The exotek made the truck feel more inconsistent and I had less control, cornering felt sloppy. The stock v2 was smoother overall and more consistent. Stock was faster by nearly .5 - 1 seconds. Didn't notice a difference between the two on the straight away.
Anybody want to buy a used one?
Old 07-31-2012 | 09:47 AM
  #27566
Tech Prophet
yeah, it is probably not needed indoors. I never really had too much of an issue on indoor clay with the stock vts. But on loamy outdoor, I liked it.
Old 07-31-2012 | 09:48 AM
  #27567
samuelsonmark71's Avatar
Have to keep in mind that with the Exotek, you should be running different front diff fluid than you would with the V2 diff. Other wise, steering will suffer
samuelsonmark71 is offline
Old 07-31-2012 | 09:51 AM
  #27568
Tech Prophet
ok, lets talk about that. Has anyone found out which diff oils work best with the exotec outdoors mixed traction? loamy to wet soft clay?
Old 07-31-2012 | 09:53 AM
  #27569
YGPM.
Old 07-31-2012 | 09:55 AM
  #27570
I was reading some where (not sure if it was here or in another forum) that some people were running like 10k front and 5-7k rear
